  4. [SOLVED] Sprinkler control: one or both of two conditions to prevent watering
Reset attribute value of entity in event handler
Need help figuring out how to delay a reset on reaction
Way to search for rules (rule state) in other rules
@toggledbits, not sure if this is a feature request or I'm using the search tool wrong. You have a "Search for rule" in the Rules Set tab in MSR. It works nicely to find a rule and bring up said rule, but can it/could it be used for as a "where used?" global search? For instance, I have a fairly large set of rules, divided up into 10 different rulesets. There's easily a hundred individual rules, and many of the rules have Rule State triggers, which of course refer to other rules. Amongst my troubleshooting today, I came across what may have been a duplicate or troubleshooting attempt, but I can't tell if it's actually used as a Rule State in another rule without opening each rule that I suspect it may be a part of. Thanks.
Links to MSR from HA
Tom_DT
I am using Home Assistant a lot recently. On a dashboard showing the devices, I would like to show a link to the MSR rule that controls the devices. Is there a way to link directly into MSR?
Set Reaction > Script Action
Errors after updating to MQTTController build 25139
I'm running MSR build 25139 on Docker, using MQTT controller 24293, and everything working as expected. But if I try to upgrade to MQTTController build 25139, I'm getting the following errors on MSR UI: An Entity Attribute condition in "Lay-Z-Spa auto heating off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.god Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa auto heating off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute temperature_sensor.green Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa filter pump auto off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute temperature_sensor.red Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa filter pump auto run" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.pump Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa watchdog" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.status Last 11:20:37 My MQTT configuration (local_mqtt_devices.yaml) for the related entity is: layzspa_message: type: ValueSensor capabilities: ["temperature_sensor", "value_sensor", "power_sensor"] primary_attribute: power_sensor.value events: "layzspa/message": "power_sensor.value": json_payload: true if_expr: '! isnull( payload?.PWR )' expr: "float(payload.PWR)" "value_sensor.air": json_payload: true if_expr: '! isnull( payload?.AIR )' expr: "float(payload.AIR)" "value_sensor.pump": json_payload: true if_expr: '! isnull( payload?.FLT )' expr: "float(payload.FLT)" "value_sensor.god": json_payload: true if_expr: '! isnull( payload?.GOD )' expr: "float(payload.GOD)" "value_sensor.lock": json_payload: true if_expr: '! isnull( payload?.LCK )' expr: "float(payload.LCK)" "value_sensor.unit": json_payload: true if_expr: '! isnull( payload?.UNT )' expr: "float(payload.UNT)" "value_sensor.error": json_payload: true if_expr: '! isnull( payload?.ERR )' expr: "float(payload.ERR)" "temperature_sensor.green": json_payload: true if_expr: '! isnull( payload?.GRN )' expr: "float(payload.GRN)" "temperature_sensor.red": json_payload: true if_expr: '! isnull( payload?.RED )' expr: "float(payload.RED)" "temperature_sensor.target": json_payload: true if_expr: '! isnull( payload?.TGT )' expr: "float(payload.TGT)" "temperature_sensor.value": json_payload: true if_expr: '! isnull( payload?.TMP )' expr: "float(payload.TMP)" "temperature_sensor.virtual": json_payload: true if_expr: '! isnull( payload?.VTM )' expr: "round(float(payload.VTM), 1)" "temperature_sensor.ambient": json_payload: true if_expr: '! isnull( payload?.AMB )' expr: "float(payload.AMB)" "layzspa/Status": "value_sensor.status": if_expr: '! isnull( payload )' expr: "payload" "layzspa/button": "value_sensor.button": if_expr: '! isnull( payload )' expr: "payload" and in reactor.yaml I have: "layzspa_states": name: "Lay-Z-Spa States" friendly_name: 'Lay-Z-Spa States' include: layzspa_message I realize my MQTT configuration might be a bit unorthodox, but could there still be something unintentional in the latest MQTTController build? If needed, I can provide detailed logs.
