  2. Hardware
  3. Vera
  4. Vera Alexa Plugin 7.32
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
119 Posts 7 Posters 73.2k Views 5 Watching
    @therealdb said in Vera Alexa Plugin 7.32:
    I've fixed it.
    Thanks, but -- vexingly, annoyingly, perplexingly -- when I execute that code my Alexa still just says: "Domain".
    That was with "UseAnnouncements" set to 0.
    So I set "UseAnnouncements" to 1, restarted the Luup engine, did a hard refresh on the browser, and tried again.
    This time, I get: "Sorry, I'm having trouble accessing the ??? ??? right now." (same error message as I got before during testing)
    With "debug"=1, I captured this in Vera's LuaPnP log, but don't know what most of it means...
    08	03/26/21 10:15:28.984	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunLua <0x701dc520>
    08	03/26/21 10:15:28.985	JobHandler_LuaUPnP::HandleActionRequest argument post_data=id=lu_action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunLua&Code=function%20say(text%2C%20r%2C%20volume%2C%20zone)%0A%20%20luup.call_action(%22urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1%22%2C%20%0A%20%20%20%22Say%22%2C%0A%20%20%7B%0A%20%20%20Text%20%3D%20%27%3Camazon%3Adomain%20name%3D%22conversational%22%3E%27%20..%20text%20..%20%27%3C%2Famazon%3Adomain%3E%27%2C%0A%20%20%20Repeat%3D%20r%20or%201%2C%0A%20%20%20Volume%3Dvolume%20or%2050%2C%20%0A%20%20%20GroupZones%3D%20zone%0A%7D%2C%20345)%0Aend%0A%20%0Asay(%27I%20really%20didn%E2%80%99t%20know%20how%20this%20morning%20was%20going%20to%20start.%20And%20if%20I%20had%20known%2C%20I%20think%20I%20might%20have%20just%20stayed%20in%20bed.%27%2C%201%2C%2050%2C%20%27Living%20Room%27) <0x701dc520>
    08	03/26/21 10:15:28.985	JobHandler_LuaUPnP::HandleActionRequest argument id=lu_action <0x701dc520>
    08	03/26/21 10:15:28.985	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x701dc520>
    08	03/26/21 10:15:28.985	JobHandler_LuaUPnP::HandleActionRequest argument action=RunLua <0x701dc520>
    08	03/26/21 10:15:28.985	JobHandler_LuaUPnP::HandleActionRequest argument Code=function say(text, r, volume, zone)
      luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1",
       "Say",
       Text = '<amazon:domain name="conversational">' .. text .. '</amazon:domain>',
       Repeat= r or 1,
       Volume=volume or 50,
       GroupZones= zone
    }, 345)
    say('I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.', 1, 50, 'Living Room') <0x701dc520>
    08	03/26/21 10:15:28.986	JobHandler_LuaUPnP::HandleActionRequest device: 345 service: urn:bochicchio-com:serviceId:VeraAlexa1 action: Say <0x701dc520>
    08	03/26/21 10:15:28.987	JobHandler_LuaUPnP::HandleActionRequest argument GroupZones=Living Room <0x701dc520>
    08	03/26/21 10:15:28.987	JobHandler_LuaUPnP::HandleActionRequest argument Text=<amazon:domain name="conversational">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> <0x701dc520>
    08	03/26/21 10:15:28.987	JobHandler_LuaUPnP::HandleActionRequest argument Repeat=1 <0x701dc520>
    08	03/26/21 10:15:28.987	JobHandler_LuaUPnP::HandleActionRequest argument Volume=50 <0x701dc520>
    50	03/26/21 10:15:28.988	luup_log:345: VeraAlexa[0.92@345]:addToQueue({ Volume="50", Text="<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain>", Repeat="1", GroupZones="Living Room" }) <0x701dc520>
    50	03/26/21 10:15:28.989	luup_log:345: VeraAlexa[0.92@345](addToQueue@234):addToQueue(2): 0 - true <0x701dc520>
    50	03/26/21 10:15:28.990	luup_log:345: VeraAlexa[0.92@345](addToQueue@251):addToQueue(3): 1 <0x701dc520>
