  3. Plugins
  4. Homebridge to Openluup
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
AltUI sort?
Am I losing it or did there used to be a sort either alphabetically or numerically option on devices in AltUI? Seems to not be there there? TIA C
Plugins
41 Posts 5 Posters 15.6k Views 5 Watching
    ronluna
    wrote on last edited by ronluna
    Sharing what I believe is a great way to add support to devices that used to work but since existing plugin haven't been maintain by the original authors (or any other developer in the community) have stopped working as they've abandon or moved to other platform...
    Homebridge has a large and very active community and I think this type of plugin will a good way to benefit from it.
    It will bring any device that have been configured in homebridge into openluup.
    Currently it support, thermostat (Nest and others), Switches (Specially MyQ), Dimmers, Switches, Motion Sensors, Door Lock (Open/close) Support to other type of device can easily be added.
    Homebridge2Openluup
    Installation:
    • upload the files to /you_openluup_directory/files/
    • create a new device with D_Homebridge2openluup1.xml
    • Set your hombredige IP, username, password to the deivce's attributes
    • Capture the uuid of the device you would like to bring from Homebridge into openluup by looking at your openluup logs when starting
    • based on the device type, set DeviceList Variable
    T for thermostat
    D for dimmers
    S for switches
    G for garage doors
    L for Locks
    A for motion sensors
    and build a string device type are delimited by a ; (semicolong) and device's uui by a , (comma) like this:
    T:homebridge_thermostat1_uuid,homebridge_thermostat2_uuid;D:homebridge_dimmer1_uuid,homebridge_dimmer2_uuid etc
    This still in beta, would love to add async next and support to shades and other sensors.
      Hi Ron, thanks for that.
      Not a HomeBridge user myself (yet) but it might be nice to have a version of the above information in the GitHub README file.
      Hope all's well (as it can be!)
      AK
      R 1 Reply Last reply
        I will add my Thanks as well. This is a great addition! I use Homekit in the other direction but I can definitely see use cases for this.
          AK
          ronluna
          thanks @akbooer . I'll be adding the installation instructions to the readme file... By the way, this plugin also works for ecobee thermostat, the native ecobee lua plugin by @rafale77 works ok when there is only one thermostat in the ecobee account but when more than one, ecobee server keeps deauthorizing the plugin...
          @rafale77 I also use homebridge the other way (openluup to homebridge) and is great.
          I'm currently using it for:
          • Nest thermostats with google accounts.
          • Ecobee accounts with multiple thermostats
          • AUX Mini split with built-in wifi modules
          Planning on adding control for AppleTV , Ring devices, Doorbird motion detection and many more...
          It will allow us to finally include many of the popular cloud based devices that own into the openluup environment...
          Something really cool about homebridge is that the manual and basic automation can be done from within homekit by the end-user, but deeper logic can be done from within openluup. Thinking about bringing node-red into the mix also... anyhow... I hope it can be useful for everyone here...
            Hi ronluna
            Great to see more stuff supporting openLuup and the like. If you feel like adding the plugin to the Alt App Store; I can add it to the list of available plugins:
            https://smarthome.community/topic/247/list-of-plugins-available-at-the-alternative-app-store?_=1615766458771
              A bit farfetched at the moment but I just had a brainfart that I could bridge my Home Assistant components to homekit and then fetch them back into openLuup using this plugin... pretty awesome.
                My thermostats show values in Fahrenheit, is there a way to change to Celsius?
                I found this in the log but doesn't seem to have any effect.
                homebridge2openluup debug: Engine Global Temperature Unit = C
                R 2 Replies Last reply
                  ronluna
                  @crille I'll add support to the upcoming update.
                    ronluna
                    Just added some fixes for Celsius @crille Please test the latest update from the github repo.
                    CrilleC 2 Replies Last reply
                    • R ronluna
                      @ronluna Yes, it's displayed in Celsius now, thank you.
                      • R ronluna
                        @ronluna I cannot change setpoint though.
                        Homebridge:[string "L_Homebridge2openluup1.lua"]:83: attempt to compare number with string
                          ronluna
                          @crille pushed new fix for celsius. the plugin is now available on the altappstore.
