  3. MQTT – setup and use
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
107 Posts 10 Posters 72.8k Views 7 Watching
    I’ve just been looking here...
    MQTT - Tasmota
    and, I have to say (unless I’m missing something) it seems to be a bit of a free-for-all compared to the rather well thought-out topic structure of Shellies. I suppose that this is more or less inevitable for open source stuff.
      MQTT - Tasmota
      @akbooer yes, but announcements messages are rich and well structured. I could post something, since I have different sensor attached. I’ve also looked at the Shelly bridge, and I could send other samples (Shelly 1, Shelly 1 with temperature sensor, Shelly plug, Shelly button, Shelly uni, Shelly em) if necessary.
        Shellies, I find, are really well documented here:
        Welcome to Shelly Technical Documentation | Shelly Technical Documentation
        so no need of other examples (you might tell me your priorities.)
        For Tasmota, though, I failed to get that level of understanding from their docs, so an example might help.
        B 1 Reply Last reply
          @therealdb
          I've just added Shelly bridge support for Shelly 1/1PM (I think) in development v21.3.28.
          If you're able to check, that would be great.
          If it's all OK, then I'll move on to the others.
            @therealdb
            @akbooer I'll try it later tomorrow, since this is a family movie night. meanwhile, here's a couple of messages from my broker:
            tasmota/discovery/id
            config = {"ip":"192.168.1.50","dn":"tasmota-dehum","fn":["tasmota-dehum",null,null,null,null,null,null,null],"hn":"tasmota-dehum","mac":"XXX","md":"Sonoff TH","ty":0,"if":0,"ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"9.3.1","t":"tasmota-dehum","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[1,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1],"swn":[null,null,null,null,null,null,null,null],"btn":[0,0,0,0,0,0,0,0],"so":{"4":0,"11":0,"13":0,"17":0,"20":0,"30":0,"68":0,"73":0,"82":0,"114":0,"117":0},"lk":1,"lt_st":0,"sho":[0,0,0,0],"ver":1}
            sensors = {"sn":{"Time":"2021-03-26T23:48:03","SI7021":{"Temperature":15.8,"Humidity":73.4,"DewPoint":11.0},"TempUnit":"C"},"ver":1}
            config = {"ip":"192.168.1.53","dn":"tasmota-watertank","fn":["tasmota-watertank",null,null,null,null,null,null,null],"hn":"tasmota-watertank","mac":"ECFABC5F0A29","md":"Generic","ty":0,"if":0,"ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"9.3.1","t":"tasmota-watertank","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[0,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1],"swn":[null,null,null,null,null,null,null,null],"btn":[0,0,0,0,0,0,0,0],"so":{"4":0,"11":0,"13":0,"17":0,"20":0,"30":0,"68":0,"73":0,"82":0,"114":0,"117":0},"lk":1,"lt_st":0,"sho":[0,0,0,0],"ver":1}
            sensors = {"sn":{"Time":"2021-03-15T13:47:43","DS18B20":{"Id":"3C01D6070BEA","Temperature":15.3},"SR04":{"Distance":58.351},"TempUnit":"C"},"ver":1}
            sensors = {"sn":{"Time":"2021-03-28T09:21:22","BME280":{"Temperature":20.2,"Humidity":50.0,"DewPoint":9.4,"Pressure":967.1},"TSL2561":{"Illuminance":113.900,"IR":2135,"Broadband":6591},"PressureUnit":"hPa","TempUnit":"C"},"ver":1}
            Status are published under tele/devicename
            STATE = {"Time":"2021-03-28T19:17:42","Uptime":"13T06:19:46","UptimeSec":1145986,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":84,"POWER":"OFF","Wifi":{"AP":1,"SSId":"XXX","BSSId":"XXX","Channel":12,"RSSI":60,"Signal":-70,"LinkCount":3,"Downtime":"0T00:01:32"}}
            SENSORS = {"Time":"2021-03-28T19:17:42","DS18B20":{"Id":"3C01D607ACFE","Temperature":13.8},"TempUnit":"C"}
            The format of sensors is very similar to discovery, but more compact.
            There's also tele/device/LWT (Online, Offline) to handle "Last Will and Testament". I'm using it to notify of device being dropped out of the network via CommFailure and similar.
            I'm sure @ArcherS has many more sensors than me.
              ArcherS
              I have some 10 Tasmota devices with a number of different sensors reporting temperature etc. It is very easy to combine the sensors on one device, the information for all attached sensors are included in one SENSOR message for that Tasmota device.