    50	03/26/21 10:15:28.990	luup_log:345: VeraAlexa[0.92@345](addToQueue@254):addToQueue(4): playing <0x701dc520>
    50	03/26/21 10:15:28.991	luup_log:345: VeraAlexa[0.92@345](checkQueue@206):checkQueue: 1 in queue <0x701dc520>
    50	03/26/21 10:15:28.991	luup_log:345: VeraAlexa[0.92@345](checkQueue@214):checkQueue: play next <0x701dc520>
    50	03/26/21 10:15:28.992	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",345) old value "" <0x701dc520>
    50	03/26/21 10:15:28.993	luup_log:345: VeraAlexa[0.92@345](sayTTS@323):Executing command [TTS]: "-e speak:'<s><amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain></s><break time=\"0s\" />' -d \"Living Room\"" <0x701dc520>
    06	03/26/21 10:15:31.164	Device_Variable::m_szValue_set device: 257 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: KWH was: 4.5700 now: 4.5700 #hooks: 0 upnp: 0 skip: 0 v:0xb71548/NONE duplicate:1 <0x7701d520>
    06	03/26/21 10:15:31.164	Device_Variable::m_szValue_set device: 257 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: KWHReading was: 1616771413 now: 1616771731 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x7701d520>
    50	03/26/21 10:15:31.563	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:micasaverde-com:serviceId:HaDevice1","CommFailure","0",345) old value "0" <0x701dc520>
    50	03/26/21 10:15:31.564	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","LatestResponse","sending cmd:speak:<s><amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain></s><break time=\"0s\" /> to dev:Living_Room type:A3NPD82ABCPIDP serial:d889f9dcc0ab4085bcb59494f81c3726 customerid:A3SL3Z0HELH3YG",345) old value "sending cmd:speak:<s><amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain></s><break time=\"0s\" /> to dev:Living_Room type:A3NPD82ABCPIDP serial:d889f9dcc0ab4085bcb59494f81c3726 customerid:A3SL3Z0HELH3YG" <0x701dc520>
    50	03/26/21 10:15:31.564	luup_log:345: VeraAlexa[0.92@345](@279):Response from Alexa.sh: "sending cmd:speak:<s><amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain></s><break time=\"0s\" /> to dev:Living_Room type:A3NPD82ABCPIDP serial:d889f9dcc0ab4085bcb59494f81c3726 customerid:A3SL3Z0HELH3YG" <0x701dc520>
    50	03/26/21 10:15:31.565	luup_log:345: VeraAlexa[0.92@345](sayTTS@337):Queue will be checked again in "3" secs <0x701dc520>
    08	03/26/21 10:15:31.662	JobHandler_LuaUPnP::HandleActionRequest device: 322 service: urn:micasaverde-com:serviceId:Sonos1 action: NotifyRenderingChange <0x6fbdc520>
    08	03/26/21 10:15:31.662	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=322 <0x6fbdc520>
    08	03/26/21 10:15:31.662	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:Sonos1 <0x6fbdc520>
    08	03/26/21 10:15:31.663	JobHandler_LuaUPnP::HandleActionRequest argument action=NotifyRenderingChange <0x6fbdc520>
    08	03/26/21 10:15:31.663	JobHandler_LuaUPnP::HandleActionRequest argument LastChange=<Event xmlns="urn:schemas-upnp-org:metadata-1-0/RCS/"><InstanceID val="0"><Volume channel="Master" val="50"/><Volume channel="LF" val="100"/><Volume channel="RF" val="100"/></InstanceID></Event> <0x6fbdc520>
    08	03/26/21 10:15:31.663	JobHandler_LuaUPnP::HandleActionRequest argument sid=uuid:RINCON_48A6B8431C7701400_sub0000000321 <0x6fbdc520>
    04	03/26/21 10:15:31.668	<Job ID="17" Name="" Device="322" Created="2021-03-26 10:15:31" Started="2021-03-26 10:15:31" Completed="2021-03-26 10:15:31" Duration="0.4141000" Runtime="0.969000" Status="Successful" LastNote=""/> <0x77bf2320>