🎉 My very first MSR controller: OpenSprinkler
Since today is my birthday - and I still pretend to be unconventional - I'm giving away a present to this wonderful community and I'm releasing my first OpenSprinkler controller for MSR. It was real fun to code it - and while it's still WIP, it seems to work OK for me. It's polling-based at the moment, but I'll add support for updates via MQTT very soon (it's already partially coded). Get it at (install is similar to MQTTController and such): https://github.com/dbochicchio/reactor-opensprinkler Feel free to try it. It's beta software, but it's stable. I'll update it weekly until all the tasks from my todo list are empty. Since I've learnt a lot from this controller, I'll explore new controllers soon.
Advice reqeusted to migrate MSR from Bare Metal to Container
Good day all, I'm in the process of trying to shut down my 10 year old Linux home server that served many purposes, but primarily it's what I used for my NAS/Plex Media server. I migrated the NAS aspect of the server in November of last year to a true NAS solution (Ubiquti UNAS Pro), which is rack mount and much more efficient than my old tower, which it's only side benefit was heating my home office during the winter. Unfortunately it also means heating my home office during the summer, which were about to be in full swing. I have two things running on this 10 year old server at this point. MSR and pi-hole. I'm running Plex Media Server on Fedora Workstation in Podman on mini PC, which is much more energy efficient than my old tower. My next step is to migrate MSR. I know there are images of MSR out there, and creating it is well documented. I'm going to be using Podman instead of Docker for various reasons, but they work very similar. What I don't know, is what I need to do to migrate my existing Bare Metal installation over to a container. Has anyone done this? Any advice?
Can´t restart or upgrade/deploy MSR
[Solved] Limit HA Entity in MSR
Organizing/ structuring rule sets and rules
Hi guys, Just wondering how you guys organize your rule sets and rules. I wish I had an extra layer to have some more granularity, but my feature request was not popular. Maybe there are better ways to organize my rule sets. I use the rule sets now primarily for rooms. So a rule set per room. But maybe grouping by functionality works better. Any examples/ suggestions would be appreciated.
Moving MSR from a QNAP container to RP 5 - some issues
Tom_DT
Widget deletion does not work and landing page (status) is empy
Need help reducing false positive notifications
Deleting widgets
Hopefully a trivial question, but how do you delete widgets in a status page? Using build 22266
MQTT configuration question
I have the following yaml configuration in local_mqtt_devices file x_mqtt_device: set_speed: arguments: speed: type: str topic: "command/%friendly_name%" payload: type: json expr: '{ "fan": parameters.speed }' While this works fine, I'm wondering how this could be changed to "fixed" parameters, as in this case "fan" only accepts "A", "Q" or a numeric value of 1-5?
System Configuration Check - time is offset
Hi! I get this message when I'm on the status tab: System Configuration Check The time on this system and on the Reactor host are significantly different. This may be due to incorrect system configuration on either or both. Please check the configuration of both systems. The host reports 2025-04-01T15:29:29.252Z; browser reports 2025-04-01T15:29:40.528Z; difference 11.276 seconds. I have MSR installed as a docker on my Home Assistant Blue / Hardkernel ODROID-N2/N2+. MSR version is latest-25082-3c348de6. HA versions are: Core 2025.3.4 Supervisor 2025.03.4 Operating System 15.1 I have restarted HA as well as MSR multiple times. This message didn´t show two weeks ago. Don´t know if it have anything to do with the latest MSR version. Do anyone know what I can try? Thanks in advance! Let's Be Careful Out There (Hill Street reference...) /Fanan
Programmatically capture HTTP Request action status code or error
I have a very strange situation, where if InfluxDB restarts, other containers may fail when restarting at the same time (under not easy to understand circumstances), and InfluxDB remains unreachable (and these containers crashes). I need to reboot these containers in an exact order, after rebooting InfluxDB. While I understand what's going on, I need a way to reliable determine that InfluxDB is not reachable and these containers are not reachable, in order to identify this situation and manually check what's going on - and, maybe, in the future, automatically restart them if needed. So, I was looking at HTTP Request action, but I need to capture the HTTP response code, instead of the response (becase if ping is OK, InfluxDB will reply with a 204), and, potentially, a way to programmatically detect that it's failing to get the response. While I could write a custom HTTP controller for this or a custom HTTP virtual device, I was wondering if this is somewhat on you roadmap @toggledbits Thanks!
ZwaveJSUI - RGBWW BULB - Warm/Cold White interfered with RGB settings - Bulb doesn't change color if in WarmWhite state.
