  3. Not so quiet around here :)
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Forum sysops
37 Posts 11 Posters 6.7k Views 11 Watching
    Got banned quite quickly from Vera/ezlo forum, without any warning. I was kinda asking for it, but still, they could have some sense of humour over there 🙂
    Using MSR on Docker (Synology NAS), having InfluxDB, Grafana & Home Assistant, Hubitat C-8, Zigbee2MQTT
      I am so sorry that happened. I recognized immediately that was going to be a problem, and I tried to moderate the post out, but they've taken away my moderation rights, even in my own categories. I guess they are making the new order of things for the eZLO brand, as they must. But they're being pretty draconian about it, and I think a lot of people have taken note and it is merely the chilling effect that keeps them from crying out. Many will vote with their feet just the same, if only because if it's not safe to complain when something doesn't work, nothing will get fixed, and if nothing gets fixed, there's no reason to continue on the product.
        On the positive side (and I'm saying this in hope that @Sorin and @alecs are paying attention here at SHC?!), ezlo is moving in the right direction of engaging their own staff more -- FINALLY! -- on the ezlo Forum. Regrettably, nobody there has responded to my numerous requests to have my account reinstated, which means I can never participate even to edit my own content over there. Which I consider a loss to both parties, as well as all of our fellow Vera-using comrades.
        Really wish they had simply split ezlo-related topics into an entirely new Forum (perhaps even ezlo into an entirely new company) rather than cannibalize what was in place, operating quite smoothly, since 2009. Sad that one man can ruin an entire operation, when it would have been so much easier and more suitable for the owner to insulate end-users from his ego with several layers of good-humored employees. I don't see any other tech company's boss yelling at customers and booting them out right and left?!?!
        Sad.
          I've asked for them to delete my account, but they say "the jury's still out" in the case of the "SHC mutineers". 🙄 😉
          toggledbitsT rafale77R 2 Replies Last reply
            @toggledbits, no worries, as said I was aware that could happen. As I didn't have previous "offenses" I thought I would at least get a warning first, but that didn't happen.
            Well, it's time also for me to leave "official" Vera behind (already I've used your excellent decouple-script) and continue my journey in the world of home automation. MSR is one of those logical next steps.
            • PerHP PerH
              @perh said in Not so quiet around here 🙂:
              If you're in GDPR territory, there is no jury. Your request is ironclad.
                sender
                Yep, GDPR has a legal clause on the "right to be forgotten". Although this is about "personal data that can lead back to an individual". And since that is very broad and companies don't want to be fined they comply with such a request. But on the other hand... most companies don't even know what your talking about and leads nowhere...
                • PerHP PerH
                  Did they actually use the term "mutineers" there?
                  Are they actually serious? Do they still think that we are properties/employees/soldiers they should have any sort of control over? I hope not.
                  They are booting the most loyal customers, ones who are willing to spend their time providing free customer support to others, sharing their fixes and findings to the community. Customers who are also providing them feedback to make their products better... He forced the creation of this forum with censorship then accuses people of all kinds of things and now is surprised that people are leaving? 😲
                  Trust me only a very small number of those who have left are here. Many more are on many other platforms ranging from Homeseer to Hubitat to Home Assistant. And the cold hard truth is, that everyone has been much better off after leaving, has a much more reliable and capable system and for those who rely on community forums, have a place to discuss and have fun learning again.
                    hehe, no they didn't. Just me exaggerating. I said that i'd like a reason for the suspension, and a resolution to wether it would be upheld, and if so, to delete my account completely.. we'll see. 🙂
                      Hello
                      I've not read all your comments yet here but I will.
                      @tunnus I can't believe they banned you that is terrible, just for that? That's crazy.
                      I was lucky not to get banned myself then as I replied to you. 😲
                      Regarding the lost of our moderator rights for those of us that had them.
                      I have been told it was an unintended side affect of them introducing the new E badges for their staff and the new "Ezlo Response Team" group thing.
                      I asked directly if it was a company policy change?
                      Here is what I was told:
                      It was a side affect not policy
                      Anyone who has been affected by this issue can contact them (probably Sorin) for a fix.
                      I was also told that they wanted to make sure that anyone who was contributing to the forum as a moderator could continue their good work.
                      I have been restored as a moderator now and also had a power up with new badge titles to choose from.
                      However I am not sure if the list of users who where previously moderators is now lost to them ?
                      I have asked Sorin to confirm yesterday, but not had a response back as yet.
                      So you may need to contact him for a fix on your own account.
                      However it is very troubling that members are being banned for little to no reason and no warnings given. Its not good at all.
                        WHO did you get those responses from? I've only heard (twice) from Tech Support (which the Forum Rules FAQ sends you to when contesting an account suspension) in which they merely said, "We're aware but are not in charge. Forward to the forum managers. Stand by." in essence.
                          @librasun said in Not so quiet around here 🙂:
                          Directly from the main man himself.
                          In which regard? Don't tell me you have been banned as well ?
                            YES! Ostensibly for "Like"-ing someone else's reply?? (I was given no reason, and only found out by surprise the next day.)
                            In fact, the entire Leaderboard (since 2009) -- with a few key exceptions, mercifully -- has been banned. That's why it's so quiet over there.
                            And I wouldn't know how to get in touch with any of ezlo staff, esp. the owner, without being able to DM them on the Forum. Catch-22!!
                              Sorin has just told me Elcid is also suspended. Don't know what he's done.
                                I have the long list of banned Forum members but it has grown since Feb. 27 when I made it.
                                It starts... "ElCid, HSD99, Matteburk, Mai_Pensato, Crille, eonnet, hienry_k9, Forzaalfa, TomD, LibraSun, Shoktronic, DesT, Catman, kfxo, Pabla, slelieveld, akbooer, rafale77, matsohl, tunnus..."
                                I strongly suspect you get a pass because you author a tech blog.
                                  Gees, I know a lot of those names, didn't know Pabla and Crille were banned and I certainly didn't know ElCid was banned.
                                  Well I always speak my mind and if something doesn't work I'll say it doesn't.
                                  PablaP 1 Reply Last reply
                                      I'm suspended until 2/27/3021 according to the Sign On screen.
                                      "Account suspended until February 27, 3021: Breach of forum rules"
                                      (FYI, I did not know this for 48 hours, because the login screen said nothing at all at first.)
                                        @tunnus said in Not so quiet around here 🙂:
                                        Welcome to the new normal 🙂
                                        @toggledbits said in Not so quiet around here 🙂:
                                        Ummm, not really unless the data is stored in GDPR geography ITYF.
                                          Clearly they aren't using the forum platform software as intended. "Suspended" is meant to be a reasonable time based suspension rather than a permanent ban.
                                          Others who have been "Suspended" also. won't be back then if they have the same date of 3021 ?
                                          Appears there are no proper appeals process or procedures.
                                          Only thing you could do is contact Customer Care for what good that might do.
                                          Who is going to help me with Node-Red now? Is ElCid a member here ?
                                          ElcidE 1 Reply Last reply
                                          • Oh the joy of pairing
                                          • HDMI oddness
                                            668
                                            sethlampman
                                          • Date/time condition