    02	03/26/21 10:15:32.100	ZWaveJobHandler::AlarmCallback skipping check because of jobs <0x7701d520>
    08	03/26/21 10:15:32.574	JobHandler_LuaUPnP::HandleActionRequest device: 322 service: urn:micasaverde-com:serviceId:Sonos1 action: NotifyZoneGroupTopologyChange <0x6f3dc520>
    08	03/26/21 10:15:32.575	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=322 <0x6f3dc520>
    08	03/26/21 10:15:32.575	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:Sonos1 <0x6f3dc520>
    08	03/26/21 10:15:32.575	JobHandler_LuaUPnP::HandleActionRequest argument action=NotifyZoneGroupTopologyChange <0x6f3dc520>
    08	03/26/21 10:15:32.575	JobHandler_LuaUPnP::HandleActionRequest argument ZoneGroupState=<ZoneGroupState><ZoneGroups><ZoneGroup Coordinator="RINCON_48A6B8431C7701400" ID="RINCON_48A6B8431C7701400:2371207342"><ZoneGroupMember UUID="RINCON_48A6B8431C7701400" Location="http://192.168.86.21:1400/xml/device_description.xml" ZoneName="Living Room" Icon="x-rincon-roomicon:living" Configuration="1" SoftwareVersion="62.1-86220" SWGen="2" MinCompatibleVersion="61.0-00000" LegacyCompatibleVersion="58.0-00000" BootSeq="59" TVConfigurationError="0" HdmiCecAvailable="1" WirelessMode="1" WirelessLeafOnly="0" HasConfiguredSSID="1" ChannelFreq="2437" BehindWifiExtender="0" WifiEnabled="1" Orientation="0" RoomCalibrationState="4" SecureRegState="3" VoiceConfigState="2" MicEnabled="1" AirPlayEnabled="1" IdleState="0" MoreInfo=""/></ZoneGroup></ZoneGroups><VanishedDevices></VanishedDevices></ZoneGroupState> <0x6f3dc520>
    08	03/26/21 10:15:32.576	JobHandler_LuaUPnP::HandleActionRequest argument sid=uuid:RINCON_48A6B8431C7701400_sub0000000322 <0x6f3dc520>
    04	03/26/21 10:15:32.582	<Job ID="18" Name="" Device="322" Created="2021-03-26 10:15:32" Started="2021-03-26 10:15:32" Completed="2021-03-26 10:15:32" Duration="0.4675000" Runtime="0.4284000" Status="Successful" LastNote=""/> <0x77bf2320>
    And this capture from the log with "UseAnnouncements" set back to 0:
    01	03/26/21 10:27:44.148	LuaInterface::CallFunction_Timer device 340 refreshCache took 10 seconds <0x73c1d520>
    01	03/26/21 10:27:44.154	LuaInterface::CallFunction_Timer device 336 refreshCache took 10 seconds <0x73e1d520>
    01	03/26/21 10:27:53.205	Mongoose mg_read start (null) <0x701dc520>
    01	03/26/21 10:27:53.205	Mongoose mg_read middle (null) 768 <0x701dc520>
    01	03/26/21 10:27:53.205	Mongoose mg_read end (null) 768 <0x701dc520>
    01	03/26/21 10:27:53.206	Mongoose mg_read after pull (null) 0 <0x701dc520>
    08	03/26/21 10:27:53.206	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunLua <0x701dc520>
    08	03/26/21 10:27:53.206	JobHandler_LuaUPnP::HandleActionRequest argument post_data=id=lu_action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunLua&Code=function%20say(text%2C%20r%2C%20volume%2C%20zone)%0A%20%20luup.call_action(%22urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1%22%2C%20%0A%20%20%20%22Say%22%2C%0A%20%20%7B%0A%20%20%20Text%20%3D%20%27%3Camazon%3Adomain%20name%3D%22conversational%22%3E%27%20..%20text%20..%20%27%3C%2Famazon%3Adomain%3E%27%2C%0A%20%20%20Repeat%3D%20r%20or%201%2C%0A%20%20%20Volume%3Dvolume%20or%2050%2C%20%0A%20%20%20GroupZones%3D%20zone%0A%7D%2C%20345)%0Aend%0A%20%0Asay(%27I%20really%20didn%E2%80%99t%20know%20how%20this%20morning%20was%20going%20to%20start.%20And%20if%20I%20had%20known%2C%20I%20think%20I%20might%20have%20just%20stayed%20in%20bed.%27%2C%201%2C%2050%2C%20%27Living%20Room%27) <0x701dc520>