Hi , I'm on -Reactor (Multi-hub) latest-25067-62e21a2d -Docker on Synology NAS -ZWaveJSUI 9.31.0.6c80945 Problem with ZwaveJSUI: When I try to change color to a bulb RGBWW, it doesn't change to the RGB color and the bulb remains warm or cold white. I tryed with Zipato RGBW Bulb V2 RGBWE2, Hank Bulb HKZW-RGB01, Aentec 6 A-ZWA002, so seems that it happens with all RGBWW bulb with reactor/zwavejsui. I'm using from reator the entity action: "rgb_color.set" and "rgb_color.set_rgb". After I send the reactor command, It changes in zwavejsui the rgb settings but doesn't put the white channel to "0", so the prevalent channel remains warm/cold White and the bulb doesn't change into the rgb color. This is the status of the bulb in zwavejsui after "rgb_color.set" (235,33,33,) and the bulb is still warmWhite. x_zwave_values.Color_Switch_currentColor={"warmWhite":204,"coldWhite":0,"red":235,"green":33,"blue":33} The "cold white" and "warm white" settings interfer with the rgb color settings. Reactor can change bulb colors with rgb_color set — (value, ui8, 0x000000 to 0xffffff) or rgb_color set_rgb — (red, green, blue, all ui1, 0 to 255) but if warm or cold white are not to "0", zwavejsui doesn't change them and I can't find a way to change into rgb or from rgb back to warm white. So if I use from reactor: rgb_color set_rgb — (235,33,33) in zwavejsui I have x_zwave_values.Color_Switch_targetColor={"red":235,"green":33,"blue":33} 14/03/2025, 16:43:57 - value updated Arg 0: └─commandClassName: Color Switch └─commandClass: 51 └─property: targetColor └─endpoint: 0 └─newValue └──red: 235 └──green: 33 └──blue: 33 └─prevValue └──red: 235 └──green: 33 └──blue: 33 └─propertyName: targetColor 14/03/2025, 16:43:57 - value updated Arg 0: └─commandClassName: Color Switch └─commandClass: 51 └─property: currentColor └─endpoint: 0 └─newValue └──warmWhite: 204 └──coldWhite: 0 └──red: 235 └──green: 33 └──blue: 33 └─prevValue └──warmWhite: 204 └──coldWhite: 0 └──red: 235 └──green: 33 └──blue: 33 └─propertyName: currentColor In zwavejsui, the bulb changes rgb set but warm White remains to "204" and the bulb remais on warm White channel bacause is prevalent on rgb set. x_zwave_values.Color_Switch_currentColor_0=204 x_zwave_values.Color_Switch_currentColor_1=0 x_zwave_values.Color_Switch_currentColor_2=235 x_zwave_values.Color_Switch_currentColor_3=33 x_zwave_values.Color_Switch_currentColor_4=33 Is it possible to targetColor also for "warmWhite" and "coldWhite" and have something similar to this? x_zwave_values.Color_Switch_targetColor={"warmWhite":0,"coldWhite":0,"red":235,"green":33,"blue":33} Thanks in advance.
solved
10 Posts 2 Posters 548 Views 2 Watching
    I think I'm just staring at this too hard so I'm opening up to the collective.
    Scenario: water the gardens at XX time unless one or both of the following are TRUE:
    • More than .25" of rain has fallen yesterday (I have an entity for this)
    • It is currently raining (I have an entity for this)
    I had it set to OR and that (obviously) doesn't work because, whilst first bullet was TRUE second bullet was FALSE and so the water flowed.
    I'm thinking, atm, of something using Reaction>Group and building out something that isolates the conditions vs making them an OR.
    Am I on the right path here?
    *Hubitat C-7 2.4.1.177
    *HASS 2025.6.0
    w/ ZST10-700 fw 7.18.3
    MSR: latest-25139-fbd67abc
      In staring even harder I came up with this:
      Since image functionality is STILL BROKEN on this forum (but, oh, it LOOKS pretty)...
      Triggers not or
      Comment: This is a NOT rule. If either of these conditions are NOT true then this rule is FALSE. (If the rainfall total either yesterday or today is more than 1/4" then FALSE).
