  2. Hardware
  3. Vera
  4. Sensative Strip showing two instances in Vera.
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
Help with Luup Reloads
Recently I have been getting constant reloads on my Vera Plus running the latest 7.32 beta build. It usually starts after a 3-4 day Luup uptime and the reloads start at around 5am local time and keep going every 30 mins until I physically restart my Vera Plus (unplugging and plugging it back in). Right before a reload I see on the status bar above the modes on the homepage "cannot write user data" then after a few minutes a reload occurs. Looking into the logs I have seen mention of 03 06/21/21 8:53:18.102 JobHandler_LuaUPnP::Reload: low memory Critical 1 m_bCriticalOnly 0 dirty data 1 running 1 <0x76aa7520> almost every single time a reload happens. I have attached logs from 2 instances this morning where a reload happened. I have noticed that the OpenSprinkler plugin has been very chatty even though I have set debugging to 0, is that what is filling up temp log system? 01 06/21/21 8:45:58.123 IOPort::Connect connect -1 192.168.8.43:23 <0x6a148520> 02 06/21/21 8:45:59.031 UserData::CommitToDatabase data size 1244271 1244271 <0x7662b520> 01 06/21/21 8:45:59.333 UserData::WriteUserData saved--before move File Size: 234865 save size 234865 <0x7662b520> 02 06/21/21 8:45:59.333 UserData::TempLogFileSystemFailure start 0 <0x7662b520> 02 06/21/21 8:45:59.334 UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x7662b520> 02 06/21/21 8:45:59.334 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x7662b520> 01 06/21/21 8:45:59.341 UserData::WriteUserData failed File Size: 234865 save size 234902 <0x7662b520> 02 06/21/21 8:45:59.342 UserData::TempLogFileSystemFailure start 1 <0x7662b520> 02 06/21/21 8:45:59.344 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x7662b520> 01 06/21/21 8:45:59.632 UserData::WriteUserData failed result:1 size2:234865 vs 234865 <0x7662b520> 02 06/21/21 8:45:59.632 UserData::TempLogFileSystemFailure start 1 <0x7662b520> 02 06/21/21 8:45:59.634 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x7662b520> 02 06/21/21 8:45:59.635 UserData::TempLogFileSystemFailure start 0 <0x7662b520> 02 06/21/21 8:45:59.635 UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x7662b520> 02 06/21/21 8:45:59.636 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x7662b520> 06 06/21/21 8:45:59.636 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 2 #hooks: 0 upnp: 0 skip: 0 v:0x1099d38/NONE duplicate:0 <0x7662b520> 06 06/21/21 8:45:59.637 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: OK now: Resetting ZWave Network #hooks: 0 upnp: 0 skip: 0 v:0x1a02d48/NONE duplicate:0 <0x7662b520> 06 06/21/21 8:45:59.637 Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusID was: 0 now: 3 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x7662b520> 06 06/21/21 8:45:59.638 Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusText was: OK now: GET_LANG(resetting_zigbee_network,Resetting Zigbee Network) #hooks: 0 upnp: 0 skip: 0 v:0x12b9e60/NONE duplicate:0 <0x7662b520> 01 06/21/21 8:45:59.648 RAServerSync::SendAlert notification lost quit 1 device 50002761 servers:vera-us-oem-event12.mios.com/vera-us-oem-event11.mios.com for time 23822220 type 7 code user_data <0x7642b520> 02 06/21/21 8:46:01.381 UserData::CommitToDatabase data size 1244349 1244349 <0x770dc320> 01 06/21/21 8:46:01.675 UserData::WriteUserData saved--before move File Size: 234875 save size 234875 <0x770dc320> 02 06/21/21 8:46:01.675 UserData::TempLogFileSystemFailure start 0 <0x770dc320> 02 06/21/21 8:46:01.676 UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x770dc320> 02 06/21/21 8:46:01.676 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x770dc320> 01 06/21/21 8:46:01.680 UserData::WriteUserData failed File Size: 234875 save size 234865 <0x770dc320> 02 06/21/21 8:46:01.680 UserData::TempLogFileSystemFailure start 1 <0x770dc320> 02 06/21/21 8:46:01.682 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x770dc320> 01 06/21/21 8:46:01.940 UserData::WriteUserData failed result:1 size2:234875 vs 234875 <0x770dc320> 02 06/21/21 8:46:01.941 UserData::TempLogFileSystemFailure start 1 <0x770dc320> 02 06/21/21 8:46:01.943 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x770dc320> 02 06/21/21 8:46:01.944 UserData::TempLogFileSystemFailure start 0 <0x770dc320> 02 06/21/21 8:46:01.945 UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x770dc320> 02 06/21/21 8:46:01.945 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x770dc320> 50 06/21/21 8:46:03.102 luup_log:1304: VeraOpenSprinkler[1.50]: [updateFromController] error: false - nil - nil <0x72581520> 01 06/21/21 8:46:05.210 Main WatchDogRoutine: blocked - terminating 1 <0x695de520> 02 06/21/21 8:46:05.211 Dumping 40 locks <0x695de520> 02 06/21/21 8:46:05.211 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.211 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.211 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.211 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.212 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.212 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.212 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.212 