    08	03/26/21 10:27:53.207	JobHandler_LuaUPnP::HandleActionRequest argument id=lu_action <0x701dc520>
    08	03/26/21 10:27:53.207	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x701dc520>
    08	03/26/21 10:27:53.207	JobHandler_LuaUPnP::HandleActionRequest argument action=RunLua <0x701dc520>
    08	03/26/21 10:27:53.207	JobHandler_LuaUPnP::HandleActionRequest argument Code=function say(text, r, volume, zone)
       "Say",
       Repeat= r or 1,
       GroupZones= zone
    }, 345)
    08	03/26/21 10:27:53.209	JobHandler_LuaUPnP::HandleActionRequest device: 345 service: urn:bochicchio-com:serviceId:VeraAlexa1 action: Say <0x701dc520>
    08	03/26/21 10:27:53.209	JobHandler_LuaUPnP::HandleActionRequest argument GroupZones=Living Room <0x701dc520>
    08	03/26/21 10:27:53.209	JobHandler_LuaUPnP::HandleActionRequest argument Text=<amazon:domain name="conversational">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> <0x701dc520>
    08	03/26/21 10:27:53.210	JobHandler_LuaUPnP::HandleActionRequest argument Repeat=1 <0x701dc520>
    08	03/26/21 10:27:53.210	JobHandler_LuaUPnP::HandleActionRequest argument Volume=50 <0x701dc520>
    50	03/26/21 10:27:53.211	luup_log:345: VeraAlexa[0.92@345]:addToQueue({ Volume="50", Text="<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain>", Repeat="1", GroupZones="Living Room" }) <0x701dc520>
    50	03/26/21 10:27:53.211	luup_log:345: VeraAlexa[0.92@345](addToQueue@234):addToQueue(2): 0 - true <0x701dc520>
    50	03/26/21 10:27:53.212	luup_log:345: VeraAlexa[0.92@345](addToQueue@251):addToQueue(3): 1 <0x701dc520>
    50	03/26/21 10:27:53.213	luup_log:345: VeraAlexa[0.92@345](addToQueue@254):addToQueue(4): playing <0x701dc520>
    50	03/26/21 10:27:53.213	luup_log:345: VeraAlexa[0.92@345](checkQueue@206):checkQueue: 1 in queue <0x701dc520>
    50	03/26/21 10:27:53.214	luup_log:345: VeraAlexa[0.92@345](checkQueue@214):checkQueue: play next <0x701dc520>
    50	03/26/21 10:27:53.215	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",345) old value "" <0x701dc520>
    50	03/26/21 10:27:53.215	luup_log:345: VeraAlexa[0.92@345](sayTTS@323):Executing command [TTS]: "-e speak:'<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain>' -d \"Living Room\"" <0x701dc520>
    50	03/26/21 10:27:55.712	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:micasaverde-com:serviceId:HaDevice1","CommFailure","0",345) old value "0" <0x701dc520>
    50	03/26/21 10:27:55.713	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","LatestResponse","sending cmd:speak:<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> to dev:Living_Room type:A3NPD82ABCPIDP serial:d889f9dcc0ab4085bcb59494f81c3726 customerid:A3SL3Z0HELH3YG",345) old value "sending cmd:speak:<s><amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain></s><break time=\"0s\" /> to dev:Living_Room type:A3NPD82ABCPIDP serial:d889f9dcc0ab4085bcb59494f81c3726 customerid:A3SL3Z0HELH3YG" <0x701dc520>
    06	03/26/21 10:27:55.713	Device_Variable::m_szValue_set device: 345 service: urn:bochicchio-com:serviceId:VeraAlexa1 variable: LatestResponse was: sending cmd:speak:<s><amazon:domain name="conversational">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain></s><break time="0s" /> to dev:Living_Room type:A3NPD82ABCPIDP serial:d889f9dcc0ab4085bcb59494f81c3726 customerid:A3SL3Z0HELH3YG now: sending cmd:speak:<amazon:domain name="conversational">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> to dev:Living_Room type:A3NPD82ABCPIDP serial:d889f9dcc0ab4085bcb59494f81c3726 customerid:A3SL3Z0HELH3YG #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x701dc520>
