  3. Plugins
  4. Alexa guard via Vera-Alexa and spoken command support
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
36 Posts 5 Posters 10.1k Views 5 Watching
    So, Amazon recently released the ability to execute spoken commands.
    dbochicchio/VeraAlexa: Alexa plug-in for Vera and openLuup. (github.com)
    Using my plug-in, you could just do something like this:
    luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1",
      "RunCommand",
      {Command="-e textcommand:'Alexa, I’m leaving' -d 'Bedroom'"}, 666)
    Or any spoken command that's not directly accesible via routines. Something like
    "Play music everywhere"
    "TV volume to 32"
    "Pause TV"
    and much more 🙂
    Give it a try!
      Seems very cool. I need to look into this....
      Maybe add your app to the AltAppStore?
        @rafale77 it's already there 🙂
        Lookf for "VeraAlexa".
          ahh, right, I was not looking closely enough. Sorry.
            Is anyone using Vera Alexa to successfully (and hopefully silently) detect whether a particular Echo device is online? Amazon's Alexa devices notoriously rebuff any attempt at PING via TCP, yet will reveal their presence via ARP -A if you know their assigned IP address in advance.
            But that got me to wondering whether the Vera Alexa plug-in might permit a shortcut, using MSR in my case, to elicit a response from each Echo device telling me, "I'm here. I'm awake. I'm online." My primary goal is to send alerts when one of my devices drops offline, which they sometimes do without warning.
            Thoughts?
              I could in theory look at the device.json and use it to construct something, like a Devices variable or similar. Not sure how often this is updated, and I'm not sure if you could find something useful inside. For example, I'm parsing it to detect the alarms. I'm seeing an "online" property that might be useful to you.
              LibraSunL 2 Replies Last reply
                @therealdb said in Alexa guard via Vera-Alexa and spoken command support:
                Heck, even if it just updates daily that might suffice. I just hate when I go to speak to an Alexa device and realize that it's been "offline" for days, and I've never come up with a suitable warning notification for that condition.
                  Just curious, do you know why your alexa device went offline? When I had some, it was pretty rare and when it did happen, I recall that it would be because of an automated firmware update which failed to reboot the device or because of wifi/cloud issues. They were pretty rare (still one of the reasons why I hate the cloud for home automation with a passion) but was wondering if and why you had a higher frequency of these.
                  LibraSunL 1 Reply Last reply
                    @rafale77 said in Alexa guard via Vera-Alexa and spoken command support:
                    An alexa might drop out maybe four times a year or so. My hometown has a LOT of power outages, so I always assumed that was part of it. Other times, I'd just notice an Echo Dot sitting there with its light spinning. But the most recent occasion involved an accessory (that ironically includes a battery backup for a Dot, with built-in speaker) whose power light continued to glow even after it stopped providing current to the Dot.
                    So it's not one particular thing happening, it's rarely the same device, and it's never under my control. The reason I don't immediately notice the drop-out is that I'm never out of earshot of at least 3 Alexa devices in my small home. 🙂
                      @librasun I don’t have children in this a plugin, so if you’re able to parse a json/text, I could save it in a variable for sure. Maybe something like this
                      DeviceName,online,volume
                      Or similar.
                        Or similar.
                        @librasun I don’t have children in this a plugin, so if you’re able to parse a json/text, I could save it in a variable like DeviceName,online,volume
                        Yes, that's more than sufficient for my needs, since MSR can store HTTP replies and parse JSON objects with ease. Meraviglioso!
                        Of course, I'm sitting on my hands waiting for the next revision of Vera Alexa to come out, in hopes that the plug-in's basic functionality also returns. Version 0.94 only succeeds with the RunRoutine command, while all else is silent (the mirror opposite of 0.92).
                        I know you're very busy with other things, so no hurry either way!
                          My dots only go offline when there are wifi issues or, I think, a couple have crashed maybe twice total since I started using them about 3 years back.
                          AltUI says I'm on 1.0 and speech is fine, no routines.
                            @librasun it's done on my dev branch, but I'll need a more couple days to look at your problem. I'll probably release it later this week. it's not json based, but a simple comma-separated list, as I've anticipated before.
                              0.95 is on GitHub. I've managed to fix your problems @LibraSun @CatmanV2 . Give it a try.
                              I've also added a new UpdateDevices action, that's updating a Devices variable. It's also updated every time a new action is executed. @LibraSun try it and let me know!
                                Ooh, exciting! I'll get right on that and report back ASAP.
                                (Planning to d/l the ZIP, unzip it, and drop the relevant files into Vera > Dev Apps > Luup Files > restart > Ctrl-F5 refresh > leave "Configured" = 1, "Debug" = 0, "Announcements" = 0 and then run my test suite from MSR (via Lua commands).)
                                THANKS, DB!
                                QUICK FEEDBACK: Did the above and so far, no improvement.
                                For instance, I send this to Vera from MSR:
                                "luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command="-e weather -d 'Living Room'"}, 366)"
                                and get this response with no errors:
                                "sending cmd:weather to dev:Living Room type:A15ERDAKK5HQQG serial:eb48978706f5459f890ef0ec5aa9fce9 customerid:A3SL3Z0HELH3YG"
                                but still no audible sound. Will investigate, and likely go the "Configured=0" route to prompt any updates needing doing. (Did that, no improvement. Captured logs and sent to DB.)
                                  THANKS, DB!
                                  @librasun I've not tested RunCommand specifically. Routines and TTS are working for me. Off to test commands...
                                    Thanks. Just DL and unzip into the VeraAlexa folder, yes? Or Via AltApp store?
                                    Cheers
                                      @therealdb
                                      @catmanv2 said in Alexa guard via Vera-Alexa and spoken command support:
                                      It should be the same.
                                      I've tested RunCommand and it's working for me.
                                        Updated from GitHub Master. Have lose all TTS and recreating the .alexa.cookie does not resolve 😞
                                          Same here I keep getting
                                          50 04/27/21 10:32:06.865 luup_log:952: VeraAlexa[0.92@952](@279):Response from Alexa.sh: "cookie does not exist. logging in ... ERROR: Amazon Login was unsuccessful. Possibly you get a captcha login screen. Try logging in to https://alexa.amazon.ca with your browser. In your browser make sure to have all Amazon related cookies deleted and Javascript disabled! (For more information have a look at /storage/alexa/.alexa.login) To avoid issues with captcha, try using Multi-Factor Authentication. To do so, first set up Two-Step Verification on your Amazon account, then configure this script (or the environment) with your MFA secret. Support for Multi-Factor Authentication requires 'oathtool' to be installed." <0x6ce0c520>
                                          Even though I have tried getting a cookie file multiple times, oddly enough even though I used the Github files from today my plugin still show 0.92
                                            117.0k
