  2. Hardware
  3. Vera
  4. Messaging after VERA decoupling
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
19 Posts 9 Posters 5.1k Views 9 Watching
  • S sender
    @therealdb haven't you got the telegram desktop app?
    @sender yes, but I love to experiment things. the desktop app is actively sending notifications to my Vera system via MQTT, so I'm turning on lights (including a BusyLight outside my home office) when I'm joining a call, when it's dark and I'm working at the PC, or turn them off when it's light enough in the morning.
    • ? Offline
      ? Offline
      A Former User
      I'll check out Telegram and Pushover. Thanks for the suggestions.
      • ? Offline
        ? Offline
        A Former User
        Settled on Pushover.net as it fits my messaging alert needs perfectly. I have added to my other systems instead of e-mailing.
        I was surprised on how many applications have direct integrations with it including Home Assistant.
          Yep, I have been running pushover, replacing the vera mobile push notification for quite a few years. It's been rock solid. I was particularly enamored by the ability to push snapshots of my security cameras to my apple watch... To make it easy I used Home Assistant as the integration relay so openLuup (and vera before that) sent the call to home assistant which then went to pushover.
          • parkercP Offline
            parkercP Offline
            parkerc
            I’m a bit old school, I still use Prowl with my Veras - https://www.prowlapp.com/
            Here’s some code examples on how to use it.
            function my_escape (s)
                s = string.gsub(s, " ", "+")
                return s
            function my_prowl (appl, event, description)
                local prowl_url      = "https://api.prowlapp.com/publicapi/add?apikey="
                    .. "put-your-api-code-here"
                    .. "&application=" .. my_escape(appl)
                    .. "&event="         .. my_escape(event)
                    .. "&description=" .. my_escape(description)
                    .. "&priority=-1"
                    .. "&url=https://www.google.co.uk/"
                luup.inet.wget(prowl_url)
            my_prowl ("Vera Home Controller", "Testing code", "this could any description")
            Or something all in one..
            luup.inet.wget("https://api.prowlapp.com/publicapi/add?apikey=Your-api-key-goes-here&application=Test+Event&event=Armed+Notification&description=The+DSC+alarm+system+has+been+armed&priority=1")
              I've gotta ask, since Pushover essentially breaks their paid apps down into three "flavors" (Web browser, Android and iOS), how do they differentiate other channels like Home Assistant or IFTTT? Or do those get lumped into "Web" along with Chrome, etc.? (I assume every endpoint has to have a unique name, no matter what.)
              ? 1 Reply Last reply
                I am really not sure. I am only using the iOS app as the notification target. Home Assistant just sends the notification and is not considered a channel... (Simple python http post call) I also have not used any paid tier. It's been 3 years.
                • ? A Former User
                  First I want to say thank you to this group. You have given me ideas and help along the HA path for a long time.
                  I'm an old Vera user and planning to decouple from MIOS cloud now or after 7.32 but I'm stuck at how to push messages out.
                  I'm using Reactor and Scenes for Vera native messaging. What's a good solution going forward?
                  Also want to mention that after reading the Decoupling document I have built a NTP GPS server on a Pi3B and enjoyed learning more about Linux along the way. I have it stabilized after learning 100 different ways.
                  @droy last week I changed all notification types to a Telegram BOT, it works great, fast and simple.
                    ? Offline
                    ? Offline
                    A Former User
                    @librasun it looks like they charge the onetime fee by user consumption endpoint groups (Android, iOS, and Desktop) and not integrations or apps.
                      That's right. I thought someone above was saying that HA was acting as an endpoint, not just a broadcast source. I was wrong.
                      • ? A Former User
                        ArcherS
                        @droy I use the excellent Telegram plugin by @therealdb in OpenLuup, it should work on the Vera also.
                        • A ArcherS
                          @archers 100% working under Vera as well.
                            sender
                            I use homeassistant with node red and telegram natively. Alternatively I use the homeassistant companion app with messaging. Both rock solidand instant.
                              147.9k
