  2. Hardware
  3. Vera
  4. Old apps
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
Old apps
11 Posts 3 Posters 1.8k Views 3 Watching
  • propheadP Offline
    propheadP Offline
    prophead
    Is there a way to remove a vera app and keep the devices it created?
      On the vera, the devices get deleted when they become orphan, meaning, their parents get deleted. Technically you could delete the plugin and keep the device yes, by preventing the device from becoming orphan. Change the parent id for example. What specific device are you trying to keep?
      • propheadP Offline
        propheadP Offline
        prophead
        Temperature children from ecobee app and weather underground app. These ids are referenced in multiple places. Would rather leave non working apps in place then to have to edit scenes. Im loath to touch any vera short of deleting it. Understand while apps don’t work I still update the variables from openluup.
          Yes, changing the parent (to 0, or some dummy device as a surrogate parent) should work. I’d also manually disable the parent apps, even if they’re not running properly. Backup first!
          • propheadP Offline
            propheadP Offline
            prophead
            Ok, how to disable apps without disabling devices? I like your idea of changing parent. I’m going to try that. What happens to scenes when one of their devices disappears?
              If you delete a device which is a scene trigger, then that trigger disappears, IIRC.
              All plugin devices should have a disable attribute which you can set to 1.
              • propheadP Offline
                propheadP Offline
                prophead
                Oh man what a nightmare. In case anyone was wondering if setting your parent to 0 on app child device will allow it to live past app deletion. It wont.
                • propheadP Offline
                  propheadP Offline
                  prophead
                  How do i creat a dummy device on vera it doesn’t seem to be working for me?
                    What have you tried to create? It can be anything. D_BinaryLight1.xml is be fine.
                    Had you disabled the plugin before the reload when you set a child device parent to 0?
                      Also, ... possibly important to remove the altid from the child device so that a plugin can’t identify it.
                      • propheadP Offline
                        propheadP Offline
                        prophead
                        Disabling the app via device was the way to go here. I didn’t know this was possible and I started your first suggestion before I read the second. After a lot of scrambling I got back to where I need to be less one more vera app.