    50	03/26/21 10:27:55.715	luup_log:345: VeraAlexa[0.92@345](@279):Response from Alexa.sh: "sending cmd:speak:<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> to dev:Living_Room type:A3NPD82ABCPIDP serial:d889f9dcc0ab4085bcb59494f81c3726 customerid:A3SL3Z0HELH3YG" <0x701dc520>
    50	03/26/21 10:27:55.717	luup_log:345: VeraAlexa[0.92@345](sayTTS@337):Queue will be checked again in 11.726 secs <0x701dc520>
    08	03/26/21 10:27:55.821	JobHandler_LuaUPnP::HandleActionRequest device: 322 service: urn:micasaverde-com:serviceId:Sonos1 action: NotifyRenderingChange <0x6fbdc520>
    08	03/26/21 10:27:55.821	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=322 <0x6fbdc520>
    08	03/26/21 10:27:55.821	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:Sonos1 <0x6fbdc520>
    08	03/26/21 10:27:55.821	JobHandler_LuaUPnP::HandleActionRequest argument action=NotifyRenderingChange <0x6fbdc520>
    08	03/26/21 10:27:55.821	JobHandler_LuaUPnP::HandleActionRequest argument LastChange=<Event xmlns="urn:schemas-upnp-org:metadata-1-0/RCS/"><InstanceID val="0"><Volume channel="Master" val="50"/><Volume channel="LF" val="100"/><Volume channel="RF" val="100"/></InstanceID></Event> <0x6fbdc520>
    08	03/26/21 10:27:55.822	JobHandler_LuaUPnP::HandleActionRequest argument sid=uuid:RINCON_48A6B8431C7701400_sub0000000321 <0x6fbdc520>
    04	03/26/21 10:27:55.826	<Job ID="43" Name="" Device="322" Created="2021-03-26 10:27:55" Started="2021-03-26 10:27:55" Completed="2021-03-26 10:27:55" Duration="0.3272000" Runtime="0.1304000" Status="Successful" LastNote=""/> <0x77bf2320>
    08	03/26/21 10:27:56.584	JobHandler_LuaUPnP::HandleActionRequest device: 322 service: urn:micasaverde-com:serviceId:Sonos1 action: NotifyZoneGroupTopologyChange <0x703dc520>
    08	03/26/21 10:27:56.584	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=322 <0x703dc520>
    08	03/26/21 10:27:56.584	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:Sonos1 <0x703dc520>
    08	03/26/21 10:27:56.585	JobHandler_LuaUPnP::HandleActionRequest argument action=NotifyZoneGroupTopologyChange <0x703dc520>
    @librasun it's something about your device. Is it an Amazon Echo, or something else?
      #94
      The test unit I tried (and which serves as the Default output device for VeraAlexa) is indeed a Sonos Beam with Alexa built in. However, it has not (yet) mattered which device I try with, Echo, Dot, etc., nor have things improved when I refer to the default unit as "Living Room" or "Libra's Sonos" (both entries appear in Amazon's enumeration of devices on my account).
      Nor have things improved if I substitute the SONOS service in place of the BOCHICCHIO one.
        FWIW I get total silence. I'm not that bothered but just as a data point
          wrote on last edited by Pabla
          #96
          Those codes that @therealdb posted worked fine for me oddly enough, I don't know how they weren't working earlier.
          Edit: I have only tested with my Echo not any of my Sonos devices yet
            I ran his updated code again twice - once with "UseAnnouncements" set to 0, once set to 1 - targeting my Echo device ('Kitchen') and received silence both times. Kept DebugMode = 1 throughout, but don't see any overt errors.
            But I AM troubled by the weird red text mentioning "MONGOOSE" always occurring the millisecond before my Lua code runs... anyone know why it's ALWAYS there?
