  3. Plugins
  4. BroadLink Mark II plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
8 Posts 3 Posters 2.9k Views 3 Watching
    The plugin has been updated to ver 0.56 which improves the RF learning procedure. It also recognises some of the newer RM4 devices (thanks Bruce Lacey).
    Existing uses just need to upload the "L_BroadLink_Mk2_1.lua" file.
    RF learning has been improved but is never particularly reliable. You can invoke testing by executing this code in the Lua Test box:
    local DeviceID =  the_id_of_the_IR_child_device
    luup.call_action('urn:a-lurker-com:serviceId:IrTransmitter1', 'LearnRFCode', {}, DeviceID)
    return true
    Running the code illuminates the LED on the BroadLink device. If you do nothing at this point, the learning times out after about 24 seconds and the result is "No RF code was learnt".
    While in the learning mode, tap the remote button to be learnt, every 2/3 of a second or so. If the LED goes out (typically after about say 5 seconds) some result was learnt.
    The result can be found in the parent device by looking at the variable "LearntRFCode". However, it is far easier to look at the log file, which logs the process as it proceeds and also the result. You need to learn a few results to try and determine if the results are at all consistent.
    • A a-lurker
      return true
      @a-lurker said in BroadLink Mark II plugin:
      Presumably, you can also access this from either AltUI or the openLuup console Action page for the device, which would be even easier.
        Yep - many ways to skin a cat but you might only have a dog to work with.
          ronluna
          I tested the latest changes to add support for the RM4 Pro and it created a "IR" Child although it did not list any of the devices that have been created inside the RM4 Pro itself (Probably because is an RF device and that child was not created?). Also the IP set in the plugin attributes is different than the IP This is what the logs are showing:
          2021-04-02 08:53:44.604   luup_log:82: BroadLink_Mk2 debug: The BroadLink device at IP address 10.1.11.126 and of type 0x4e2a is not known to this plugin
          I do have another Broadlink device in the network so I guess is trying to discover that one as well.
          2021-04-02 08:53:44.557   openLuup.scheduler:: [3] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore
          2021-04-02 08:53:44.557   openLuup.scheduler:: [82] BroadLink-Mk2 device startup
          2021-04-02 08:53:44.557   luup_log:82: BroadLink_Mk2 debug: Initialising plugin: BroadLink_Mk2
          2021-04-02 08:53:44.557   luup_log:82: BroadLink_Mk2 debug: Using: Lua 5.1
          2021-04-02 08:53:44.557   luup_log:82: BroadLink_Mk2 debug: 0.57 --> PluginVersion
          2021-04-02 08:53:44.558   luup_log:82: BroadLink_Mk2 debug: Using: dkjson
          2021-04-02 08:53:44.559   luup_log:82: BroadLink_Mk2 debug: Broadcasting discovery message
          2021-04-02 08:53:44.559   luup_log:82: BroadLink_Mk2 debug: 10.1.11.22
          2021-04-02 08:53:44.603   luup_log:82: BroadLink_Mk2 debug: 10.1.11.126
          2021-04-02 08:53:44.604   luup_log:82: BroadLink_Mk2 debug: Rx'ed a discovery response: rxMsg length = 128
          5A A5 AA 55 5A A5 AA 55  00 00 00 00 00 00 00 00   Z..UZ..U........
          00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
          E5 D6 00 00 2A 4E 07 00  00 00 DD 8A EB A7 DF 24   ....*N.........$
          00 00 00 00 2A 4E 0A 01  0B 7E DD 8A EB A7 DF 24   ....*N...~.....$
          E5 A5 A5 E5 85 8B E6 96  AF E7 A9 BA E8 B0 83 00   ................
          00 00 00 00 00 00 00 00  00 00 00 00 00 00 02 01   ................
          2021-04-02 08:53:44.604   luup_log:82: BroadLink_Mk2 debug: Looks like the Cloud bit is set - that's not good
          2021-04-02 08:53:44.604   luup_log:82: BroadLink_Mk2 debug: Friendly name: e5a5a5e5858be696afe7a9bae8b083
          2021-04-02 08:53:45.604   luup_log:82: BroadLink_Mk2 debug: Number of BroadLink devices found is 1
          2021-04-02 08:53:45.604   luup_log:82: BroadLink_Mk2 debug: Header to be sent follows (ex checksum):
          00 00 00 00 9B 64 65 00  00 00 8D DE 18 B0 43 A0   .....de.......C.
          00 00 00 00 FB C8 00 00   ........
          2021-04-02 08:53:45.605   luup_log:82: BroadLink_Mk2 debug: Payload to be sent follows (unencrypted):
          00 00 00 00 A7 C5 DF 0A  91 33 F1 88 C9 82 A5 6D   .........3.....m
          C8 BC F9 DF 00 00 00 00  00 00 00 00 00 00 00 00   ................