              Some data from them:
              AM2301 (temp, humidity and dew point temp)
              tele/tasmota_E0395C/SENSOR = {"Time":"2021-03-28T19:56:35","AM2301":{"Temperature":5.7,"Humidity":64.6,"DewPoint":-0.5},"TempUnit":"C"}
              DS18B20 (temp) Four DS18B20 connected to one Tasmota
              tele/tasmota_2ECD0B/SENSOR = {"Time":"2021-03-28T19:49:06","DS18B20-1":{"Id":"000005B4E469","Temperature":5.8},"DS18B20-2":{"Id":"3C01D60701B8","Temperature":17.9},"DS18B20-3":{"Id":"3C01D6074A47","Temperature":20.3},"DS18B20-4":{"Id":"3C01D6079246","Temperature":9.3},"AM2301":{"Temperature":5.4,"Humidity":75.0,"DewPoint":1.3},"TempUnit":"C"}
              and in a device that also has an AM2301, since it is only one DS18B20 it does not get the "-nn" suffix
              tele/tasmota_845CBC/SENSOR = {"Time":"2021-03-28T20:11:35","DS18B20":{"Id":"000005B5E8ED","Temperature":12.0},"AM2301":{"Temperature":11.2,"Humidity":40.6,"DewPoint":-1.7},"TempUnit":"C"}
              BME280 ( temp, humidity, dew pont temp, air pressure) and BH1750 (light sensor in lux) in one device
              tele/tasmota_81FF56/SENSOR = {"Time":"2021-03-28T19:49:35","BME280":{"Temperature":6.6,"Humidity":65.4,"DewPoint":0.5,"Pressure":1009.4},"BH1750":{"Illuminance":0},"PressureUnit":"hPa","TempUnit":"C"}
              BLE sensors (temp, humidity, dew point temp) below three Xiaomi sensors identified by their MAC
              tele/tasmota_F181DC/SENSOR = {"Time":"2021-03-28T20:01:38","ATC-f159bf":{"Temperature":21.5,"Humidity":48.0,"DewPoint":10.0,"Battery":69,"RSSI":-80},"ATC-9446bf":{"Temperature":22.6,"Humidity":42.0,"DewPoint":9.0,"Battery":83,"RSSI":-89},"ATC-6d5d44":{"Temperature":14.3,"Humidity":46.0,"DewPoint":2.8,"Battery":63,"RSSI":-84},"TempUnit":"C"}
              MH-Z19B C02 meter (CO2 and temp) below in a device that also has a AM2301
              tele/tasmota_7EC9D9/SENSOR = {"Time":"2021-03-28T20:03:49","AM2301":{"Temperature":20.7,"Humidity":48.1,"DewPoint":9.3},"MHZ19B":{"Model":"B","CarbonDioxide":655,"Temperature":22.0},"TempUnit":"C"}
                B Offline
                B Offline
                Buxton
                @akbooer Tasmota energy sensor
                  "Time": "2021-03-28T21:51:01",
                  "ENERGY": {
                    "TotalStartTime": "2020-06-07T00:10:43",
                    "Total": 2356.063,
                    "Yesterday": 7.056,
                    "Today": 6.459,
                    "Period": 24,
                    "Power": 285,
                    "ApparentPower": 302,
                    "ReactivePower": 99,
                    "Factor": 0.95,
                    "Voltage": 123,
                    "Current": 2.453
                • A ArcherS
                  ArcherS
                  And a Tasmota IR receiver that can also be used for HVACs.
                  IR remotes for HVACs are a bit special, they send/receive all data fields every time.
                  Received IR from a Logitech remote:
                  tele/tasmota_E0D649/RESULT = {"IrReceived":{"Protocol":"NEC","Bits":32,"Data":"0x10EF08F7","DataLSB":"0x08F710EF","Repeat":0}}
                  Received from a noname led-lights remote:
                  tele/tasmota_E0D649/RESULT = {"IrReceived":{"Protocol":"LUTRON","Bits":3,"Data":"0x700000000","DataLSB":"0xE000000000","Repeat":0}}
                  The Tasmota IR receive/transmitter also supports HVAC remotes, this is an example of a received message from my Fujitsu remote:
                  tele/tasmota_E0D649/RESULT = {"IrReceived":{"Protocol":"FUJITSU_AC","Bits":128,"Data":"0x0x1463001010FE0930400400000000206C","Repeat":0,"IRHVAC":{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
                  I have not tested sending yet since my Mqtt is not fully up and running yet, but it should be something like this:
                  IRsend{"Protocol":"NEC","Bits":32,"Data":"0x10EF08F7","DataLSB":"0x08F710EF","Repeat":0}
                  and for IRHVAC:
                  IRHVAC{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
                    @therealdb
                    #22
                    @akbooer shelly 1 seems to be good, but I'm mostly using them as binary sensors (shelly 1 can detach the input from the button, so it's very handy ie for doorbell, PIR or similar, since it's 12v or 110/220).