      Entity Attribute: Weatherflow Precipitation Yesterday (hass>sensor_weatherflow_precipitation_yesterday) value_sensor.value <= 0.25
      OR Entity Attribute: Weatherflow Precipitation Today (hass>sensor_weatherflow_precipitation_today) value_sensor.value <= 0.25
      Currently, there was 1.61" of rain yesterday so the outcome is false and there has been no rain today so that outcome is true - as such the ruleset is rendered false.
      Is my thinking sound here?
      *HASS 2025.6.0
        So basically the way you have your rule structured right now is that the group will go true either when it rains more than 0.25" or its currently raining. Which is the opposite of what you'd want. As you mentioned in your recent post switching this to a not or operator should fix it. Meaning the group will be true if it hasn't rained more than 0.25" yesterday or is currently raining.
          @Pabla Thanks!
          I altered the premise very slightly to be rain amounts on both days because, hey, it might be actually raining right then but it might be a very slight passing shower which doesn't end up providing the needed water amount.
          The updated version looks at amounts on both days, instead.
          *HASS 2025.6.0
          PablaP 1 Reply Last reply
            @Pabla Thanks!
            @gwp1 Excellent! Regardless of condition the not operator should do the trick
              @Pabla Hmmm. We've had a sudden storm that has dropped 2" of rain today. As such both Conditions are now false and then ruleset has gone SET.
              SO... testing, when I flip the criteria of the Conditions to >= .25 both go true and the ruleset goes false.
              I did a quick test and, yes, it appears by bumping one of the two Conditions to be silly high like 5" (so today's actual is less than that) it makes one Condition true and one false and the ruleset remains as unset. Bumping both to be silly high (so both actuals are less than that) makes the ruleset toggle to SET which is the desired outcome. Any or both of the Conditions being TRUE toggles the ruleset unset. Both conditions being false toggles the ruleset TRUE.
              The expectation is that tomorrow morning there will be no flow of water as at least today's Condition is true so no matter what tomorrow's is (between midnight and 0600 ET) this ruleset will not SET.
              *HASS 2025.6.0
                @gwp1 I am not sure I am quite following. Are you saying that when both conditions: Rain amount yesterday and Rain amount today are true (meaning a certain amount of rain has fallen either yesterday or today) that the ruleset still goes true and waters the garden?
                  @Pabla
                  @gwp1 said in [SOLVED] Sprinkler control: one or both of two conditions to prevent watering:
                  So the settings are as such now:
                  Triggers [not or]
                  Entity Attribute: Weatherflow Precipitation Yesterday (hass>sensor_weatherflow_precipitation_yesterday) value_sensor.value >= 0.25
                  OR Entity Attribute: Weatherflow Precipitation Today (hass>sensor_weatherflow_precipitation_today) value_sensor.value >= 0.25
                  Right now the first one is true and the second is false. As such, the rule is RESET. Unless we get rain between now and tomorrow morning, the "yesterday" will roll off and "today" will become "yesterday" and both Conditions will be be false and the rule will change to SET and the water will flow.
                  *HASS 2025.6.0
                    Ah I see but isn't that what you'd expect? Say yesterday you got over 0.25 (inches?) of rain and today you got 0.23. This would mean your garden will not be watered.
                    Lets say no rain falls between today and tomorrow. That means when tomorrow rolls over yesterdays rain total now becomes 0.23 and todays is 0. Based on that info you'd want your garden to be watered.
                    To me the ruleset is working as intended, if you still wouldn't want it to water I would set your "todays" threshold a little lower.
                      @Pabla The original Conditions were <= .25 whereas the working version had to be flipped to >= .25. That's what ultimately made it work.
                      *HASS 2025.6.0
                      • Reset attribute value of entity in event handler
                        RHCPNG
                      • Need help figuring out how to delay a reset on reaction
                        165
                      • Way to search for rules (rule state) in other rules
                      • Links to MSR from HA
                        Tom_DT
                        Tom_D
                      • Set Reaction > Script Action
                      • Wiring Samotech SM308-S into light fitting
                      • Errors after updating to MQTTController build 25139
                      • 🎉 My very first MSR controller: OpenSprinkler
                        772
                      • Advice reqeusted to migrate MSR from Bare Metal to Container
                        48.3k
                      • Z-Wave Future....
                      • Can´t restart or upgrade/deploy MSR
