  4. [SOLVED] New iblind and zwaveJScontroller/MSR not communicating
solved
44 Posts 3 Posters 22.1k Views 3 Watching
    I installed a new iblind this evening and it is appearing in ZWaveJS. It is operational thru Home Assistant just fine. It is operational thru the HA ZwaveJS plugin just fine.
    Where it is non-responsive is in MSR for some reason. The entities are there. Adding the node to a Reaction and then attempting to run said Reaction nets me this:
    [latest-23242]2023-09-08T05:33:08.454Z <ZWaveJSController:5:ZWaveJSController.js:655> ZWaveJSController#zwavejs _apply_value motion_sensor.state=false
    [latest-23242]2023-09-08T05:33:08.455Z <ZWaveJSController:5:ZWaveJSController.js:722> ZWaveJSController#zwavejs setting Binary Sensor#zwavejs>11-0.x_zwave_values.Binary_Sensor_Motion to false
    [latest-23242]2023-09-08T05:33:08.692Z <ZWaveJSController:5:ZWaveJSController.js:360> ZWaveJSController#zwavejs handling node event statistics updated entity Binary Sensor#zwavejs>11-0
    [latest-23242]2023-09-08T05:40:23.960Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing cover.open on Cover#zwavejs>20-0 with [Object]{  }
    [latest-23242]2023-09-08T05:40:23.962Z <ZWaveJSController:5:ZWaveJSController.js:1843> ZWaveJSController#zwavejs no implementation mapped; attempting default
    [latest-23242]2023-09-08T05:40:25.062Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing zwave_device.refresh on Cover#zwavejs>20-0 with [Object]{  }
    **[latest-23242]2023-09-08T05:40:25.063Z <ZWaveJSController:5:ZWaveJSController.js:1843> ZWaveJSController#zwavejs no implementation mapped; attempting default**
    [latest-23242]2023-09-08T05:40:25.065Z <ZWaveJSController:5:ZWaveJSController.js:294> ZWaveJSController#zwavejs sending #1694151625064<9/8/2023, 1:40:25 AM>: [Object]{ "command": "node.refresh_values", "nodeId": 20, "messageId": 1694151625064 }
    [latest-23242]2023-09-08T05:40:26.307Z <ZWaveJSController:5:ZWaveJSController.js:360> ZWaveJSController#zwavejs handling node event statistics updated entity Cover#zwavejs>20-0
    [latest-23242]2023-09-08T05:40:26.317Z <ZWaveJSController:5:ZWaveJSController.js:360> ZWaveJSController#zwavejs handling node event value updated entity Cover#zwavejs>20-0
    [latest-23242]2023-09-08T05:40:26.318Z <ZWaveJSController:5:ZWaveJSController.js:667> ZWaveJSController#zwavejs update node 20 value "0:128:level:" data [Object]{ "source": "node", "event": "value updated", "nodeId": 20, "args": { "commandClassName": "Battery", "commandClass": 128, "property": "level", "endpoint": 0, "newValue": 100, "prevValue": 100, "propertyName": "level" } }
    [latest-23242]2023-09-08T05:40:26.319Z <ZWaveJSController:5:ZWaveJSController.js:684> ZWaveJSController#zwavejs updating attributes for node 20 value "0:128:level:"=100: [Array][ "battery_power.level", "battery_power.since" ]
    [latest-23242]2023-09-08T05:40:26.320Z <ZWaveJSController:5:ZWaveJSController.js:698> ZWaveJSController#zwavejs updating attribute battery_power.level with [Object]{ "entity": "20-0", "impl": { "expr": "float( value ) / 100", "valueId": "128:level:" } }