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.212 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.212 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.213 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.213 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.213 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.213 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.213 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.213 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.214 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.214 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.214 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.214 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.214 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.214 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.215 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.215 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.215 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.215 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.215 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.215 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.216 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.216 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.216 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.216 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.216 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.216 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.217 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.217 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.217 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.217 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.217 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.217 OL: (0xbbc560) (>100746) Variable JobHandler_LuaUPnP.cpp l:9817 time: 4:00:00p (1624290365 s) thread: 0x6f948520 Rel: Y Got: Y <0x695de520> 02 06/21/21 8:46:05.217 finished check for exceptions <0x695de520> 02 06/21/21 8:46:05.218 OL: (0xbbc560) (>100751) Variable JobHandler_LuaUPnP.cpp l:9817 time: 4:00:00p (1624290365 s) thread: 0x6d948520 Rel: Y Got: Y <0x695de520> 2021-06-21 08:46:05 - LuaUPnP Terminated with Exit Code: 137 03 06/21/21 8:53:18.102 JobHandler_LuaUPnP::Reload: low memory Critical 1 m_bCriticalOnly 0 dirty data 1 running 1 <0x76aa7520> 01 06/21/21 8:53:18.103 luup_log:901: Tesla Car_error: Monitor awake state, failed #400 HTTP/1.1 400 BAD REQUEST !! <0x72ffd520> 02 06/21/21 8:53:18.482 UserData::CommitToDatabase data size 1244185 1244185 <0x76aa7520> 01 06/21/21 8:53:18.781 UserData::WriteUserData saved--before move File Size: 234865 save size 234865 <0x76aa7520> 02 06/21/21 8:53:18.781 UserData::TempLogFileSystemFailure start 0 <0x76aa7520> 02 06/21/21 8:53:18.781 UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x76aa7520> 02 06/21/21 8:53:18.782 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x76aa7520> 01 06/21/21 8:53:18.787 UserData::WriteUserData failed File Size: 234865 save size 234875 <0x76aa7520> 02 06/21/21 8:53:18.787 UserData::TempLogFileSystemFailure start 1 <0x76aa7520> 02 06/21/21 8:53:18.789 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x76aa7520> 01 06/21/21 8:53:18.813 IOPort::Connect connect -1 192.168.8.43:23 <0x6a7c4520> 01 06/21/21 8:53:19.020 UserData::WriteUserData failed result:1 size2:234865 vs 234865 <0x76aa7520> 02 06/21/21 8:53:19.020 UserData::TempLogFileSystemFailure start 1 <0x76aa7520> 02 06/21/21 8:53:19.023 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x76aa7520> 02 06/21/21 8:53:19.027 UserData::TempLogFileSystemFailure start 0 <0x76aa7520> 02 06/21/21 8:53:19.028 UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x76aa7520> 02 06/21/21 8:53:19.028 UserData::TempLogFileSystemFailure 0 res:0 (null) <0x76aa7520> 06 06/21/21 8:53:19.029 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 2 #hooks: 0 upnp: 0 skip: 0 v:0x14bad80/NONE duplicate:0 <0x76aa7520> 06 06/21/21 8:53:19.029 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: OK now: Resetting ZWave Network #hooks: 0 upnp: 0 skip: 0 v:0x1e23b10/NONE duplicate:0 <0x76aa7520> 06 06/21/21 8:53:19.033 Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusID was: 0 now: 3 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x76aa7520> 01 06/21/21 8:53:19.040 RAServerSync::SendAlert notification lost quit 1 device 50002761 servers:vera-us-oem-event12.mios.com/vera-us-oem-event11.mios.com for time 20546340 type 7 code user_data <0x76ca7520> 06 06/21/21 8:53:19.044 Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusText was: OK now: GET_LANG(resetting_zigbee_network,Resetting Zigbee Network) #hooks: 0 upnp: 0 skip: 0 v:0x16dadc0/NONE duplicate:0 <0x76aa7520> 02 06/21/21 8:53:20.807 UserData::CommitToDatabase data size 1244263 1244263 <0x77759320> 01 06/21/21 8:53:21.081 UserData::WriteUserData saved--before move File Size: 234875 save size 234875 <0x77759320> 02 06/21/21 8:53:21.081 UserData::TempLogFileSystemFailure start 0 <0x77759320> 02 06/21/21 8:53:21.116 UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x77759320> 02 06/21/21 8:53:21.117 UserData::TempLogFileSystemFailure 