  3. Plugins
  4. MQTT Plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
MQTT Plugin
72 Posts 8 Posters 39.8k Views 9 Watching
    Update: I now have a kind of a working solution and it is interesting...
    The fundamental problem is that setting up an MQTT client to listen to the broker blocks the luasocket and therefore openLuup.
    The two libraries use different approaches to the problem.
    The older library used by the vera MQTT plugin uses a handler function which polls the broker and gets and closes immediately regardless of getting a message or not. It therefore won't block the luasocket but it comes back empty 99% of the time and really relies on luck to catch a message as it can miss them. Basically unusable.
    The newer lua library does the same but waits for a message back and blocks the luasocket while waiting. If one sets a high polling frequency without getting a message back, openLuup hangs. My solution to this has been to significantly increase the frequency of messages from the publishing client to unblock the socket. It really is no longer event based and this generates a lot of traffic.
    If anyone has better suggestions (@therealdb I look forward to your bridge). I am also thinking that openLuup could use moving all its http traffic from luasocket to libcurl...
    Edit:
    I ended up giving up on trying to make it work with luasocket and spent 2min setting up 4 MQTT subscriptions on Home Assistant and another 10 to build the bridges back into openLuup. I really hoped to be able to do have a direct pipe into openLuup...
    B Offline
    B Offline
    Buxton
    @rafale77 hey Rafale,
    I went down the very same road a while back and threw in towel because the polling by the MQTT plugin created CPU drags that stopped openLuup from functioning "reliably". The instability was also in part because I use two other must-have plugins that rely on polling, and I imagine that the combination of the three was creating a scenario that caused intermittent failures. And I too ended up implementing MQTT in Home Assistant and then using RealDB's virtual HTTP plugin to send commands to my WiFi devices--albeit not knowing the status of the devices in openLuup after the send.
    I'm looking at RigPapa's socket proxy and WebSocket plugins to see if I can transform my polling plugins to Async. The MQTT plugin is too complex for me to convert though, so if you take a crack at it, and are successful, I would very much appreciate you publishing your results, as MQTT is becoming a must for me.
    GitHub - toggledbits/sockproxyd: A socket proxy for Vera/openLuup systems
    A socket proxy for Vera/openLuup systems. Contribute to toggledbits/sockproxyd development by creating an account on GitHub.
    GitHub - toggledbits/LuWS: A WebSocket client implementation for Luup (Vera and openLuup) systems, with optional async receive (responsive)
    A WebSocket client implementation for Luup (Vera and openLuup) systems, with optional async receive (responsive) - toggledbits/LuWS
    • B Buxton
      I was also thinking about using a proxy for this but it is really adding a layer of complication. For MQTT it might be work it though, I think @therealdb 's solution is likely a better approach... basically also kind of a proxy written in C to act as the client and seems to be very lightweight.
        I had a brief health problem in the latest days that put me completely KO, but I'm recovering. Code is almost done, I just need some time to test it under load and write some doc. I hope to finish it later today.
          here we are: https://github.com/dbochicchio/luup-mqtt
          Try it and let me know. It should be easy to acquire .NET Core SDK and build the app. It's very minimal, fast and should be easy to understand. Right now it's only updating variables (with virtual device I think it's more tha enough), but I could add other actions if needed.
          rafale77R A 2 Replies Last reply
            @therealdb
            Thank you! I will be testing it shortly now that I am done with my object recognition component and fixed a couple of network issues.
              RogerO
              Hi Guys,
              Was on the Lobo beta using Owntracks that Rigpapa was running but he killed it to focus on other projects. I have MQTT broker (Mosquitto) running on my rpi but can't figure out how to get MQTT data into a virtual switch on Vera. Did you ever get this working? Are there compiled files anywhere I can load on my Vera or openluup device?
              Roger
                I'm using it exactly for OwnTracks (well, a forked version based on this). I could publish compiled binaries for sure if you are interested.
                Since OwnTracks is publishing raw data, you'll need something (ie: some code in a scene) in order to really parse the lat/lon/accuracy and update a virtual sensor.
                  RogerO
                  Thanks, that would be great.