    [latest-23242]2023-09-08T05:40:26.321Z <ZWaveJSController:5:ZWaveJSController.js:591> ZWaveJSController#zwavejs _apply_value entity Cover#zwavejs>20-0 battery_power.level
    [latest-23242]2023-09-08T05:40:26.322Z <ZWaveJSController:5:ZWaveJSController.js:655> ZWaveJSController#zwavejs _apply_value battery_power.level=1
    [latest-23242]2023-09-08T05:40:26.323Z <ZWaveJSController:5:ZWaveJSController.js:698> ZWaveJSController#zwavejs updating attribute battery_power.since with [Object]{ "entity": "20-0", "impl": { "expr": "time()", "valueId": "128:level:" } }
    [latest-23242]2023-09-08T05:40:26.323Z <ZWaveJSController:5:ZWaveJSController.js:591> ZWaveJSController#zwavejs _apply_value entity Cover#zwavejs>20-0 battery_power.since
    [latest-23242]2023-09-08T05:40:26.324Z <ZWaveJSController:5:ZWaveJSController.js:655> ZWaveJSController#zwavejs _apply_value battery_power.since=1694151626324<9/8/2023, 1:40:26 AM>
    [latest-23242]2023-09-08T05:40:26.325Z <ZWaveJSController:5:ZWaveJSController.js:722> ZWaveJSController#zwavejs setting Cover#zwavejs>20-0.x_zwave_values.Battery_level to 100
    [latest-23242]2023-09-08T05:40:26.333Z <ZWaveJSController:5:ZWaveJSController.js:360> ZWaveJSController#zwavejs handling node event value updated entity Cover#zwavejs>20-0
    [latest-23242]2023-09-08T05:40:26.334Z <ZWaveJSController:5:ZWaveJSController.js:667> ZWaveJSController#zwavejs update node 20 value "0:128:isLow:" data [Object]{ "source": "node", "event": "value updated", "nodeId": 20, "args": { "commandClassName": "Battery", "commandClass": 128, "property": "isLow", "endpoint": 0, "newValue": false, "prevValue": false, "propertyName": "isLow" } }
    [latest-23242]2023-09-08T05:40:26.336Z <ZWaveJSController:5:ZWaveJSController.js:324> ZWaveJSController#zwavejs request 1694151625064<9/8/2023, 1:40:25 AM> (node.refresh_values) success notification
    [latest-23242]2023-09-08T05:40:26.337Z <ZWaveJSController:5:ZWaveJSController.js:684> ZWaveJSController#zwavejs updating attributes for node 20 value "0:128:isLow:"=false: [Array][  ]
    [latest-23242]2023-09-08T05:40:26.338Z <ZWaveJSController:5:ZWaveJSController.js:722> ZWaveJSController#zwavejs setting Cover#zwavejs>20-0.x_zwave_values.Battery_isLow to false
    [latest-23242]2023-09-08T05:40:26.558Z <ZWaveJSController:5:ZWaveJSController.js:360> ZWaveJSController#zwavejs handling node event statistics updated entity Cover#zwavejs>20-0
    Please note the highlighted logpart - no other iblind has this. In addition, in MSR>Entities several show as null rather than having a value as the others do.
    I tried deleting all Entities associated with this device from MSR and then refreshing ZWaveJS in Home Assistant and restarting MSR - the Entities return but in the same state/s.
    Admittedly, it's been a very long three weeks at work - I could have missed something obvious during setup but I sure can't figure what it is.
      Can you paste all of the attributes for zwavejs>20-0? There's a "Copy Attributes" button when you expand the entity in the Entities list. Remember to format it as code when pasting here.
      I'm heading to a field training exercise, so I may not get a chance to look at this in depth until late Sunday.
