  2. Hardware
  3. Vera
  4. Vera Alexa Plugin 7.32
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
119 Posts 7 Posters 73.2k Views 5 Watching
    wrote on last edited by Pabla
    #96
    Those codes that @therealdb posted worked fine for me oddly enough, I don't know how they weren't working earlier.
    Edit: I have only tested with my Echo not any of my Sonos devices yet
      I ran his updated code again twice - once with "UseAnnouncements" set to 0, once set to 1 - targeting my Echo device ('Kitchen') and received silence both times. Kept DebugMode = 1 throughout, but don't see any overt errors.
      But I AM troubled by the weird red text mentioning "MONGOOSE" always occurring the millisecond before my Lua code runs... anyone know why it's ALWAYS there?
      03/26/21 13:24:43.474	Mongoose mg_read start (null) <0x6f5c2520>
      01	03/26/21 13:24:43.475	Mongoose mg_read middle (null) 762 <0x6f5c2520>
      01	03/26/21 13:24:43.475	Mongoose mg_read end (null) 762 <0x6f5c2520>
      01	03/26/21 13:24:43.475	Mongoose mg_read after pull (null) 0 <0x6f5c2520>
      08	03/26/21 13:24:43.476	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunLua <0x6f5c2520>
      08	03/26/21 13:24:43.476	JobHandler_LuaUPnP::HandleActionRequest argument post_data=id=lu_action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunLua&Code=function%20say(text%2C%20r%2C%20volume%2C%20zone)%0A%20%20luup.call_action(%22urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1%22%2C%20%0A%20%20%20%22Say%22%2C%0A%20%20%7B%0A%20%20%20Text%20%3D%20%27%3Camazon%3Adomain%20name%3D%22conversational%22%3E%27%20..%20text%20..%20%27%3C%2Famazon%3Adomain%3E%27%2C%0A%20%20%20Repeat%3D%20r%20or%201%2C%0A%20%20%20Volume%3Dvolume%20or%2050%2C%20%0A%20%20%20GroupZones%3D%20zone%0A%7D%2C%20345)%0Aend%0A%20%0Asay(%27I%20really%20didn%E2%80%99t%20know%20how%20this%20morning%20was%20going%20to%20start.%20And%20if%20I%20had%20known%2C%20I%20think%20I%20might%20have%20just%20stayed%20in%20bed.%27%2C%201%2C%2050%2C%20%27Kitchen%27) <0x6f5c2520>
      08	03/26/21 13:24:43.476	JobHandler_LuaUPnP::HandleActionRequest argument id=lu_action <0x6f5c2520>
      08	03/26/21 13:24:43.476	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x6f5c2520>
      08	03/26/21 13:24:43.477	JobHandler_LuaUPnP::HandleActionRequest argument action=RunLua <0x6f5c2520>
      08	03/26/21 13:24:43.477	JobHandler_LuaUPnP::HandleActionRequest argument Code=function say(text, r, volume, zone)
        luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1",
         "Say",
         Text = '<amazon:domain name="conversational">' .. text .. '</amazon:domain>',
         Repeat= r or 1,
         Volume=volume or 50,
         GroupZones= zone
      }, 345)
      say('I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.', 1, 50, 'Kitchen') <0x6f5c2520>
      08	03/26/21 13:24:43.479	JobHandler_LuaUPnP::HandleActionRequest device: 345 service: urn:bochicchio-com:serviceId:VeraAlexa1 action: Say <0x6f5c2520>
      08	03/26/21 13:24:43.480	JobHandler_LuaUPnP::HandleActionRequest argument GroupZones=Kitchen <0x6f5c2520>
      08	03/26/21 13:24:43.480	JobHandler_LuaUPnP::HandleActionRequest argument Text=<amazon:domain name="conversational">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> <0x6f5c2520>
      08	03/26/21 13:24:43.480	JobHandler_LuaUPnP::HandleActionRequest argument Repeat=1 <0x6f5c2520>
      08	03/26/21 13:24:43.480	JobHandler_LuaUPnP::HandleActionRequest argument Volume=50 <0x6f5c2520>
      50	03/26/21 13:24:43.481	luup_log:345: VeraAlexa[0.92@345]:addToQueue({ Volume="50", Text="<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain>", Repeat="1", GroupZones="Kitchen" }) <0x6f5c2520>
      50	03/26/21 13:24:43.482	luup_log:345: VeraAlexa[0.92@345](addToQueue@234):addToQueue(2): 0 - true <0x6f5c2520>
      50	03/26/21 13:24:43.483	luup_log:345: VeraAlexa[0.92@345](addToQueue@251):addToQueue(3): 1 <0x6f5c2520>
      50	03/26/21 13:24:43.483	luup_log:345: VeraAlexa[0.92@345](addToQueue@254):addToQueue(4): playing <0x6f5c2520>
      50	03/26/21 13:24:43.484	luup_log:345: VeraAlexa[0.92@345](checkQueue@206):checkQueue: 1 in queue <0x6f5c2520>
      50	03/26/21 13:24:43.485	luup_log:345: VeraAlexa[0.92@345](checkQueue@214):checkQueue: play next <0x6f5c2520>