            03/26/21 13:24:43.474	Mongoose mg_read start (null) <0x6f5c2520>
            01	03/26/21 13:24:43.475	Mongoose mg_read middle (null) 762 <0x6f5c2520>
            01	03/26/21 13:24:43.475	Mongoose mg_read end (null) 762 <0x6f5c2520>
            01	03/26/21 13:24:43.475	Mongoose mg_read after pull (null) 0 <0x6f5c2520>
            08	03/26/21 13:24:43.476	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunLua <0x6f5c2520>
            08	03/26/21 13:24:43.476	JobHandler_LuaUPnP::HandleActionRequest argument post_data=id=lu_action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunLua&Code=function%20say(text%2C%20r%2C%20volume%2C%20zone)%0A%20%20luup.call_action(%22urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1%22%2C%20%0A%20%20%20%22Say%22%2C%0A%20%20%7B%0A%20%20%20Text%20%3D%20%27%3Camazon%3Adomain%20name%3D%22conversational%22%3E%27%20..%20text%20..%20%27%3C%2Famazon%3Adomain%3E%27%2C%0A%20%20%20Repeat%3D%20r%20or%201%2C%0A%20%20%20Volume%3Dvolume%20or%2050%2C%20%0A%20%20%20GroupZones%3D%20zone%0A%7D%2C%20345)%0Aend%0A%20%0Asay(%27I%20really%20didn%E2%80%99t%20know%20how%20this%20morning%20was%20going%20to%20start.%20And%20if%20I%20had%20known%2C%20I%20think%20I%20might%20have%20just%20stayed%20in%20bed.%27%2C%201%2C%2050%2C%20%27Kitchen%27) <0x6f5c2520>
            08	03/26/21 13:24:43.476	JobHandler_LuaUPnP::HandleActionRequest argument id=lu_action <0x6f5c2520>
            08	03/26/21 13:24:43.476	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x6f5c2520>
            08	03/26/21 13:24:43.477	JobHandler_LuaUPnP::HandleActionRequest argument action=RunLua <0x6f5c2520>
            08	03/26/21 13:24:43.477	JobHandler_LuaUPnP::HandleActionRequest argument Code=function say(text, r, volume, zone)
               "Say",
               Repeat= r or 1,
               GroupZones= zone
            }, 345)
            say('I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.', 1, 50, 'Kitchen') <0x6f5c2520>
            08	03/26/21 13:24:43.479	JobHandler_LuaUPnP::HandleActionRequest device: 345 service: urn:bochicchio-com:serviceId:VeraAlexa1 action: Say <0x6f5c2520>
            08	03/26/21 13:24:43.480	JobHandler_LuaUPnP::HandleActionRequest argument GroupZones=Kitchen <0x6f5c2520>
            08	03/26/21 13:24:43.480	JobHandler_LuaUPnP::HandleActionRequest argument Text=<amazon:domain name="conversational">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> <0x6f5c2520>
            08	03/26/21 13:24:43.480	JobHandler_LuaUPnP::HandleActionRequest argument Repeat=1 <0x6f5c2520>
            08	03/26/21 13:24:43.480	JobHandler_LuaUPnP::HandleActionRequest argument Volume=50 <0x6f5c2520>
            50	03/26/21 13:24:43.481	luup_log:345: VeraAlexa[0.92@345]:addToQueue({ Volume="50", Text="<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain>", Repeat="1", GroupZones="Kitchen" }) <0x6f5c2520>
            50	03/26/21 13:24:43.482	luup_log:345: VeraAlexa[0.92@345](addToQueue@234):addToQueue(2): 0 - true <0x6f5c2520>
            50	03/26/21 13:24:43.483	luup_log:345: VeraAlexa[0.92@345](addToQueue@251):addToQueue(3): 1 <0x6f5c2520>
            50	03/26/21 13:24:43.483	luup_log:345: VeraAlexa[0.92@345](addToQueue@254):addToQueue(4): playing <0x6f5c2520>
            50	03/26/21 13:24:43.484	luup_log:345: VeraAlexa[0.92@345](checkQueue@206):checkQueue: 1 in queue <0x6f5c2520>
            50	03/26/21 13:24:43.485	luup_log:345: VeraAlexa[0.92@345](checkQueue@214):checkQueue: play next <0x6f5c2520>
            50	03/26/21 13:24:43.486	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",345) old value "" <0x6f5c2520>
            50	03/26/21 13:24:43.487	luup_log:345: VeraAlexa[0.92@345](sayTTS@323):Executing command [TTS]: "-e speak:'<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain>' -d \"Kitchen\"" <0x6f5c2520>
            50	03/26/21 13:24:45.930	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:micasaverde-com:serviceId:HaDevice1","CommFailure","0",345) old value "0" <0x6f5c2520>
            50	03/26/21 13:24:45.931	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","LatestResponse","sending cmd:speak:<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> to dev:Kitchen type:A1MPSLFC7L5AFK serial:2f69293cc2c749f6854ad6c5b41aef43 customerid:A3SL3Z0HELH3YG",345) old value "sending cmd:speak:<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> to dev:Kitchen type:A1MPSLFC7L5AFK serial:2f69293cc2c749f6854ad6c5b41aef43 customerid:A3SL3Z0HELH3YG" <0x6f5c2520>
            50	03/26/21 13:24:45.932	luup_log:345: VeraAlexa[0.92@345](@279):Response from Alexa.sh: "sending cmd:speak:<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> to dev:Kitchen type:A1MPSLFC7L5AFK serial:2f69293cc2c749f6854ad6c5b41aef43 customerid:A3SL3Z0HELH3YG" <0x6f5c2520>
            50	03/26/21 13:24:45.933	luup_log:345: VeraAlexa[0.92@345](sayTTS@337):Queue will be checked again in 11.726 secs <0x6f5c2520>
            50	03/26/21 13:24:56.101	luup_log:345: VeraAlexa[0.92@345](checkQueue@206):checkQueue: 0 in queue <0x73a03520>
            50	03/26/21 13:24:56.102	luup_log:345: VeraAlexa[0.92@345](checkQueue@210):checkQueue: queue is empty <0x73a03520>
            PablaP therealdbT 2 Replies Last reply
                 "Say",
                 Repeat= r or 1,
                 GroupZones= zone
              }, 345)
              @librasun Instead of using the Zone names have you tried inputting the Echo's name in the GroupZone argument instead? ie if its called Kitchen Dot or whatever.