          00 00 00 00 00 00 00 00  00 00 00 00 00 01 00 00   ................
          2021-04-02 08:53:45.618   luup_log:82: BroadLink_Mk2 debug: Sending:  Authorisation: txMsg length = 136
          2021-04-02 08:53:45.632   luup_log:82: BroadLink_Mk2 debug: Broadlink device: 649b replied with: 03e9
          2021-04-02 08:53:45.632   luup_log:82: BroadLink_Mk2 debug: Error: errorMsg = fff9
          2021-04-02 08:53:45.632   luup_log:82: BroadLink_Mk2 debug: This device is probably offline - mac address: a0:43:b0:18:de:8d
          2021-04-02 08:53:45.632   luup_log:82: BroadLink_Mk2 debug: k = ir
          2021-04-02 08:53:45.632   luup_log:82: BroadLink_Mk2 debug: a0:43:b0:18:de:8d_ir
          2021-04-02 08:53:45.632   luup_log:82: BroadLink_Mk2 debug: RM4 Pro - IR 1
          2021-04-02 08:53:45.632   luup_log:82: BroadLink_Mk2 debug: urn:schemas-micasaverde-com:device:IrTransmitter:1
          2021-04-02 08:53:45.632   luup_log:82: BroadLink_Mk2 debug: D_BroadLink_Mk2_IrRf_1.xml
          2021-04-02 08:53:45.633   luup_log:82: BroadLink_Mk2 debug: type = function, value = function: 0x1a03140
          2021-04-02 08:53:45.633   luup_log:82: BroadLink_Mk2 debug: {"a0:43:b0:18:de:8d":{"blInternalId":"00000001","blKey":"a7c5df0a9133f188c982a56dc8bcf9df","blDeviceType":25755,"blIp":"10.1.11.20","blDesc":"RM4 Pro"}} --> BroadLinkDevices
          2021-04-02 08:53:45.633   luup.chdev.append:: [a0:43:b0:18:de:8d_ir] RM4 Pro - IR 1
          2021-04-02 08:53:45.633   luup.chdev.sync:: [82] BroadLink-Mk2, syncing children
          2021-04-02 08:53:45.633   luup.set_failure:: status = false
          2021-04-02 08:53:45.633   luup.variable_set:: 82.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: false now: false #hooks:0
          2021-04-02 08:53:45.633   luup.variable_set:: 82.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 1617316371 now: 1617368025 #hooks:0
          2021-04-02 08:53:45.633   openLuup.scheduler:: [82] BroadLink-Mk2 device startup completed: status=true, msg=All OK, name=BroadLink_Mk2
          Any ideas how to get the RF portion working?
          • R ronluna
            First on this:
            and
            Getting the last bit and reformatting it a little:
            \xe5\xa5\xa5\xe5\x85\x8b\xe6\x96\xaf\xe7\xa9\xba\xe8\xb0\x83
            and sticking it into this UTF8 enc/dec you get the attached image. If someone knows what it means, I would be interested in knowing - I suspect it something to do with aircons.
            It seems that a few air conditioners are now using the Broadlink protocol. They are controlled with a mobile app called AC freedom and they use the Broadlink devtype 0x4E2a (20010dec).
            So in short the plugin doesn't handle A/Cs. @ronluna can you tell us more about this Broadlink / Aircon device?
            More info here: on the A/Cs
            • A a-lurker
              First on this:
              and
              Second: EDIT: yes the Broadlink device was not producing an RF child. It should be fixed: see latest lua file in GitHub ver 0.57a. There are so many variations of all these devices it's hard to keep up.
              On this:
              The Broadlink device may be on the edge of its WiFi range.
              Note that the plugin now also allows you to send codes in base64 format. Just send them and the plugin will work out if they are base64 encoded.
              For reasons unclear Home Assistant seems to use them. However they have thousands available for Aircons
              R 1 Reply Last reply
              • A a-lurker
                On this:
                ronluna
                @a-lurker the second broadlink device in the network is indeed Mini split A/C that uses AC Freedom app. Both device are well within the wifi range and working fine when using their native apps so I doubt the timeout message has something to do with the strength of the connection. What I've noticed in the past when I've seen a timeout like this is due to the socket expecting a special carrier return <CR> or something in that sort, simply not understanding what was sent back to it.
                I'm not familiar with the RM communication protocol... Although I'm all ears to see what else We could try to get this off the ground.