      50	03/26/21 13:24:43.486	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",345) old value "" <0x6f5c2520>
      50	03/26/21 13:24:43.487	luup_log:345: VeraAlexa[0.92@345](sayTTS@323):Executing command [TTS]: "-e speak:'<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain>' -d \"Kitchen\"" <0x6f5c2520>
      50	03/26/21 13:24:45.930	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:micasaverde-com:serviceId:HaDevice1","CommFailure","0",345) old value "0" <0x6f5c2520>
      50	03/26/21 13:24:45.931	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","LatestResponse","sending cmd:speak:<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> to dev:Kitchen type:A1MPSLFC7L5AFK serial:2f69293cc2c749f6854ad6c5b41aef43 customerid:A3SL3Z0HELH3YG",345) old value "sending cmd:speak:<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> to dev:Kitchen type:A1MPSLFC7L5AFK serial:2f69293cc2c749f6854ad6c5b41aef43 customerid:A3SL3Z0HELH3YG" <0x6f5c2520>
      50	03/26/21 13:24:45.932	luup_log:345: VeraAlexa[0.92@345](@279):Response from Alexa.sh: "sending cmd:speak:<amazon:domain name=\"conversational\">I really didn’t know how this morning was going to start. And if I had known, I think I might have just stayed in bed.</amazon:domain> to dev:Kitchen type:A1MPSLFC7L5AFK serial:2f69293cc2c749f6854ad6c5b41aef43 customerid:A3SL3Z0HELH3YG" <0x6f5c2520>
      50	03/26/21 13:24:45.933	luup_log:345: VeraAlexa[0.92@345](sayTTS@337):Queue will be checked again in 11.726 secs <0x6f5c2520>
      50	03/26/21 13:24:56.101	luup_log:345: VeraAlexa[0.92@345](checkQueue@206):checkQueue: 0 in queue <0x73a03520>
      50	03/26/21 13:24:56.102	luup_log:345: VeraAlexa[0.92@345](checkQueue@210):checkQueue: queue is empty <0x73a03520>
      PablaP therealdbT 2 Replies Last reply
           "Say",
           Repeat= r or 1,
           GroupZones= zone
        }, 345)
        @librasun Instead of using the Zone names have you tried inputting the Echo's name in the GroupZone argument instead? ie if its called Kitchen Dot or whatever.
             "Say",
             Repeat= r or 1,
             GroupZones= zone
          }, 345)
          #99
          @librasun said in Vera Alexa Plugin 7.32:
          It’s a fix they did in 7.32. No worries.
          As for the echo remaining silent, open l_*.lua and set devmode variable to 1, then reload luup. It will be verbose during logging, posting the entire sh command. You could try to capture it and run directly via ssh, to see the complete response.
            #100
              Vera beta, not VeraAlexa I assume?
              So glad I stopped with it! There's so much I should do with OpenLuup but I lack both the imagination and the skill, but thanks to all on here, have a rock solid system!
              PablaP 1 Reply Last reply
                @catmanv2 ha whoops didn’t even check I posted in the correct thread.
                  This still is hacky, because it's based on unsupported feature, but me and many others have it running since 3+ years. The point is to
                  • ensure you could get a cookie. If not, the best thing to do is to install on a pi or similar and use via oath tool and openluup
                  • use exact names for devices, because it's case sensitive
                  • avoid groups, unless you have announcements enabled
                  • avoid complex voices, unless you have announcements enabled
                  • try with debugmode set to 1 and looking at live logs
                  I'm always open to PRs for docs and a UI, if anyone wants to contribute. I've not invested so much into a proper UI because I still think it's not really necessary, but it doesn't mean that one of you could not step in and do it 😁
                  #103
                  @therealdb Has the 'runroutine' action been deprecated?
                  I just tried sending:
                    "RunRoutine",
                    {RoutineName="Time for Cooking", GroupZones="Living Room"}, 345)
                  and got back this error:
                  ERROR: unknown command "automation:Time for Cooking"!
                  ...along with all the possible valid options...