                   "Say",
                   Repeat= r or 1,
                   GroupZones= zone
                }, 345)
                #99
                @librasun said in Vera Alexa Plugin 7.32:
                It’s a fix they did in 7.32. No worries.
                As for the echo remaining silent, open l_*.lua and set devmode variable to 1, then reload luup. It will be verbose during logging, posting the entire sh command. You could try to capture it and run directly via ssh, to see the complete response.
                  #100
                    Vera beta, not VeraAlexa I assume?
                    So glad I stopped with it! There's so much I should do with OpenLuup but I lack both the imagination and the skill, but thanks to all on here, have a rock solid system!
                    PablaP 1 Reply Last reply
                      @catmanv2 ha whoops didn’t even check I posted in the correct thread.
                        This still is hacky, because it's based on unsupported feature, but me and many others have it running since 3+ years. The point is to
                        • ensure you could get a cookie. If not, the best thing to do is to install on a pi or similar and use via oath tool and openluup
                        • use exact names for devices, because it's case sensitive
                        • avoid groups, unless you have announcements enabled
                        • avoid complex voices, unless you have announcements enabled
                        • try with debugmode set to 1 and looking at live logs
                        I'm always open to PRs for docs and a UI, if anyone wants to contribute. I've not invested so much into a proper UI because I still think it's not really necessary, but it doesn't mean that one of you could not step in and do it 😁
                        #103
                        @therealdb Has the 'runroutine' action been deprecated?
                        I just tried sending:
                          "RunRoutine",
                          {RoutineName="Time for Cooking", GroupZones="Living Room"}, 345)
                        and got back this error:
                        ERROR: unknown command "automation:Time for Cooking"!
                        ...along with all the possible valid options...
                        /storage/alexa/alexa_remote_control_plain.sh [-d <device>|ALL] -e <pause|play|next|prev|fwd|rwd|shuffle|repeat|vol:<0-100>> |           -b [list|<"AA:BB:CC:DD:EE:FF">] | -q | -n | -r <"station name"|stationid> |           -s <trackID|'Artist' 'Album'> | -t <ASIN> | -u <seedID> | -v <queueID> | -w <playlistId> |           -a | -m <multiroom_device> [device_1 .. device_X] | -lastalexa | -l | -h    -e : run command, additional SEQUENCECMDs:         weather,traffic,flashbriefing,goodmorning,singasong,tellstory,         speak:'<text>',sound:<soundeffect_name>,         textcommand:'<anything you would otherwise say to Alexa>'    -b : connect/disconnect/list bluetooth device    -q : query queue    -n : query notifications    -r : play tunein radio    -s : play library track/library album    -t : play Prime playlist    -u : play Prime station    -v : play Prime historical queue    -w : play library playlist    -a : list available devices    -m : delete multiroom and/or create new multiroom containing devices    -lastalexa : print serial number that received the last voice command    -login : Logs in, without further command    -l : logoff    -h : help
                        In brief, I see no reference (except in the ReadMe back at GitHub) to the 'RunRoutine' action, neither does trying to execute a routine through the 'textcommand' method. Any suggestions?
                            "RunRoutine",
                          @librasun routine is a shortcut for -e automation:'ABC'.
                          In my experience, no space will work better, and sometimes you'll have to replace with _. ie 'Time_for_Cooking'
                          I'm using routines daily, to trigger things (ie, when the alarm is off, when we are going to bed to read my calendar, weather, and house status via a virtual device on HA-bridge, etc) and it's working no problem since day 1.
                            I'll gladly give that a whirl, thanks again. Sorry to always take up your time with such mundane things like this!!