        @toggledbits As requested:
        battery_power.since=1694178019327
        cover.state=null
        position.value=null
        x_debug.dt={"entity_class":"Cover","match":"deviceClass.generic.key=17;deviceClass.specific.key=7","capabilities":["cover","toggle","position"],"primary_attribute":"cover.state","description":"Window Blind Controller","model":"iblinds V3","default_name":"Window Blind Controller","values":[{"valueId":"38:currentValue:","capabilities":{"cover":{"attributes":{"state":{"expr":"!(value == 0 || value >= 99)"}},"actions":{"open":{"valueId":"38:targetValue:","value":50},"close":{"valueId":"38:targetValue:","value":99},"stop":false}},"position":{"attributes":{"value":{"expr":"round( value / 99, 2 )"}},"actions":{"set":{"valueId":"38:targetValue","value":{"expr":"max( 0, min( 99, round( 100 * ( parameters.value ?# 0 ), 0 ) ) )"}},"increase":{"valueId":"38:targetValue","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) + ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}},"decrease":{"valueId":"38:targetValue","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) - ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}},"relative":{"valueId":"38:targetValue","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) + ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}}}},"toggle":{"actions":{"toggle":{"valueId":"38:targetValue:","value":{"expr":"entity.attributes.cover.state ? 99 : 50"}}}}}}],"manufacturerId":647,"productType":4,"productId":113}
        x_zwave_values.Battery_isLow=false
        x_zwave_values.Battery_level=100
        x_zwave_values.Configuration_Close_Interval=15
        x_zwave_values.Configuration_Default_ON_Value=50
        x_zwave_values.Configuration_MC=1
        x_zwave_values.Configuration_Maximum_Tilt_Level=99
        x_zwave_values.Configuration_Minimum_Tilt_Level=0
        x_zwave_values.Configuration_Movement_Duration=0
        x_zwave_values.Configuration_Override_Response_to_ON_Command=null
        x_zwave_values.Configuration_Remote_Calibration=1
        x_zwave_values.Configuration_Reset_Button=0
        x_zwave_values.Configuration_Reverse_Direction=1
        x_zwave_values.Configuration_Send_Reports=0
        x_zwave_values.Indicator_Node_Identify_3=0
        x_zwave_values.Indicator_Node_Identify_4=0
        x_zwave_values.Indicator_Node_Identify_5=0
        x_zwave_values.Indicator_identify=true
        x_zwave_values.Indicator_timeout=null
        x_zwave_values.Indicator_value=null
        x_zwave_values.Manufacturer_Specific_manufacturerId=647
        x_zwave_values.Manufacturer_Specific_productId=114
        x_zwave_values.Manufacturer_Specific_productType=4
        x_zwave_values.Version_applicationBuildNumber=43707
        x_zwave_values.Version_applicationFrameworkAPIVersion="3.12.1"
        x_zwave_values.Version_applicationFrameworkBuildNumber=35
        x_zwave_values.Version_applicationVersion="3.12.1"
        x_zwave_values.Version_firmwareVersions=["3.12"]
        x_zwave_values.Version_hardwareVersion=2
        x_zwave_values.Version_hostInterfaceBuildNumber=0
        x_zwave_values.Version_hostInterfaceVersion="unused"
        x_zwave_values.Version_libraryType=3
        x_zwave_values.Version_protocolVersion="7.12"
        x_zwave_values.Version_sdkVersion="7.12.2"
        x_zwave_values.Version_zWaveProtocolBuildNumber=35
        x_zwave_values.Version_zWaveProtocolVersion="7.12.2"
        x_zwave_values.Window_Covering_currentValue_23=0
        x_zwave_values.Window_Covering_duration_23={"value":0,"unit":"seconds"}
        x_zwave_values.Window_Covering_levelChangeDown_23=false
        x_zwave_values.Window_Covering_levelChangeUp_23=true
        x_zwave_values.Window_Covering_targetValue_23=0
        zwave_device.capabilities=[106,112,114,128,134,135]
        zwave_device.endpoint=0
        zwave_device.failed=false
        zwave_device.generic_class="Multilevel Switch"
        zwave_device.impl_sig="23052:1:23093:1"
        zwave_device.is_beaming=false
        zwave_device.is_listening=false
        zwave_device.is_routing=true
        zwave_device.is_secure=false
        zwave_device.manufacturer_info=[647,4,114]
        zwave_device.node_id=20
        zwave_device.specific_class="Motor Control Class C"
        zwave_device.status=4
        zwave_device.status_text="alive"
        zwave_device.version_info=[null,"3.12.1"]
        I may try removing the device completely and repairing if you think that might have benefit.
          Look at the file called 647.yaml in ext/ZWaveJSController/manufacturer and check the version. It should be 23093. And your ext/ZWaveJSController/zwave_devices.yaml file should be version 23194.
          If these numbers don't match up, update your ZWaveJSController.
          Download: https://reactor.toggledbits.com/download/extras/ZWaveJSController/
            Also, did you restart Reactor after adding the node?
              @toggledbits Answering in reverse order: yes on restart of MSR (multiple times). Also reloaded the HA ZWaveJS plugin as well as restarted HA as a whole.
