  3. differentiation
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
differentiation
12 Posts 3 Posters 3.8k Views 3 Watching
    Hi prophead,
    I think you understand correctly.
    The best integration server, supporting the widest range of APIs is actually home assistant. Being open-source and having an enormous amount of developers and maintainers, I don’t actually foresee any commercial solution catching up to it in the short term.
    openLuup in terms of integration offers a lot too but not nearly to the same degree as Home Assistant. openLuup benefits from being able to run all of the plugins developed for vera for years. What it does have though is two main advantages: The automation interface, and scripting, what you call the front end, is far easier and very powerful with the use of lua. In that respect, many Home Assistant users end up running also Node Red which offers this similar advantage compensating for this weaker area of home assistant. The other advantage is, if you come from vera, is the ease of migration and familiarity... you can have all of your scenes and plugins pretty much seamlessly transferred over and now with the z-way bridge, you can also transfer the devices without including/excluding.
    Now on the back end, the wireless stack and device manager, z-way and HomeSeer are both far ahead of the seemingly abandoned vera on the z-way side. On Zigbee almost anything is better than vera as it was never really invested in it. After trying pretty much every platform, I found z-way to be the most advanced, most flexible and most powerful zwave manager. It’s weakness is in the front end which is why I use openLuup there and have also bonded Home Assistant to openLuup manually to add all of the Home assistant integrations to openLuup while retaining and expanding my former vera codes and automation.
    • propheadP Offline
      propheadP Offline
      prophead
      Thanks for this thoughtful and informative reply, it’s really helpful.
      What do you have in HA thats not in OL?
        I have a lot of integrations:
        BMW Connected drive (Car location, status, AC, lock control)
        Eight Sleep
        Brother Printers as sensors
        Xiaomi robot and air filters
        Facial recognitions on all my IPcams.
        Foobot
        I also use it as my zigbee bridge (using the vera's radio chip)
        unifi POE switches so I can power cycle everything POE controlled.
        All of these are bridged back into virtual devices in OL. OL remains the master controller and HA is just a device bridge. It either triggers scenes, updates device variables on OL or executes device actions commanded by OL.
        DesTD 1 Reply Last reply
        • propheadP Offline
          propheadP Offline
          prophead
          I have to ask; brother printers as sensors?
            Yes:
              Eight Sleep
              Foobot
              DesTD Offline
              DesTD Offline
              DesT
              @rafale77 said in differentiation:
              Using .... ?
                You have a couple of local options:
                Removed integration
                Removed integration
                The integration you requested has been removed
                Removed integration
                Removed integration
                And there are additional ones cloud based, one of them is:
                Microsoft Face Identify
                Instructions on how to integrate Microsoft Face Identify into Home Assistant.
                You will notice from the version introduced for these components that these are 2-3 or even 4 year old capabilities so forgive me for chuckling at what is going on in the "other place".
                  Just to show you how it looks like on the ALTUI/OpenLuup Dashboard.
                  And compare to the top screen of HA.
                  • DesTD Offline
                    DesTD Offline
                    DesT
                    I'm having 6 outdoor IPCam and think to take the one you proposed for the "ring" at the front door!
                    Right now, all of them are just connect in Synology "Surveillance" but I would like to have something more "intelligent" for sure!
                    • propheadP Offline
                      propheadP Offline
                      prophead
                      Can I run both HAss and openluup off of the same zway server?
                        You can. The API is not exclusive.
                          156.0k