                              @librasun no worries, I’m happy to help 😉
                                #107
                                Sadly, not a single time has either version ("RunRoutine" or "-e automation:") of this construct worked. It always, always claims it's an unknown command (as I shared earlier). I've used precisely the syntax from the docs, and this thread, and only those. Makes me wonder what the heck is going on. 😕
                                About to resume giving up. My only hope at this juncture was to have Vera kick off an Alexa routine. She can speak, start (non-routine) commands, make music, give the weather, etc. But not this one thing. Argh.
                                  @librasun post your variables, minus the username and password. Let’s see how it’s configured.
                                    Here ya go:
                                    device #345
                                    DebugMode
                                    BinPath
                                    /storage/alexa
                                    Username
                                    xxxxxxxxxxxx
                                    Password
                                    xxxxxxxxxxxx
                                    DefaultEcho
                                    Living Room
                                    DefaultVolume
                                    50
                                    AnnouncementVolume
                                    50
                                    Language
                                    en-us
                                    AlexaHost
                                    pitangui.amazon.com
                                    AmazonHost
                                    amazon.com
                                    UseAnnoucements
                                    DefaultBreak
                                    OneTimePassCode
                                    CommFailure
                                    CurrentVersion
                                    0.92
                                    LatestResponse
                                    ERROR: unknown command "automation:Time_for_Cooking"! /storage/alexa/alexa_remote_control_plain.sh [-d
                                    Configured
                                      Oddly there is a bugle_03 and that doesn't work either
                                      Nor 01 or 02 and they are in exactly the same format.
                                      @catmanv2 said in Vera Alexa Plugin 7.32:
                                      Check out the part of this documentation that describes:
                                      "Unfortunately, you have to try out the possible sound library entries . Of the four possible trumpet sounds, only the one shown above works, for example. You can see what sounds there are when you add "tones" to a routine."
                                        #111
                                        @therealdb somehow, on my own, I unearthed an update to alexa_remote_control_plain.sh (v0.17c -- I had been using v0.17a (now safely backed up!) until today), and it seems one step closer to honoring the RunRoutine verb. At least it doesn't throw errors in the Log or in the Variables section. Still total silence, though!
                                        Here's how it looks in the LuaUPnP log:
                                        08	04/15/21 18:31:59.634	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunLua <0x6e6ec520>
                                        08	04/15/21 18:31:59.634	JobHandler_LuaUPnP::HandleActionRequest argument Code=luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1", "RunRoutine", {RoutineName="Time for Cooking", GroupZones="Living Room"}, 345) <0x6e6ec520>
                                        08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=0 <0x6e6ec520>
                                        08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x6e6ec520>
                                        08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument action=RunLua <0x6e6ec520>
                                        08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument _r=1618529519635 <0x6e6ec520>
                                        08	04/15/21 18:31:59.636	JobHandler_LuaUPnP::HandleActionRequest device: 345 service: urn:bochicchio-com:serviceId:VeraAlexa1 action: RunRoutine <0x6e6ec520>
                                        08	04/15/21 18:31:59.636	JobHandler_LuaUPnP::HandleActionRequest argument GroupZones=Living Room <0x6e6ec520>
                                        08	04/15/21 18:31:59.636	JobHandler_LuaUPnP::HandleActionRequest argument RoutineName=Time for Cooking <0x6e6ec520>
                                        50	04/15/21 18:31:59.638	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",345) old value "" <0x6e6ec520>
                                        50	04/15/21 18:31:59.638	luup_log:345: VeraAlexa[0.92@345](runRoutine@348):Executing command [runRoutine]: "-e automation:\"Time for Cooking\" -d \"Living Room\"" <0x6e6ec520>
                                        Should I uninstall the plug-in and re-install it from scratch from your GitHub repo? I'm assuming you keep updating it based on new releases, and now I'm worried that simply pasting the contents of v0.17c into the existing .sh file on Vera may not have been the best approach. (Seemed smart at the time.)
                                        EDIT: It wasn't a smart idea, since everything stopped working (i.e. no Alexa commands would do anything any more), so I swapped back the v0.17a version of the .sh file on Vera.
                                          @librasun if you set Configured variable to 0, it will download the sh script again.
                                          set DebugMode var to 1 and see if jq is successfully detected, because it's a pre-requisite for routines.
                                          LibraSunL 1 Reply Last reply
                                            165.2k