                          • A a-lurker
                            Hi ronluna
                            ronluna
                            @a-lurker done!
                            • R ronluna
                              @ronluna I reinstalled the plugin from altappstore but still can't change setpoint. It's sending the wrong characteristicType
                              2021-03-19 08:47:29.288   luup_log:17: homebridge2openluup debug: Homebridge Put device VALUE = 23
                              2021-03-19 08:47:29.288   luup_log:17: homebridge2openluup debug: request_body for everything else = {"characteristicType":"HeatingThresholdTemperature","value":"23"}
                              2021-03-19 08:47:29.288   luup_log:17: homebridge2openluup debug: PUT Auth = Bearer XXXXXXXXXX
                              2021-03-19 08:47:29.288   luup_log:17: homebridge2openluup debug: PUT Request Body = {"characteristicType":"HeatingThresholdTemperature","value":"23"}
                              2021-03-19 08:47:29.288   luup_log:17: homebridge2openluup debug: PUT Request Length = 65
                              2021-03-19 08:47:29.303   luup_log:17: homebridge2openluup debug: URL request result: r = 1
                              2021-03-19 08:47:29.303   luup_log:17: homebridge2openluup debug: URL request result: c = 400
                              2021-03-19 08:47:29.303   luup_log:17: homebridge2openluup debug: URL request result: h = table: 0x55b66e8b2910
                              2021-03-19 08:47:29.303   luup_log:17: homebridge2openluup debug: PUT Access Token = XXXXXXXXXX
                              2021-03-19 08:47:29.303   luup_log:17: homebridge2openluup debug: response_body PUT 1 = {"statusCode":400,"message":"Invalid characteristicType. Valid types are: 'TargetHeatingCoolingState', 'TargetTemperature', 'TemperatureDisplayUnits', 'RotationSpeed', 'TargetHorizontalTiltAngle', 'TargetVerticalTiltAngle'.","error":"Bad Request"}
                              2021-03-19 08:47:29.303   luup_log:17: homebridge2openluup debug: HTTP 400 Bad Request: JSON parse error
                                ronluna
                                  ronluna
                                  @crille I thought there were only two type of temperature controller (Thermostat and HeaterCooler) in homebridge/homekit but apparently I'm wrong. I also thought homebridge/homekit (depending on the device type) would force device to share the same characteristicType ... Seems like I was wrong again... so depending on the plugin being used on homebridge the author may very well define the characteristicType somewhat differently to other plugin-ins...
                                  What kind of thermostat is configured on your homebridge setup? Brand / model . Can you please share the json response when the plug-in is updating the device’s values.. similar to this:
                                  2021-03-21 07:24:20.861   luup_log:83: homebridge2openluup debug: concat_response_body 1 = {"aid":339,"iid":8,"uuid":"0000004A-0000-1000-8000-0026BB765291","type":"Thermostat","humanType":"Thermostat","serviceName":"My ecobee","serviceCharacteristics":[{"aid":339,"iid":10,"uuid":"0000000F-0000-1000-8000-0026BB765291","type":"CurrentHeatingCoolingState","serviceType":"Thermostat","serviceName":"My ecobee","description":"Current Heating Cooling State","value":0,"format":"uint8","perms":["ev","pr"],"maxValue":2,"minValue":0,"minStep":1,"canRead":true,"canWrite":false,"ev":true},{"aid":339,"iid":11,"uuid":"00000033-0000-1000-8000-0026BB765291","type":"TargetHeatingCoolingState","serviceType":"Thermostat","serviceName":"My ecobee","description":"Target Heating Cooling State","value":0,"format":"uint8","perms":["ev","pr","pw"],"maxValue":3,"minValue":0,"minStep":1,"canRead":true,"canWrite":true,"ev":true},{"aid":339,"iid":12,"uuid":"00000011-0000-1000-8000-0026BB765291","type":"CurrentTemperature","serviceType":"Thermostat","serviceName":"My