              The the first ask:
              647.yaml
              manufacturer_id: 647
              manufacturer_name: "HAB Home Intelligence, LLC"
              version: 23093
              revision: 1
              format: 1
              and I do not have a ext/ZWaveJSController/zwave_devices.yaml but do have a ext/ZWaveJSController/zwavejs_devices.yaml and it shows
              version: 23052
              revision: 1
              format: 1
              Looking in my files I see the latest version was 23093 so I'm grabbing 23094 from your repo and installing now.
                Looks like your Hass devices aren't actually faring much better... nulls there too for some values, and that's a straight pass from Hass itself, not likely something MSR is doing (or not doing).
                Something off about this device. I'm going to PM you instructions to upload a data file from your system.
                  The the first ask:
                  647.yaml
                  version: 23093
                  revision: 1
                  format: 1
                  version: 23052
                  revision: 1
                  format: 1
                  @toggledbits Ok, release deployed.
                  ext/ZWaveJSController/zwavejs_devices.yaml now shows
                  version: 23194
                  revision: 1
                  format: 1
                  647.yaml still shows
                  version: 23093
                  revision: 1
                  format: 1
                  Node attributes:
                  battery_power.since=1694192043559
                  cover.state=null
                  position.value=null
                  zwave_device.impl_sig="23194:1:23093:1"
                  (Did a manual restart via Tools>Restart after the deploy as well.
                    Yeah, this device is off. It's reporting Multilevel Switch for its generic class, and Motor Control Class C as the more specific, and usually this device class reports command class 38, Multilevel Switch. That's how your other iBlinds units that identify the same way (same 647 manufacturer ID, product type 4, product ID 114) work. But this particular unit does not appear to be advertising command class 38 Multilevel Switch, and is instead reporting command class 106 Window Covering, which is relatively new.
                    Once you upload the data I PM'd you about, I'll be curious to see how the reporting firmware compares. But this new unit is definitely working differently from everything else you have, and it doesn't look like HA actually likes it any better -- I think that's why it's reporting the slats angle in HA as null; I bet it shows the same in their dashboard.
                    I'll know more/confirm once I see you data. Probably won't get to that until Sunday or Monday at this point, though.
                      @toggledbits file has been uploaded. This blind is in a guest room that's not in use currently - no rush.
                      Do you think excluding/including with HA/ZWjs would have any effect? Could something have gone sideways during pairing that a complete redo might clear?
                        ZWaveJSController version 23254 has been released. It should handle your oddball iBlinds unit. I'd love to know (not from you, from the manufacturer) what triggers the difference between reporting status in command class 38 versus command class 106 -- only this most recent unit of yours reports/controls via 106; all of the others use 38. And there's no difference in reported model or firmware version. No obvious configuration parameter that might trigger such a difference (e.g. some others, like some Aeotec devices, can change the reporting CC based on a config parameter). Just goes to show you that despite a fairly strict standard and specification, manufacturers can continue to make subtle choices that create headaches.
                        G 2 Replies Last reply
                          @toggledbits this was deployed and tests as working. Really appreciate it - I bought two new units and have held off installing the second until it was determined not to be a firmware problem (broken vs them just randomly changing something).
                          Thank you!
                            @toggledbits I contacted iblinds Support. This was their response:
                            *We've had similar reports. I believe it is related to a recent update with Home Assistant supporting the Z-Wave Window Covering Command Class now. So when you add your new devices they are seen with the new command class. I would imagine if you excluded and included one of the older motors they would now be Window Covering devices as opposed to multi-level switches.
                            We initially worked with the ZWaveJS developer when they added the Window Covering CC Support. But unfortunately, our HA in our lab is no longer working so we have been unable to test locally.
                            We have been waiting to get a replacement RPi so hopefully we can do some testing on our end soon.
                            I hope this helps.
                            Best Regards,
                            Eric B.
                            The iblinds Team*
                            Further, I just discovered if I do a reinterview on an existing blind via ZWaveJS in HA it switches to this new Window Covering mode.
                              I hope this helps.
                              Best Regards,
                              Eric B.
                              The iblinds Team*
                              @gwp1 said in [SOLVED] New iblind and zwaveJScontroller/MSR not communicating:
                              For what it's worth, I have both v2 and v3.1 iBlinds in my home. Reinterviewing only changes the type from multilevel switches to window covering on v3.1 blinds. Version 2 blinds remain multilevel switches after reinterviewing.