                2021-04-03 14:20:18.155   openLuup.scheduler:: [82] BroadLink-Mk2 device startup
                2021-04-03 14:20:18.155   luup_log:82: BroadLink_Mk2 debug: Initialising plugin: BroadLink_Mk2
                2021-04-03 14:20:18.155   luup_log:82: BroadLink_Mk2 debug: Using: Lua 5.1
                2021-04-03 14:20:18.155   luup_log:82: BroadLink_Mk2 debug: 0.57a --> PluginVersion
                2021-04-03 14:20:18.155   luup.variable_set:: 82.urn:a-lurker-com:serviceId:BroadLink_Mk2_1.PluginVersion was: 0.57 now: 0.57a #hooks:0
                2021-04-03 14:20:18.156   luup_log:82: BroadLink_Mk2 debug: Using: dkjson
                2021-04-03 14:20:18.157   luup_log:82: BroadLink_Mk2 debug: Broadcasting discovery message
                2021-04-03 14:20:18.157   luup_log:82: BroadLink_Mk2 debug: 10.1.11.22
                2021-04-03 14:20:19.157   luup_log:82: BroadLink_Mk2 debug: Number of BroadLink devices found is 1
                2021-04-03 14:20:19.158   luup_log:82: BroadLink_Mk2 debug: Header to be sent follows (ex checksum):
                2021-04-03 14:20:19.158   luup_log:82: BroadLink_Mk2 debug: Payload to be sent follows (unencrypted):
                2021-04-03 14:20:19.177   luup_log:82: BroadLink_Mk2 debug: Sending:  Authorisation: txMsg length = 136
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: RX of Authorisation msg response from 10.1.11.20 failed: timeout
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: This device is probably offline - mac address: a0:43:b0:18:de:8d
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: k = rf433
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: k = rf433 has no associated code at this time
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: k = ir
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: a0:43:b0:18:de:8d_ir
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: RM4 Pro - IR 1
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: urn:schemas-micasaverde-com:device:IrTransmitter:1
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: D_BroadLink_Mk2_IrRf_1.xml
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: type = function, value = function: 0x19a62d0
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: k = rf315
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: k = rf315 has no associated code at this time
                2021-04-03 14:20:20.177   luup_log:82: BroadLink_Mk2 debug: {"a0:43:b0:18:de:8d":{"blInternalId":"00000001","blKey":"a7c5df0a9133f188c982a56dc8bcf9df","blDeviceType":25755,"blIp":"10.1.11.20","blDesc":"RM4 Pro"}} --> BroadLinkDevices
                2021-04-03 14:20:20.177   luup.chdev.append:: [a0:43:b0:18:de:8d_ir] RM4 Pro - IR 1
                2021-04-03 14:20:20.178   luup.chdev.sync:: [82] BroadLink-Mk2, syncing children
                2021-04-03 14:20:20.178   luup.set_failure:: status = false
                2021-04-03 14:20:20.178   luup.variable_set:: 82.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: false now: false #hooks:0
                2021-04-03 14:20:20.178   luup.variable_set:: 82.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 1617440329 now: 1617474020 #hooks:0
                2021-04-03 14:20:20.178   openLuup.scheduler:: [82] BroadLink-Mk2 device startup completed: status=true, msg=All OK, name=BroadLink_Mk2
                • R ronluna
                  A few points:
                  • My last mods to the Lua file would have no useful effect, so my bad. It's been a while since I looked at this code so my memory is a bit out of date.
                  • No "RF child" is produced. You get one child per physical Broadlink device (if they are known to the plugin). That child handles both RF & IR, as the sent code is either an IR or RF code.
                  • I see three IP addresses in the logs provided, which makes understanding the log a little tricky. Regardless the plugin knows the physical devices by their MAC address, so the IP address can change around. Have you fixed IP addresses for the BroadLink devices?
                  • I probably need to make the logging a bit clearer on what's going on.
                  On the aircon - the BroadLink protocol is not published and they change it from time to time so reverse engineering is always on going.
                  On the RM4 Pro - this tells me its been discovered OK:
                  I assume here that the MAC listed above is the MAC address of the RM4 Pro? There is no list of found devices in the plugin's GUI representation (there probably should but I didn't do one). The json above is the "list" and it looks fine. Once a device is defined in the json it stays there; even if the device goes off line (for whatever reason) and therefore not discoverable. If the IP address changes the json is updated to match.
                  The final problem is the "cloud bit". Some of the newer devices get this bit set when the app is used with the device and it causes issues. I have no experience of any of this, as I my devices don't have it. Need to read the thread at the other site, that talks about the reset/pairing procedure to avoid problems.
                  Also is this is on a Vera or openLuup?
                  Try relocating the Broadlink device closer to the WiFi connection. I still maintain the comms may be a bit flaky. If you send any IR code to the device the log will show what's happening and you can use a cellphone camera to see if the IR is coming out of the RM4 Pro.
                  I have no plans to get this to work for the aircons - looks like a major effort; especially if you have no hardware to test the code on.
                    140.7k