699 res:1 -rw-r--r-- 1 root root 504 Jun 26 2017 /etc/cmh/user_data.json.luup.lzo -rw-r--r-- 1 root root 234865 Jun 21 08:53 /etc/cmh/user_data.json.lzo -rw-r--r-- 1 root root 234996 Jun 21 08:11 /etc/cmh/user_data.json.lzo.1 -rw-r--r-- 1 root root 234930 Jun 21 08:02 /etc/cmh/user_data.json.lzo.2 -rw-r--r-- 1 root root 234968 Jun 21 07:47 /etc/cmh/user_data.json.lzo.3 -rw-r--r-- 1 root root 234658 Jun 21 07:11 /etc/cmh/user_data.json.lzo.4 -rw-r--r-- 1 root root 234909 Jun 21 06:50 /etc/cmh/user_data.json.lzo.5 -rw-r--r-- 1 root root 234875 Jun 21 08:53 /etc/cmh/user_data.json.lzo.new <0x77759320> 02 06/21/21 8:53:21.228 UserData::TempLogFileSystemFailure start 0 <0x77759320> 02 06/21/21 8:53:21.259 UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x77759320> 02 06/21/21 8:53:21.259 UserData::TempLogFileSystemFailure 610 res:1 -rw-r--r-- 1 root root 504 Jun 26 2017 /etc/cmh/user_data.json.luup.lzo -rw-r--r-- 1 root root 234875 Jun 21 08:53 /etc/cmh/user_data.json.lzo -rw-r--r-- 1 root root 234865 Jun 21 08:53 /etc/cmh/user_data.json.lzo.1 -rw-r--r-- 1 root root 234996 Jun 21 08:11 /etc/cmh/user_data.json.lzo.2 -rw-r--r-- 1 root root 234930 Jun 21 08:02 /etc/cmh/user_data.json.lzo.3 -rw-r--r-- 1 root root 234968 Jun 21 07:47 /etc/cmh/user_data.json.lzo.4 -rw-r--r-- 1 root root 234658 Jun 21 07:11 /etc/cmh/user_data.json.lzo.5 <0x77759320> 06 06/21/21 8:53:21.465 Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeDevice1 variable: PendingRemoveDevices was: 0024460000144655-01d8,0024460000146120-a155,00244600001467ad-a538 now: 0024460000144655-01d8,0024460000146120-a155,00244600001467ad-a538 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77759320> 06 06/21/21 8:53:21.469 Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeDevice1 variable: UnknownDevices was: now: #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77759320> 03 06/21/21 8:53:22.100 LuaUPNP: ending <0x77759320> 2021-06-21 08:53:22 - LuaUPnP Terminated with Exit Code: 0```
Vera
8 Posts 2 Posters 508 Views 2 Watching
    RogerO
    I have a Sensative strip that is in Vera twice. Each one has a different Device number and ID. Have tried to delete one and it will not go away. How can I remove one without loosing the other?
    • R RogerO
      @rogero
      This is what this device looks like on Z-way
      I have a handful of them and had great grief with how the vera zwave management wiped out its battery to 20-25% of its rated lifetime. Alright I digress.
      The inclusion process of this device was broken on later vera firmwares so I don't know whether you included it only recently. What broke is the fact that the firmware on these strips require for the controller to get out of inclusion mode and start a number of configuration steps for the device to save its new HomeID and DeviceID. The vera has just become too slow or is too busy having fun maintaining itself most of the time and fail the inclusion process even though it thinks it completed it. The strip will not have saved it's new network.
      To be sure, can you post the attribute screens of your 2 devices on the UI? This device only has one z-wave instance and therefore should not have any child devices.
        RogerO
        What info are you looking for? CW-KID is helping me on Ezlo forum. maybe I shouldn't have posted in both boards.
        BTW, this strip is my oldest one and has been in Vera for a few years, though I may have lost and re-added it last time I had to replace my Bricked Vera Plus. The rest of my Sensative produces ate showing 100% battery and only one instance of each device. This one is down to 75% so that is causing concern, otherwise I would just ignor the second instance.
          This is rather strange. Not sure why you would have 2 devices. Is the vera updating both when you trip/untrip the sensor?
          I am trying to see if one is a child of the other or if one is just a ghost device which is registered in the vera z-wave chip during a failed inclusion as I described above and the other came from a previous successful inclusion.
            RogerO
            Only the second device trips when the door is opened. The have separate ID's and both are children of the controller.
              ok so I think you should be able to delete the one which doesn't trip. It is likely a ghost device (make sure they have different altid) which is remaining on the z-wave chip from a failed inclusion.
                RogerO
                I have tried deleting the device and it will not go away. Doing it through the UI anyway.
                  It is a sign that the device record is in the vera's zwave chip and not only in the vera user-data file. Sorry it's been a while now since I've dealt with a vera UI but I thought there was a way to irreversibly delete a device. Maybe from the advanced/zwave menu?
                    RHCPNG
                  • Links to MSR from HA
                    Tom_DT
                    Tom_D
                  • 🎉 My very first MSR controller: OpenSprinkler
                    744
                    45.5k
                  • Z-Wave Future....
                  • Can´t restart or upgrade/deploy MSR
                  • [Solved] Limit HA Entity in MSR
