  2. Hardware
  3. Vera
  4. Using the vera with external usb zwave or zigbee dongle
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
11 Posts 4 Posters 4.1k Views 4 Watching
      Vera Plus:
      zwave_uart_prog -o write -d sd3503_flash -f firmware file name
      Vera Secure:
      rwee -w -z -x -f firmware file name
        The zwave firmware file is available for free from silabs SDK packages.
        Z-Wave 800 Series End Device Software Development Kit - Silicon Labs
        The Z-Wave 800 Series Software Developer’s Kit (SDK) intended to help developers creating Z-Wave Plus compliant products in a fast and cost-effective manner.
        The zigbee firmware is unfortunately not free and I have not upgraded beyond the embedded 5.6.0
        Edit:
        For kicks, I just downloaded version 6.82.01 and upgraded both the vera and homeseer stick...
        Note again that the vera takes the bridge version of the firmware while the generic USB dongles can take both the bridge and static versions.
        • Black CatB Offline
          Black CatB Offline
          Black Cat
          I prefer to use an external UZB with a extension utilising a powered USB switch and mounting the radio away from any other electrical devices regardless of it being Vera.
          Works extremely well with a RPi running Homeseer or HASS.
          aka Zedrally
          • Black CatB Black Cat
            Vera 3:
            You can run this script using WinSCP or similar, where the parameter "1" means run standalone:
            /usr/bin/UpdateZWaveFirmware.sh 1
            Basically the script is a wrap around for this command (the -x parameter is not used):
            rwee -w -z -f firmware file name
            Example firmware file name:
            /etc/cmh-zwfw/zwave_fw_3.67_us.bin
              Anyone know how to program an Aeotec USB stick with say version 3.67, when the stick is showing as version 2.78?
              It looks like the Vera "rwee" program will only program the Vera internal ZWave IC, not an external USB stick?
              Can the "rwee" application be tricked into programming an external USB device? Presumably the internal ZWave IC is also just a USB device. Can a USB redirection be put in place?
              Is there some other app that can do this?
                Did you say what (hardware) version of the stick? You might dig around on their web site.
                Upgrade network to Z-Stick Gen5+ and backup tool
                This article will lead you through transferring your old Z-Stick Gen5 network to a Z-Stick Gen5+ or to any new Z-Stick Gen5 unit and forms a part of a larger Z-Stick Gen5+ user manual. You may use these same steps to back up your Z-Stick Gen5...
                  It's an Aeotec S2 DSA02203. Must be about ten years old. I was going to see if this was any use:
                  ZW090_Z-Stick_Gen5+_AU_A_V1_02.exe
                  but these sticks aren't gen5 to start with. Played around with the Aeotec Windows USB drivers but they won't cooperate either.
                  • A a-lurker
                    Following up on updating an Aeotec S2 DSA02203 USB stick:
                    If the stick shows up as version 2.78 in the "Z-Wave Settings" in Vera, you can update it to version 3.67 using this program (works on Windows 10), available for download on this page - choose the version that suits the ZWave frequency used at your locale:
                    S2 firmware update program
                    Note the page talks about updating to version 3.08 but regardless it shows up as 3.67 in a Vera 3.
                      With 20 or more devices built in behind walls, I've been very wary of not wrecking my Zwave configuration. However time moves on and my dream of getting rid of Vera continues.
                      I originally had a Vera 3 doing the Zwave duties. As you can see from my comments above, I spent sometime trying to migrate a 300 series IC configuration to a 500 series IC.
                      Eventually the only way I could get this to work was by purchasing a secondhand Vera Edge as new config target. Backed up the Vera 3 to the cloud and imported the back up to the Vera Edge. Couldn't believe that it worked but it did. It's talked about here.
                      OK sit back and relax for awhile - erhh for a few months. I've only got so much hair on my head and it needs to be carefully husbanded.
                      So more recently I got a UZB stick with the view to copying the Vera Edge configuration on to the stick. The stick could then be used with the openLuup Zway plugin or with ZwaveJS using MQTT. I've not purchased a Zway license but I believe the software lets you play around with it a little. I think you can also do stick firmware upgrades with it - not sure on this.
                      I ran up the UZB Zway stick with the Z-Wave Expert User Interface.
                      The stick reports:
                      Z-Wave Chip:	ZW0500
                      Firmware
                      Library Type:	Static Controller
                      SDK Version:	6.71.01
                      Serial API Version:	05.27
                      Great. Should be able to use rafale77's excellent Vera to stick migration instructions so I end up with a stick I can play around with. Note that the migration process nukes the configuration in the Vera.
                      Well the migration didn't work. Fortunately a back up saved me. Strangely the Vera Edge reports the following under the Zwave settings for its internals vs the stick:
                      Vera Edge internal 500 IC:
                      Version: 6.01 L:1
                      Locale: au
                      HouseID/Node: House: 0x<house> Node 1 Suc 0
                      Role: Master SIS: NO PRI: YES
                      Stick version info:
                      Version: 4.61 L:1
                      Locale: au
                      So I can only assume the migration didn't happen because it looked like the stick was a backward step ie 6.01 to 4.61. However the stick looked really good in the Z-Wave Expert User Interface. ie 6.71.01 sdk & 05.27 firmware.
                      Where is the 4.61 coming from? Is it the SDK version? It can't be the stick version as it's not shown in this bewildering mess. No mention here of 4.61 either.
                      Also what does the "L:1" even mean?
                      Many moons ago at the other place rafale77 says:
                      "Finding it interesting that my external UZB dongle SD3503 reports version 6.07 L:1 when the internal ZM5304 reports 6.7 L:7. And also that with the upgrade I lost the primary state of the controller."
                      Looking at the Vera file /usr/bin/UpdateZWaveFirmware.sh there is this comment:
                      # LuaUPnP doesn't support leading 0 in numbers on either side of the dot,
                      # so we must interpret 4.5 / 6.1 as 4.05 / 6.01.
                      So Vera reporting 6.07 means 6.7 and 6.01 actually means version 6.1 !!!! Sounds like this is the SDK version number?
                      Anyway why can't I migrate the Vera Edge config to the Stick?
                      • A a-lurker
                        The stick reports:
                        Z-Wave Chip:	ZW0500
                        Firmware
                        Version: 6.01 L:1
                        Locale: au
                        Stick version info:
                        Version: 4.61 L:1
                        Locale: au
                        I developed this mapping table in answer to some of my own questions above.
                          125.7k