                    ArcherS
                    @therealdb I finally decided to try and setup MQTT for my Tasmota and Shelly devices.
                    After having built the bridge i.a.w. the instructions I have copied it to my Ubuntu PC that also is running OpenLuup. I put all the files in a folder in "Home" and given permissions sudo chmod -R a+rwx /path/to/folder.
                    (I built the files on my Win 10 PC in an Ubuntu WSL including -r linux-x64.)
                    The Tasmota test device I use says "MQT: Connected" in the console so it seems that it connects to the bridge when it starts. I also set up MQTT Explorer and it also connects to the bridge and shows the topics from the Tasmota device.
                    Despite this no temp value is set for the virtual sensor in OpenLuup I use for the test.
                    I have double checked the topic name, the topic path and the OpenLuup information and it seems correct.
                    appsettings.json:
                    	"MQTT": {
                    		"Username": "luup",
                    		"Password": "openluup",
                    		"Port": 1883
                    	"Luup": {
                    		"ipAddress": "127.0.0.1",
                    		"port": 3480
                    	"Devices": [
                    			"ClientID": "tasmota_test",
                    			"TopicName": "tele/tasmota_test/SENSOR",
                    			"TopicPath": "AM2301.Temperature",
                    			"DeviceID": 216,
                    			"Service": "urn:upnp-org:serviceId:TemperatureSensor1",
                    			"Variable": "CurrentTemperature"
                    	/* remove comment when you're OK with less logs
                    	"Serilog": {
                    		"MinimumLevel": {
                    			"Default": "Information",
                    			"Override": {
                    				"Microsoft": "Fatal",
                    				"System": "Fatal"
                    Sensor topic on Tasmota console is posted when Tasmota posts the data:
                    13:58:05 MQT: tele/tasmota_test/SENSOR = {"Time":"2021-01-28T13:58:05","AM2301":{"Temperature":23.5,"Humidity":37.3,"DewPoint":8.1},"TempUnit":"C"}
                    Device in OpenLuup:
                    The log file says:
                    2021-01-28 12:51:57.992 +01:00 [INF] [MQTTServer] Broker is starting on port 1883...
                    2021-01-28 12:59:21.709 +01:00 [INF] [MQTTServer] Broker is starting on port 1883...
                    2021-01-28 13:55:27.236 +01:00 [INF] [MQTTServer] Broker is starting on port 1883...
                    2021-01-28 13:57:48.402 +01:00 [INF] [MQTTServer] Broker is starting on port 1883...
                    Any ideas on what could be wrong? I have most likely missed something obvious. 🙂
                    //ArcherS
                      Sorry, nothing to suggest. I took a look at the MQTT code and while ago and it's rather poorly written.
                      FYI, though, I am in the process of writing a Shelly bridge for openLuup, which will have its own MQTT server and be able to automatically create configured devices for any Shellys that use it.
                      Turns out that it's rather easier to write a minimal MQTT server than it is an MQTT client.
                        ArcherS
                        Just to clarify, what I installed was the stand alone MQTT Bridge from @therealdb and not the old MQTT plugin. Perhaps it was a bit confusing of me to post it here...
                        I agree that MQTT in some form for sure is a great addition to OpenLuup and Shelly/Tasmota devices. 🙂
                        Automatically adding devices sounds promising!
                        //ArcherS
                          It uses the paho/mqtt library and utilities (albeit updated to v3.) I thought of using that as a base, but after inspection, started from scratch.
                          Yup, the only config would be to point the Shelly device at the server.
                          • A ArcherS
                            appsettings.json:
                            	"MQTT": {
                            		"Username": "luup",
                            		"Port": 1883
                            	"Luup": {
                            		"port": 3480
                            	"Devices": [
                            			"DeviceID": 216,
                            	"Serilog": {
                            		"MinimumLevel": {
                            			"Override": {
                            				"System": "Fatal"
                            Device in OpenLuup:
                            The log file says:
                            //ArcherS
                            @archers Today is a bad day, so I'll take a look at it tomorrow.
                            Maybe it's time to add some features I added to my branch lately.
