  4. x_vera_device.failed=true Question
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
7 Posts 2 Posters 1.8k Views 2 Watching
    I have a couple of HS1DS-Z door sensors (Z-Wave) this issue is newish and hasn't always been a problem with them. I have an MSR rule that will detect any failed devices on the Vera Hub and alert me. For some reason MSR thinks these two door sensors have failed when I think they have not. As they are fully working and operational within Vera.
    Yesterday I unpaired both of them from the Vera controller and added them again to see if that might fix the issue, but I have just seen an alert in MSR about one of these door sensors being failed again.
    Looking at it in the Entities I see this:
    Looking at this devices variables in the Vera UI7 I don't even see a CommFailure variable listed at all for some reason, not sure why.
    So how is MSR deciding the device is failed ?
      arming.state=false
      battery_power.level=0.65
      battery_power.since=1661355061000
      binary_sensor.state=false
      door_sensor.state=false
      x_vera_device.configured=true
      x_vera_device.device_number=202
      x_vera_device.device_type="urn:schemas-micasaverde-com:device:DoorSensor:1"
      x_vera_device.mapped_by="*;device_type=urn:schemas-micasaverde-com:device:DoorSensor:1"
      x_vera_device.mapped_class="door_sensor"
      x_vera_device.parent_device=1
      x_vera_device.room_id="7"
      x_vera_svc_micasaverde_com_HaDevice1.AutoConfigure="-1"
      x_vera_svc_micasaverde_com_HaDevice1.BatteryDate="1661355061"
      x_vera_svc_micasaverde_com_HaDevice1.BatteryLevel="65"
      x_vera_svc_micasaverde_com_HaDevice1.ChildrenSameRoom="1"
      x_vera_svc_micasaverde_com_HaDevice1.CommFailure="1"
      x_vera_svc_micasaverde_com_HaDevice1.CommFailureAlarm="1656854367,1"
      x_vera_svc_micasaverde_com_HaDevice1.CommFailureTime="1661092640"
      x_vera_svc_micasaverde_com_HaDevice1.Configured="1"
      x_vera_svc_micasaverde_com_HaDevice1.FirstConfigured="1661353606"
      x_vera_svc_micasaverde_com_HaDevice1.LastUpdate="1661355061"
      x_vera_svc_micasaverde_com_HaDevice1.ModeSetting="1:;2:A;3:A;4:A"
      x_vera_svc_micasaverde_com_HaDevice1.PollRatings="5.00"
      x_vera_svc_micasaverde_com_HaDevice1.WakeupRatings="5.00"
      x_vera_svc_micasaverde_com_HaDevice1.sl_Alarm="TAMPER_ALARM"
      x_vera_svc_micasaverde_com_HaDevice1.sl_Alarm_updated=1658772103494
      x_vera_svc_micasaverde_com_HaDevice1.sl_BatteryAlarm="0"
      x_vera_svc_micasaverde_com_HaDevice1.sl_BatteryAlarm_updated=1658772103494
      x_vera_svc_micasaverde_com_HaDevice1.sl_TamperAlarm="0"
      x_vera_svc_micasaverde_com_HaDevice1.sl_TamperAlarm_updated=1661355055978
      x_vera_svc_micasaverde_com_SecuritySensor1.Armed="0"
      x_vera_svc_micasaverde_com_SecuritySensor1.ArmedTripped="0"
      x_vera_svc_micasaverde_com_SecuritySensor1.IgnoreTripTime="2"
      x_vera_svc_micasaverde_com_SecuritySensor1.LastTamper="1661355055"
      x_vera_svc_micasaverde_com_SecuritySensor1.LastTrip="1661377232"
      x_vera_svc_micasaverde_com_SecuritySensor1.Tripped="0"
      x_vera_svc_micasaverde_com_ZWaveDevice1.AgiInfo="X"
      x_vera_svc_micasaverde_com_ZWaveDevice1.AlarmType="0x6,0x7,"
      x_vera_svc_micasaverde_com_ZWaveDevice1.AlarmVersion="0,1"
      x_vera_svc_micasaverde_com_ZWaveDevice1.AssociationNum="5"
      x_vera_svc_micasaverde_com_ZWaveDevice1.Capabilities="83,156,1,4,7,1,R,B,RS,|48:2,89,90,94,113:4,114,115,128,132:2,133,134,"
      x_vera_svc_micasaverde_com_ZWaveDevice1.ConfiguredAssoc=""
      x_vera_svc_micasaverde_com_ZWaveDevice1.ConfiguredWakeupInterval="86400"
      x_vera_svc_micasaverde_com_ZWaveDevice1.LastArr="1661377143,2"
      x_vera_svc_micasaverde_com_ZWaveDevice1.LastNnu="1661375951,2"
      x_vera_svc_micasaverde_com_ZWaveDevice1.LastReset="1661353599"
      x_vera_svc_micasaverde_com_ZWaveDevice1.LastRouteUpdate="1661354768"
      x_vera_svc_micasaverde_com_ZWaveDevice1.LastWakeup="1661377235"
      x_vera_svc_micasaverde_com_ZWaveDevice1.ManufacturerInfo="608,360,360"
      x_vera_svc_micasaverde_com_ZWaveDevice1.NodeInfo="30,59,5a,5e,71,72,73,80,84,85,86,"
      x_vera_svc_micasaverde_com_ZWaveDevice1.PlusInfo="1,6,0,12,6,12,6"
      x_vera_svc_micasaverde_com_ZWaveDevice1.PollNoReply="131"
      x_vera_svc_micasaverde_com_ZWaveDevice1.PollOk="2"
      x_vera_svc_micasaverde_com_ZWaveDevice1.PollSettings="0"
      x_vera_svc_micasaverde_com_ZWaveDevice1.SensorBiType="10"
      x_vera_svc_micasaverde_com_ZWaveDevice1.SubscribedAlarms=",0x6,0x7,"
      x_vera_svc_micasaverde_com_ZWaveDevice1.VersionInfo="6,4,5,1,1"
      x_vera_svc_micasaverde_com_ZWaveDevice1.WakeupCapabilities="60,86400,10800,60"
      x_vera_svc_micasaverde_com_ZWaveDevice1.WakeupInterval="86400"