ecobee","description":"Current Temperature","value":24.3667,"format":"float","perms":["ev","pr"],"unit":"celsius","maxValue":37.77777777777778,"minValue":-73.33333333333333,"minStep":0.1,"canRead":true,"canWrite":false,"ev":true},{"aid":339,"iid":13,"uuid":"00000035-0000-1000-8000-0026BB765291","type":"TargetTemperature","serviceType":"Thermostat","serviceName":"My ecobee","description":"Target Temperature","value":23.8556,"format":"float","perms":["ev","pr","pw"],"unit":"celsius","maxValue":26.666666666666664,"minValue":15.555555555555555,"minStep":0.1,"canRead":true,"canWrite":true,"ev":true},{"aid":339,"iid":14,"uuid":"00000036-0000-1000-8000-0026BB765291","type":"TemperatureDisplayUnits","serviceType":"Thermostat","serviceName":"My ecobee","description":"Temperature Display Units","value":1,"format":"uint8","perms":["ev","pr","pw"],"maxValue":1,"minValue":0,"minStep":1,"canRead":true,"canWrite":true,"ev":true}],"accessoryInformation":{"Manufacturer":"ecobee","Model":"nikeSmart","Name":"My ecobee","Serial Number":"Vera ID: 173","Firmware Revision":"0.8.3-beta.12"},"values":{"CurrentHeatingCoolingState":0,"TargetHeatingCoolingState":0,"CurrentTemperature":24.3667,"TargetTemperature":23.8556,"TemperatureDisplayUnits":1},"instance":{"name":"homebridge","username":"0E:10:83:81:C6:A5","ipAddress":"10.1.11.21","port":51706,"services":[],"connectionFailedCount":0},"uniqueId":"240d0198fc8289b3b5a77315b7e4ec132096ddbd6e6beb5e4c174a6a84908e8d"}
                                  • R ronluna
                                    @ronluna I thought so as well. That’s why I thought any device configured as a thermostat in homebridge would have the same characteristics and your plugin would support it.
                                    My “thermostat” is another homebridge plugin for MELCloud (Mitsubishi cloud for my WiFi connected inverters).
                                    Here is the json response:
                                    luup_log:17: homebridge2openluup debug: concat_response_body 1 = {"aid":60,"iid":8,"uuid":"0000004A-0000-1000-8000-0026BB765291","type":"Thermostat","humanType":"Thermostat","serviceName":"Övervåningen","serviceCharacteristics":[{"aid":60,"iid":10,"uuid":"0000000F-0000-1000-8000-0026BB765291","type":"CurrentHeatingCoolingState","serviceType":"Thermostat","serviceName":"Övervåningen","description":"Current Heating Cooling State","value":1,"format":"uint8","perms":["pr","ev"],"maxValue":2,"minValue":0,"canRead":true,"canWrite":false,"ev":true},{"aid":60,"iid":11,"uuid":"00000033-0000-1000-8000-0026BB765291","type":"TargetHeatingCoolingState","serviceType":"Thermostat","serviceName":"Övervåningen","description":"Target Heating Cooling State","value":1,"format":"uint8","perms":["pr","pw","ev"],"maxValue":3,"minValue":0,"canRead":true,"canWrite":true,"ev":true},{"aid":60,"iid":12,"uuid":"00000011-0000-1000-8000-0026BB765291","type":"CurrentTemperature","serviceType":"Thermostat","serviceName":"Övervåningen","description":"Current Temperature","value":23,"format":"float","perms":["pr","ev"],"unit":"celsius","maxValue":100,"minValue":0,"minStep":0.1,"canRead":true,"canWrite":false,"ev":true},{"aid":60,"iid":13,"uuid":"00000035-0000-1000-8000-0026BB765291","type":"TargetTemperature","serviceType":"Thermostat","serviceName":"Övervåningen","description":"Target Temperature","value":22,"format":"float","perms":["pr","pw","ev"],"unit":"celsius","maxValue":38,"minValue":10,"minStep":0.1,"canRead":true,"canWrite":true,"ev":true},{"aid":60,"iid":14,"uuid":"00000036-0000-1000-8000-0026BB765291","type":"TemperatureDisplayUnits","serviceType":"Thermostat","serviceName":"Övervåningen","description":"Temperature Display