  3. Block Code (Fenced) formatting issues in new forums
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
6 Posts 2 Posters 3.7k Views 2 Watching
    @DesT, fenced code blocks display differently after the upgrade.
    abc
    def
    The above should display as abc and def on two separate lines. This works. But this fails:
    verbose: true
    config:
      data: "auto"
    The above should display as three lines, verbose: true, config: and data: "auto", but this fails. In order to make it display properly, I now have to open the fenced code block with ```text (specify language, generic text). This displays without highlighting. The words yml and yaml (and the all-caps versions) don't seem to be recognized. I can also use js to get JavaScript highlighting, but this isn't great for YAML. Here's the same block with the language (text) specifier added (no other changes):
    verbose: true
    config:
      data: "auto"
    Sure, we can start adding language specifiers to our new posts, but I suspect if we start digging around old posts, we're going to find a lot of broken display of the fenced code blocks (plain ``` at the start with no language specifier) in the thousands of old posts in these forums, upon which people still rely for answers and information.
    Log file snippets also get similarly brutalized:
    [###BUILDVERSION###]2023-04-26T19:41:51.683Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log
    [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming
    [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming
    [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming
    [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming
    [###BUILDVERSION###]2023-04-26T19:41:51.837Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.0.10:3000
    [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected
    [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization
    [###BUILDVERSION###]2023-04-26T19:41:51.931Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "10.16.0", "serverVersion": "1.28.0", "homeId": 3631280043, "minSchemaVersion": 0, "maxSchemaVersion": 28 }
    [###BUILDVERSION###]2023-04-26T19:41:51.932Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing initial inventory
    [###BUILDVERSION###]2023-04-26T19:41:52.325Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 134 (AEON Labs) from package ver 22315.1
    [###BUILDVERSION###]2023-04-26T19:41:52.328Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 1 endpoint 0 (entity "1-0")
    [###BUILDVERSION###]2023-04-26T19:41:52.339Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 543 (Elexa Consumer Products Inc.)
    I think this is going to be a problem. Is there a way in NodeBB to configure the default language for fenced code block markdown for the entire forum so that these display more as they did before the upgrade?
    EDIT: Examples below of old posts with corrupt formatting now:
    https://smarthome.community/topic/1101/dynamic-groups-controller-filter-expressions
    https://smarthome.community/post/11362
    This last old post is interesting, because the first block displays incorrectly, but the second block is OK. In playing around, there seem to be triggering character sequences, suggesting that the markdown processor is trying to "guess" the language but not getting it right, perhaps:
    https://smarthome.community/post/11332
    • DesTD Offline
      DesTD Offline
      DesT
      @toggledbits I will try to check that this week!
      • DesTD Offline
        DesTD Offline
        DesT
        Much better now? 😉
          After a page refresh, looking better. I'll look around at some other places...
          • DesTD DesT
            Much better now? 😉
            @DesT Better, but still not perfect. The first link I gave above, when I go to it... it takes a long time to load, and while it's loading, the fenced code is properly displayed but all monochrome (no highlighting). Like this:
            When the page finally finishes loading (30-45 seconds for me), it goes back to this (broken, see initial block, block after now in color highlight):
            • DesTD Offline
              DesTD Offline
              DesT
              I think it's better now BUT I had to disable auto detect code...
                157.6k