      x_vera_svc_micasaverde_com_ZWaveNetwork1.ConsecutivePollFails="0"
      x_vera_svc_micasaverde_com_ZWaveNetwork1.LastPollSuccess="1661355061"
      x_vera_svc_upnp_org_SwitchPower1.Status="0"
      zwave_device.capabilities="83,156,1,4,7,1,R,B,RS,|48:2,89,90,94,113:4,114,115,128,132:2,133,134,"
      zwave_device.failed=true
      zwave_device.manufacturer_info="608,360,360"
      zwave_device.node_id=147
      zwave_device.version_info="6,4,5,1,1"
      Capabilities: arming, battery_power, binary_sensor, door_sensor, x_vera_device, x_vera_security, x_vera_svc_micasaverde_com_HaDevice1, x_vera_svc_micasaverde_com_SecuritySensor1, x_vera_svc_micasaverde_com_ZWaveDevice1, x_vera_svc_micasaverde_com_ZWaveNetwork1, x_vera_svc_upnp_org_SwitchPower1, zwave_device
      Actions: arming.arm, arming.disarm, x_vera_device.set_variable, x_vera_security.trip, x_vera_security.untrip, x_vera_svc_micasaverde_com_HaDevice1.AllowPairing, x_vera_svc_micasaverde_com_HaDevice1.Poll, x_vera_svc_micasaverde_com_HaDevice1.Reconfigure, x_vera_svc_micasaverde_com_HaDevice1.Remove, x_vera_svc_micasaverde_com_HaDevice1.SetPollFrequency, x_vera_svc_micasaverde_com_HaDevice1.StressTest, x_vera_svc_micasaverde_com_HaDevice1.ToggleState, x_vera_svc_micasaverde_com_SecuritySensor1.SetArmed, x_vera_svc_micasaverde_com_ZWaveNetwork1.AddNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.BackupDongle, x_vera_svc_micasaverde_com_ZWaveNetwork1.DownloadNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.HealNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.PollAllNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.PutByte, x_vera_svc_micasaverde_com_ZWaveNetwork1.ReconfigureAllNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.RemoveNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.SendData, x_vera_svc_micasaverde_com_ZWaveNetwork1.SetPolling, x_vera_svc_micasaverde_com_ZWaveNetwork1.SimulateIncomingData, x_vera_svc_micasaverde_com_ZWaveNetwork1.UpdateNeighbors, x_vera_svc_micasaverde_com_ZWaveNetwork1.UpdateNetwork, x_vera_svc_upnp_org_SwitchPower1.SetTarget, zwave_device.debug, zwave_device.heal, zwave_device.interview, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.remove_failed, zwave_device.replace_failed, zwave_device.reset_meters, zwave_device.set_config, zwave_device.set_location, zwave_device.set_name, zwave_device.set_value
        Just spotted "x_vera_svc_micasaverde_com_HaDevice1.CommFailure="1"" in that output above. Yet I cannot see that in the Vera UI7 web GUI for this device in its variables. Also I do not have that red banner that says "Can't detect device". As far as Vera looks the device looks to be all OK and working fine.
        Obviously that variable should be 0 not 1.
          This is the device variables in Vera UI7
            Just create the CommFailure variable on the Vera using the service ID given with a value of 0. That variable should exist for all Z-Wave devices, so if it isn't there, it either got deleted somehow (corruption?) or its a bug in the device handler (on the Vera).
              Looking on another different device I made a note of these:
              CommFailure - urn:micasaverde-com:serviceId:HaDevice1
              CommFailureTime - urn:micasaverde-com:serviceId:HaDevice1
              CommFailureAlarm - urn:micasaverde-com:serviceId:HaDevice1
              Then on one of the problematic Door contact sensors I added the new services.
              Now under its Variables tab I see them:
              I will monitor and see if CommFailure goes back to 1 ?
                The issue isn't that CommFailure was 0 or 1, it was that it wasn't there at all. That suggests it may have existed at some point with value 1, then disappeared, leaving the attribute value on the MSR side stuck (because it had no variable from Vera to use to change it). It's possible the Vera device handler has a bug and instead of setting 0 when the device is configured, it sets it to blank, which as of a couple of firmware versions ago, deletes the variable rather than setting it to an empty value. Having now created it manually, if it later disappears, that would confirm this theory -- something in the firmware is removing for some reason (or worst case, there's user_data corruption). In any case, CommFailure should always exist for Z-Wave devices, so something isn't right there, but of course, no chance that it would be researched or fixed these days. The Vera firmware thread has been long dead, no updates have been published, and questions and requests are left unanswered; I have my doubts that anyone with the knowledge (and will) is still there. Everyone's busy filling the holes in the new firmware (now four years since the acquisition).
                  163.3k
