  3. HTTP 400 error with Telegram
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
7 Posts 4 Posters 1.6k Views 4 Watching
    Hi all. Looking for some guidance as ever
    This
    luup.inet.wget('https://api.telegram.org/bot1225075966:AAHS5rwhCpOx0hwq3mOnNjtCSKiDeAS6B4/sendMessage?chat_id=@Coalport58&text=House mode is home')
    Works fine
    This
    luup.inet.wget('https://api.telegram.org/bot1225075966:AAHS5rwhCpOx0hwq3mOnNjtCSKiDeAS6B4/sendMessage?chat_id=@Coalport58&text=House mode is Home')
    Throws a 400 error:
    openLuup.client:: WGET error status: 400
    I have munged the bot key to post here, but just changing the 'h' to 'H' breaks it. Any ideas why?
      To other readers, I think CatmanV2 is talking about that changing the word "home" to "Home" in the Telegram message is causing problems?
      While this may not be the answer, I would suggest you at least URL encode your message before sending it off:
      local function urlEncode(str)
          if (str) then
              str = string.gsub (str, "\n", "\r\n")
              str = string.gsub (str, "([^%w %-%_%.%~])",
                  function (c) return string.format ("%%%02X", string.byte(c)) end)
              str = string.gsub (str, " ", "+")
          return str
      -- eg URL encode msg
      msg = urlEncode(msg)
        There also a url 'encode' function in the socket library
        local url = require "socket.url"
        local encoded = url.escape(msg)
          Nice to know.
            I usually get this error when using the internal lua libs, while curl is ok.
            It seems lua is sending an utf7 encoded url, instead of utf8 and sometime telegram doesn’t like it.
              Thanks. Yes, just changing "home" to "Home" breaks it
              No idea how to use the URL encoding :). I try to keep things simple!
                Try this link then.