                  /storage/alexa/alexa_remote_control_plain.sh [-d <device>|ALL] -e <pause|play|next|prev|fwd|rwd|shuffle|repeat|vol:<0-100>> |           -b [list|<"AA:BB:CC:DD:EE:FF">] | -q | -n | -r <"station name"|stationid> |           -s <trackID|'Artist' 'Album'> | -t <ASIN> | -u <seedID> | -v <queueID> | -w <playlistId> |           -a | -m <multiroom_device> [device_1 .. device_X] | -lastalexa | -l | -h    -e : run command, additional SEQUENCECMDs:         weather,traffic,flashbriefing,goodmorning,singasong,tellstory,         speak:'<text>',sound:<soundeffect_name>,         textcommand:'<anything you would otherwise say to Alexa>'    -b : connect/disconnect/list bluetooth device    -q : query queue    -n : query notifications    -r : play tunein radio    -s : play library track/library album    -t : play Prime playlist    -u : play Prime station    -v : play Prime historical queue    -w : play library playlist    -a : list available devices    -m : delete multiroom and/or create new multiroom containing devices    -lastalexa : print serial number that received the last voice command    -login : Logs in, without further command    -l : logoff    -h : help
                  In brief, I see no reference (except in the ReadMe back at GitHub) to the 'RunRoutine' action, neither does trying to execute a routine through the 'textcommand' method. Any suggestions?
                      "RunRoutine",
                    @librasun routine is a shortcut for -e automation:'ABC'.
                    In my experience, no space will work better, and sometimes you'll have to replace with _. ie 'Time_for_Cooking'
                    I'm using routines daily, to trigger things (ie, when the alarm is off, when we are going to bed to read my calendar, weather, and house status via a virtual device on HA-bridge, etc) and it's working no problem since day 1.
                      I'll gladly give that a whirl, thanks again. Sorry to always take up your time with such mundane things like this!!
                        @librasun no worries, I’m happy to help 😉
                          #107
                          Sadly, not a single time has either version ("RunRoutine" or "-e automation:") of this construct worked. It always, always claims it's an unknown command (as I shared earlier). I've used precisely the syntax from the docs, and this thread, and only those. Makes me wonder what the heck is going on. 😕
                          About to resume giving up. My only hope at this juncture was to have Vera kick off an Alexa routine. She can speak, start (non-routine) commands, make music, give the weather, etc. But not this one thing. Argh.
                            @librasun post your variables, minus the username and password. Let’s see how it’s configured.
                              Here ya go:
                              device #345
                              DebugMode
                              BinPath
                              /storage/alexa
                              Username
                              xxxxxxxxxxxx
                              Password
                              xxxxxxxxxxxx
                              DefaultEcho
                              Living Room
                              DefaultVolume
                              50
                              AnnouncementVolume
                              50
                              Language
                              en-us
                              AlexaHost
                              pitangui.amazon.com
                              AmazonHost
                              amazon.com
                              UseAnnoucements
                              DefaultBreak
                              OneTimePassCode
                              CommFailure
                              CurrentVersion
                              0.92
                              LatestResponse
                              ERROR: unknown command "automation:Time_for_Cooking"! /storage/alexa/alexa_remote_control_plain.sh [-d
                              Configured
                                Oddly there is a bugle_03 and that doesn't work either
                                Nor 01 or 02 and they are in exactly the same format.
                                @catmanv2 said in Vera Alexa Plugin 7.32:
                                Check out the part of this documentation that describes:
                                "Unfortunately, you have to try out the possible sound library entries . Of the four possible trumpet sounds, only the one shown above works, for example. You can see what sounds there are when you add "tones" to a routine."
                                  #111
                                  @therealdb somehow, on my own, I unearthed an update to alexa_remote_control_plain.sh (v0.17c -- I had been using v0.17a (now safely backed up!) until today), and it seems one step closer to honoring the RunRoutine verb. At least it doesn't throw errors in the Log or in the Variables section. Still total silence, though!