Units","value":0,"format":"uint8","perms":["pr","pw","ev"],"maxValue":1,"minValue":0,"canRead":true,"canWrite":true,"ev":true},{"aid":60,"iid":15,"uuid":"00000029-0000-1000-8000-0026BB765291","type":"RotationSpeed","serviceType":"Thermostat","serviceName":"Övervåningen","description":"Rotation Speed","value":60,"format":"float","perms":["pr","pw","ev"],"unit":"percentage","maxValue":100,"minValue":0,"minStep":1,"canRead":true,"canWrite":true,"ev":true},{"aid":60,"iid":16,"uuid":"0000006C-0000-1000-8000-0026BB765291","type":"CurrentHorizontalTiltAngle","serviceType":"Thermostat","serviceName":"Övervåningen","description":"Current Horizontal Tilt Angle","value":0,"format":"int","perms":["pr","ev"],"unit":"arcdegrees","maxValue":90,"minValue":-90,"minStep":1,"canRead":true,"canWrite":false,"ev":true},{"aid":60,"iid":17,"uuid":"0000007B-0000-1000-8000-0026BB765291","type":"TargetHorizontalTiltAngle","serviceType":"Thermostat","serviceName":"Övervåningen","description":"Target Horizontal Tilt Angle","value":0,"format":"int","perms":["pr","pw","ev"],"unit":"arcdegrees","maxValue":90,"minValue":-90,"minStep":1,"canRead":true,"canWrite":true,"ev":true},{"aid":60,"iid":18,"uuid":"0000006E-0000-1000-8000-0026BB765291","type":"CurrentVerticalTiltAngle","serviceType":"Thermostat","serviceName":"Övervåningen","description":"Current Vertical Tilt Angle","value":-45,"format":"int","perms":["pr","ev"],"unit":"arcdegrees","maxValue":90,"minValue":-90,"minStep":1,"canRead":true,"canWrite":false,"ev":true},{"aid":60,"iid":19,"uuid":"0000007D-0000-1000-8000-0026BB765291","type":"TargetVerticalTiltAngle","serviceType":"Thermostat","serviceName":"Övervåningen","description":"Target Vertical Tilt Angle","value":-45,"format":"int","perms":["pr","pw","ev"],"unit":"arcdegrees","maxValue":90,"minValue":-90,"minStep":1,"canRead":true,"canWrite":true,"ev":true}],"accessoryInformation":{"Manufacturer":"Mitsubishi","Model":"Default-Model","Name":"Övervåningen","Serial Number":"1805118279","Firmware Revision":"0.3.4"},"values":{"CurrentHeatingCoolingState":0,"TargetHeatingCoolingState":0,"CurrentTemperature":0,"TargetTemperature":10,"TemperatureDisplayUnits":0,"RotationSpeed":0,"CurrentHorizontalTiltAngle":-90,"TargetHorizontalTiltAngle":-90,"CurrentVerticalTiltAngle":-90,"TargetVerticalTiltAngle":-90},"instance":{"name":"homebridge","username":"CC:22:3D:E3:CE:43","ipAddress":"127.0.0.1","port":51826,"services":[],"connectionFailedCount":0},"uniqueId":"8f37721c51dc9fd6b15aad7024d6a8460038b1ee7e6fb23c732f1abc5bcfb8fd"}
                                      ronluna
                                      @crille Please test the latest commit on github.
                                      • R ronluna
                                        @ronluna Sorry, but it does not work.
                                        I believe the MELCloud plugin only accepts "TargetTemperature" for changing Setpoint
                                        and not
                                        luup.variable_set:: 18.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint was: 22 now: 18 #hooks:0
                                        This is only if you want to support the MELCloud provisioned thermostat, otherwise do not put to much energy in to it.
                                        For me it would be at great way to control my temperature triggered by house modes since there is no MELCloud plugin for openLuup.
                                          and not
                                          ronluna
                                          @crille said in Homebridge to Openluup:
                                          TargetTemperature
                                          That's characteristicType the plugin is trying to set for your plugin. Can your share what are the Manufacturer, Model and Type variables set to?
                                            107.0k
                                          • Integrations and 'Loaded'
