  4. [Solved] Expressions - predefining a variable type
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
11 Posts 3 Posters 2.7k Views 3 Watching
    wrote on last edited by PerH
    I have a use case where I need to have a boolean variable that will be set to true/false by reactions.
    I see that i can define a local variable by giving it a name and leaving the definition empty. This leaves it at state "null" until a reaction tells it that its a boolean.
    Is there a way to tell it that it should start out as "false" (i.e when reactor has restarted), and not null?
    Am i going about this the wrong way?
    -- The use case is that I have a sensor on my fireplace, and the following logic is for notifying when its time to get up en refill with firewood.. I also want to reset the MaxInInterval to CurrentTemp when notification is sent..
    1fd2951f-cb6b-4a2f-b957-1e0698171f4d-image.png dd99634e-f0ad-4878-bb87-0284c2df5535-image.png
    Edit: better screenhots. Reactor version 23010-7dd2c9e9
      BTW, in the screenshots we see that the NotificationSent has fired, and is now interpreted as a string..
        The rule is corrected and works well:
        It notifies once for each time the temperature has increased, only with temperatures above 100°C, and when i'm home..
        The NotificationSent value wasn't nessecary here, But i'm still wondering if one can define a variable type and set the start value, and later manupulate that value by a reaction?
          It depends on the use case, but I usually set them via a group in the reaction. Just be sure to se to ${{bool(false)}}
          Depending on the use case, I have a couple resetting (or setting for the first time) in a reaction watching for MSR start.
            @therealdb said in Expressions - predefining a variable type:
            That's redundant. false is a reserved word that means boolean false, so you don't need to put it through bool()
            @PerH
            This Set Variable action is setting the variable to the string value "true". The operand/parameter of the action is a string. In order to get a boolean, you have to use the expression substitution form as @therealdb suggests, but you only need ${{ true }} -- the interior of the substitution is an expression, and the result of the expression is whatever type the expression result is... in this case, the keyword true simply evaluates to boolean true (the result is boolean).
            To answer your original question, you can initially set the expression for the variable to false in the Expressions editor at the time you create the variable (or any time after), save changes, force and evaluation, and then once the initial false value is bound to the variable, just remove the expression (make it an expressionless variable) and save changes again.
              Considering this solved, but would like to add that its a bit important to mark "true" and "false" as depicted above here, and not using them in string form.
              Using "true" in string form in the condition like in "MaxInInterval" in the initial post didn't work, the condition didn't flip when the state changed.
              I guess this is because of how these reserved words are interpreted, so tagging them as boolean is important.
              • PerHP PerH
                @PerH I'm finding this entire statement to be a bit cryptic. Can you elaborate on what you are saying here, how you now think it works?
                  I'd be happy to!
                  in the original post you see my expression: if NotificationSent != "true" then, which is supposed to reset the maximum reading when notification is sent, and prepare for a new increase when more wood is applied.
                  This never fired when the condition was met, but when I changed it to if NotificationSent != "1" then, (with the same change in the reactions) it worked as intended. The variable was still interpreted as a string.
                  My theory was that this was caused by the special considerations for the word "true" in the interpreter somehow, and that the ${{ true }} in the reaction would solve the problem.
                  That may offcourse be wrong? I admit that the imperical basis is rather thin. 😉
                  I should be able to reproduce this if needed.
                  • PerHP PerH
                    I'd be happy to!
                    @PerH I’ve been in the same boat and, yes, the problem is in the underlying type. The same applies to int/float, if you have an increment somewhere.
                    Apologies for the bool() part, I was on my phone and I wrote the first thing that came to my mind, but @toggledbits is in fact right.
                      Yes, the rules of comparisons of different types for Expressions are different from the rules in Conditions. In a Condition, the comparison of the string "true" to a boolean attribute with value true will succeed. In Expressions, the JavaScript rules are followed so the equivalent expression's (e.g. "true" == true) result is false (the string is not equal to the boolean because the word contained in the string isn't magical). But in a Condition, the comparison of a non-zero operand to a boolean attribute having value true will be true, and in Expressions following the JavaScript rules will also be true (because in JavaScript and therefore the expression language, non-zero values are equivalent to true, and 0 is equivalent to false). Basically, in Expressions the strings are treated more strictly by their type, as in JavaScript, and there are no "magic values" (like the word "true") that are understood to mean something else. In Conditions, because all operands are strings, some back office magic happens to try to interpret what to do, otherwise no comparison to anything other than a string could work at all.
                      This may seem inconsistent across the product but it's something I'm unlikely to change as (a) relaxing it in Expressions promotes sloppy construction of expressions, and (b) Expressions are and always have been (even in R4V) an advanced user feature and it is my expectation that advanced users learn the rules of the language, as they would for any language (e.g. Lua). In Conditions and Actions (of Reactions), all operands and parameters are always strings; they need to be manipulated for Conditions to do comparisons, or for Actions to produce the right parameters for the target device or hub. In Expressions, the values are determined by the subexpression that produces them (e.g. "1" produces a string type result, where 1 produces a numeric result, [1] produces an array containing a numeric, and ["1"] produces an array containing a string).
                      I also note your expression if MaxInterval-CurrentTemp > 15 then true else false end, is a bit redundant from a programmer's perspective. In this construction, MaxInterval -CurrentTemp > 15 on its own produces true or false (the > operator always produces a boolean result), so you don't need the branches of the if...else..end construction here, the greater-than test itself can be the entire expression: MaxInterval-CurrentTemp > 15 alone will work the same and be more efficient. Adding the if block just makes extra work.
                        I appreciate both the strictness regarding code and the lesson in javascript. Thanks!
                        I've found out why my "MaxInInterval" didn't work in the original post, and what that "Force re-evaluation..." tickbox on the reactions does!
                        (to type it out, I changed the variable in reaction, and naturally, the only variable being updated was the one called out..)
                          164.9k