                                  Here's how it looks in the LuaUPnP log:
                                  08	04/15/21 18:31:59.634	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunLua <0x6e6ec520>
                                  08	04/15/21 18:31:59.634	JobHandler_LuaUPnP::HandleActionRequest argument Code=luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1", "RunRoutine", {RoutineName="Time for Cooking", GroupZones="Living Room"}, 345) <0x6e6ec520>
                                  08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=0 <0x6e6ec520>
                                  08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x6e6ec520>
                                  08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument action=RunLua <0x6e6ec520>
                                  08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument _r=1618529519635 <0x6e6ec520>
                                  08	04/15/21 18:31:59.636	JobHandler_LuaUPnP::HandleActionRequest device: 345 service: urn:bochicchio-com:serviceId:VeraAlexa1 action: RunRoutine <0x6e6ec520>
                                  08	04/15/21 18:31:59.636	JobHandler_LuaUPnP::HandleActionRequest argument GroupZones=Living Room <0x6e6ec520>
                                  08	04/15/21 18:31:59.636	JobHandler_LuaUPnP::HandleActionRequest argument RoutineName=Time for Cooking <0x6e6ec520>
                                  50	04/15/21 18:31:59.638	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",345) old value "" <0x6e6ec520>
                                  50	04/15/21 18:31:59.638	luup_log:345: VeraAlexa[0.92@345](runRoutine@348):Executing command [runRoutine]: "-e automation:\"Time for Cooking\" -d \"Living Room\"" <0x6e6ec520>
                                  Should I uninstall the plug-in and re-install it from scratch from your GitHub repo? I'm assuming you keep updating it based on new releases, and now I'm worried that simply pasting the contents of v0.17c into the existing .sh file on Vera may not have been the best approach. (Seemed smart at the time.)
                                  EDIT: It wasn't a smart idea, since everything stopped working (i.e. no Alexa commands would do anything any more), so I swapped back the v0.17a version of the .sh file on Vera.
                                    @librasun if you set Configured variable to 0, it will download the sh script again.
                                    set DebugMode var to 1 and see if jq is successfully detected, because it's a pre-requisite for routines.
                                    LibraSunL 1 Reply Last reply
                                      Thanks, that'll give me something to read!
                                        #114
                                        @therealdb Oddly, no mention of jq in the log. I'll need to be reminded how to (re)install jq so I'll go check the Docs (EDIT: Nope, they don't explain how, nor where to find it.) for the 100th time, lol.
                                        Wow, this whole Vera Alexa thing has turned into quite the balancing act. So many moving parts! 😕
                                        EDIT: I found elsewhere on the old MCV forum, after much Googling, this reference to jq and where it comes from, namely:
                                        it’s a package to parse json via command line: https://stedolan.github.io/jq/
                                        You’ll have to build yourself and load in your unit.
                                        Sadly, that is all Greek to me. (And here I thought jq somehow "came with 7.32 firmware", lol.) So I kept searching...
                                        EDIT 2: Looks like 22 days ago, I was informed: "The plug-in will take care of it. So, just set configured to 0 and it will install it." Turns out I've done that twice since, so naturally assumed jq is indeed installed on my Vera.
                                        Screenshot from file search (for "jq*") in WinSCP as (false) "proof":
                                        Still frustrated... on a hunch that the above just means jquery (not jq) is installed, I then followed @Elcid 's advice from the same post:
                                        ssh in and run:
                                        opkg update
                                        opkg install jq
                                        So I PuTTY'd into Vera, did those things, and I saw these freshly installed files...
                                        Then I restarted Vera's Luup engine one more time, and ....
                                          #115
                                          AND HOLY CRAP, IT WORKS NOW!! The Last Response variable finally shows a successful...
                                          sending cmd:automation:Time for Cooking to dev:Living Room type:A15ERDAKK5HQQG serial:eb48978706f5459f890ef0ec5aa9fce9 customerid:A3SL3Z0HELH3YG
                                          and the Alexa Routine that I've been trying to run all week finally ran from MSR!
                                          Now, it's on to troubleshooting this command, which no longer responds with an error, or the odd response "Domain!", but just vexing silence after altering the volume level to '50':
                                          luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say",{Text='<amazon:domain name="conversational">Hello from Vera Alexa.</amazon:domain>', Volume=50, Repeat = 2}, 345)
                                          And dang it, now this one has stopped working (i.e. no error thrown, just silence):
                                          luup.call_action("urn:micasaverde-com:serviceId:Sonos1", "Say", {Text="Hello from your Vera Alexa"}, 345)
                                          You can never quite win. <facepalm> Now, all the formerly working routines are silent. Argh!
                                          And since I could detect no "Error" conditions in the log, I went back in via WinSCP and discovered that a new file alexa_remote_control.sh (along with a bunch of others named alexa.volume.db99...) had mysteriously appeared, but was v0.17c (shown above not to work), so I temporarily renamed it, and renamed the v0.17a file to `alexa_remote_control.sh' whereupon all my formerly working commands resumed working. Oh, man, what an unending journey. Think I'll stick with solving Sudoku puzzles!
                                          (So I renamed the files as Vera Alexa had them and ran away.)
                                            165.2k