                              #50
                              @ArcherS I did some tests. here's what I got:
                              [09:08:32 VRB] [MQTTServer] Message Received...
                              [sonoff-pool] - tele/tasmota/SENSOR - {"Time":"2020-07-26T08:21:19","DS18B20":{"Id":"02131D86D0AA","Temperature":25.3},"TSL2561":{"Illuminance":0.049},"SR04":{"Distance":45.421},"TempUnit":"C"}
                              [09:08:36 VRB] [MQTTServer] Processed message: got 25.3
                              [09:08:36 VRB] Matched value
                              [09:08:37 VRB] [LuupWrapper] Calling Uri: http://127.0.0.1:3480/data_request?id=variableset&output_format=json&DeviceNum=501&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=25.3&RunAsync=1 2
                              [09:08:37 VRB] [MQTTServer] Message Received...
                              [dbdomoticz] - owntracks/update/daniele - {"t":"c","tst":1611145530,"acc":65,"_type":"transition","event":"enter","lon":xx.615871,"topic":"owntracks\/DB\/daniele\/event","lat":xxx.995452999999998,"wtst":1610963724,"tid":"DB","desc":"Home"}
                              So, you should see at least the commands being reported. Check for permissions for the deamon and look at the console logs of your device. Maybe there's something (username? password? that's not correct.
                              EDIT: I just pushed a new release updated to .NET 5. Just get the new SDK, the build procedure is the same.
                                ArcherS
                                @therealdb the permissions etc look right, also username password are correct, I get "connected" in the Tasmota console, so it seems to connect.
                                Is your log above from the MqttBridge logfile? If so I cannot see it, it only says:
                                I think i will try to build it again. When looking in github I cannot see any updates to the files for some reason.
                                //ArcherS
                                • A ArcherS
                                  //ArcherS
                                  @archers crazy days at work. push is in progress.
                                  yes, this was from my own logs (where I attached owntracks as well - via a mqtt realy I have to test things around that's pushing mqtt messages from my prod system to my test ones).
                                    ArcherS
                                    #53
                                    @therealdb I tried to buid again from the new files, but I cannot get the Luup.MqttBridge to run the way it did before the update.
                                    Unclear what is wrong, I think I did everything in the same was as before. I noticed that the icon on the Luup.MqttBridge file is different when looking at it in Ubuntu "Files".
                                    //ArcherS
                                    • A ArcherS
                                      //ArcherS
                                      @archers what's the output of dotnet publish -c Release -r linux-x64? You can do it under Windows and it will produce executables for Linux as well.
                                      If you want just a single file, go with
                                      dotnet publish -c Release -r linux-x64 -p:PublishSingleFile=true --self-contained true
                                      this will produce a single file with everything inside. I'm updating the doc as well.
                                      • R RogerO
                                        @rogero @ArcherS @rafale77 I just published a compiled version for Linux-64. It's under releases. No SDK need to be installed, just chmod and you're ready to go.
                                        Release Version 0.30 · dbochicchio/luup-mqtt
                                        First compiled release. Just for Linux-x64. Build for Windows or Raspberry using .NET 5 SDK.
                                        If you're running Raspberry and need ARM-64, let me know and I could add it compiled as well.
                                          ArcherS
                                          @therealdb thanks for the build!
                                          When using your latest build the Luup.MqttBridge file for some reason is a "shared library (application/x-sharedlib)" and not as when building from the older version "executable (application/x-executable)" despite having set permissions.
                                          Really strange, I managed to get around this by creating a .sh file containing "./Luup.MqttBridge" and running this.
                                          Over first hurdle...
                                          However when I launch the new built file I still only get this in the log file:
                                          [19:17:23 INF] [MQTTServer] Broker is starting v 0.30.210109 on port 1883...
                                          It is as if it hangs while trying to start/starting.
                                          In the Tasmota console it says connected so the user/passwd seems ok:
                                          19:17:21 MQT: Connected
                                          So obviously not quite there yet. 🙂
                                          Any ideas on what the pronlem could be?
                                          //ArcherS
                                          therealdbT A 2 Replies Last reply
                                            163.1k