                    It also discovered my shelly plug, but as a scene controller. Here's the info part:
                    {"wifi_sta":{"connected":true,"ssid":"XXX","ip":"192.168.1.46","rssi":-47},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":true},"time":"08:57","unixtime":1617001074,"serial":30,"has_update":false,"mac":"XXXX","cfg_changed_cnt":12,"actions_stats":{"skipped":0},"relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"source":"timer"}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1617008274,"counters":[0.000, 0.000, 0.000],"total":0}],"temperature":31.77,"overtemperature":false,"tmp":{"tC":31.77,"tF":89.18, "is_valid":true},"update":{"status":"idle","has_update":false,"new_version":"20210323-105718/v1.10.1-gf276b51","old_version":"20210323-105718/v1.10.1-gf276b51"},"ram_total":50632,"ram_free":38444,"fs_size":233681,"fs_free":166413,"uptime":222282}
                    It's a plug with KWH and internal temp sensor, for overheat protection.
                      I will also probably just send an announce message upon start of the broker. This will enable automatical discover of new devices, with no user intervention.
                        shelly 1 seems to be good, but I'm mostly using them as binary sensors (shelly 1 has the ability to detach the input from the button
                        Yes, I think all their switches can do that. I’ll add the appropriate logic to give each child device the scene controller variables.
                          #25
                          I think we need a separate Tasmota thread, or this will get confusing.
                          @therealdb for the Shelly input devices I see:
                            for switch in "momentary" mode:
                            input_event/n = {"event":"S","event_cnt":11}
                          		S = shortpush
                          		L = longpush
                          		SS = double shortpush
                          		SSS = triple shortpush
                          		SL = shortpush + longpush
                          		LS = longpush + shortpush
                          and this can be for multiple inputs (eg. ix3 has three.)
                          So we need to agree on how to map these to scene numbers. Perhaps the easiest thing is to repesent each one by increments of 10.
                          For example:
                              scene_no = {
                          		S = 10,  -- shortpush
                          		L = 20,  -- longpush
                          		SS = 30, -- double shortpush
                          		SSS = 40,  -- triple shortpush
                          		SL = 50, -- shortpush + longpush
                          		LS = 60, --longpush + shortpush
                          so a short push on button 0 would be 10, a long push on button 1 would be 21.
                            After an embarassing three attempts, v21.3.29c has this multi-push scene numbering implemented for shelly-ix3 (only, at the moment.)
                              		S = shortpush
                              		L = longpush
                              For example:
                                  scene_no = {
                              		L = 20,  -- longpush
                              @akbooer yeah, I think the numbering is OK.
                              What I was referring to detached mode is that when in this mode, you have input and switch not in sync, so imho we should map them as a BinarySwitch and a generic security sensor for the input. You'll get both \input and \relay mqtt message.
                              I think it's OK to discuss Tasmota in this thread, since it's basically all dedicated to MQTT 😉
                                #28
                                Can't be a generic security sensor if you want to capture the different switch press modes, so I think just the sl_SceneActivated and time makes more sense.
                                  Just wanted to say big thanks to all for the great work!
                                  I've read all the progress with the broker and Tasmota bridge with joy and now managed to switch my Sonoffs from rules and Virtual HTTP Devices completely to MQTT using homebridge-mqttthing and Virtual Sensor plugin.
                                    @crille
                                    Excellent news. Yes, I am using homebridge-mqttthing too, for my few-remaining Zwave devices bridged to openLuup from Vera. The Homebridge-Shelly accessory is also very functional.
                                    All this means that the Apple Home app is my primary UI (well, actually secondary, since Siri on the HomePod takes care of most things.)
                                      #31
                                      Awesome to see the MQTT implementation. Only if I could get myself the motivation to migrate to homebridge and get everything (Z-way/openLuup/HomeAssistant/Homebridge) to talk through MQTT instead of http as they are at the moment... It seems to be a lot of work...
                                      For me too, the Apple Home app has become my primary (yet rarely used) UI.
                                        @crille
                                        I'm trying to get rid of the old Vera plugin for Homebridge.
                                        What topics do I put in mqttthing to get/set bridged Vera devices?
                                        I got the "getOn" to reflect the status when I had luup.attr_set ("openLuup.MQTT.PublishVariableUpdates", true) in the Lua Startup Code, is that necessery for this purpose?
                                        Do I need to write a handler for this?
                                        I tried a generic handler but never got it to work.
                                        Do you have an example of a handler if it's required?
                                          Depends what you want to get/set. Currently, I'm just using this for on/off switches, so using the mqttthing type Light bulb - on/off. I'm sure you can be more sophisticated, but I haven't tried it.
                                          As an example, I'll use a Vera-attached Zwave switch (device #30186 – it's actually a Fibaro relay, but it could be anything)
                                          The first thing you need to ensure is that you have set the openLuup MQTT server to publish variable updates, using this line in Lua Startup:
                                          luup.attr_set ("openLuup.MQTT.PublishVariableUpdates", true)   -- publish variable updates
                                          So, then, in order to reflect the relevant variable in the mqttthing you need in MQTT Topics :
                                          • Get on – openLuup/update/30186/SwitchPower1/Status
                                          and in order to control it:
                                          • Set on – relay/30186
                                          The relay command above is just a convenient openLuup shortcut to turn devices on/off which works both in MQTT and as an HTTP request.
                                          That should be all for basic control.
                                            154.0k