                              The Window Covering class is supposedly better. The MLS class is designed for rolling blinds, so on/off will have the bllinds all the way open, or all the way off. With horizonal blinds, the 0/100 values are just 180 degree opposites of a closed blind. With Window Covering class, I believe there are values to tell the Z-Wave system what type of blind it is, and specify what is open versus closed. I dealt with iBlinds support maybe 4 or 5 months ago, and at the time, no Z-Wave system supported Window Covering. Zwave JS implemented the change shortly thereafter.
                              • T tamorgen
                                @tamorgen I'm poking at it now. It seems for the iblinds I can now use cover.close and the [0] NO (default) setting for direction vs having it set to [1] YES to make it tilt the way I want it to when closed.
                                I was using power_switch.off previously to close my v3.1's.
                                • T tamorgen
                                  UPDATE: after many lost hours last night/this morning (hello, 0230 ET, looking at you) I found cover.x and power_switch.x to be woefully unreliable after reinterviewing the blinds.
                                  What has proven reliable is position.set for which I use 0 for closed, 50 for open and have the blinds (as they were previously) set to [1] YES for Reverse Direction.
                                    I've been using the ID hass>cover_blind_horizontal_slats_angle and x_hass_cover.open_cover_tilt or x_haas_cover.close_cover_tilt and it works flawlessly for open and close. If I want to set the position for partial close when the sun is glarring into the room, I use x_hass_cover.set_cover_tilt_position with the same ID, and set the tilt_position to whatever I want to reduce the glare.
                                    My only problem now is that I use mushroom for my dashboard in Home Assistant, and the templates for covers hasn't caught up with the new Window Covering class. It makes adjusting the blinds more problematic from HA.
                                      Can you please be more descriptive here? I don't have these devices, so I can't test them, but that doesn't mean I'm not interested in getting them working reliably. But the description given isn't enough for me to do any troubleshooting at all.
                                        @toggledbits of course, no problem! I cannot seem to upload images into this response. I've uploaded to your Dropbox shared folder a pair of images.
                                        Using the iblind I sent you logs and such for previously as the example, I have a blind called Beach Blind (two guest rooms, one is named Ocean, the other Beach). I use the commands from the ID Beach Blind from zwavejs. As @tamorgen notes, there is also a new one (with the changes HA made) from my HASS controller called Beach Blind Horizontal Slates Angle which has a few less commands including those mentioned starting with x_hass_*.
                                        I use the ZwaveJSController commands.
                                        cover.open
                                        cover.close
                                        power_switch.on
                                        power_switch.off
                                        position.set
                                        zwave_device.set_config
                                        These are the ones I most commonly use to open, close, and tilt the blinds. refresh is used to force HA to update dasheboards with any changes and set_config I use less often, weekly, to recalibrate the blinds as they do wander sometimes and "open" becomes "open-ish".
                                        I'd been using power_switch.on to open and cover.close to close. The blinds have been happiest that way. With these new changes from HA, these commands have become hit/miss. In the HA ZWaveJS plugin the status would reflect 0/closed but the blind was clearly wide open.
                                        Last night/this morning I opted to use position.set and it's been pretty solid from what I've seen throughout the day.
                                        position.set = 0 nets me a closed blind, position.set = .5 nets me a wide open/"slates level with the ground" blind. I used position.set = .2 or .3 to tilt the sun away during specific dayparts based on sun azimuth.
                                        I did not grab MSR logs during those tests - apologies, it was 0200 ET and I just wanted the blinds closed for the night. I have amassed 13 of these iblinds over the past couple years.
                                        If you wish, I'll set some time tonight or tomorrow night and generate some MSR logs.
                                          cover.open
                                          cover.close
                                          power_switch.on
                                          power_switch.off
                                          position.set
                                          To be precise, it's not so much a change from HA, but from ZWaveJS. They're recognizing a new command class that the developers at iBlinds actually recommend.
                                          I don't believe the old power switch commands work with the new command class. When I go into a specific device in ZwaveJS, the switch type devices are greyed out.
                                          if you go into the switch, it shows it as unavailable.
                                          I would guess the power on/off cover.close / cover.open are remnants and probably need to be removed.
                                            155.1k
