  2. Code/Snippet library
  3. List of plugins available at the Alternative App Store
Scene number?
Embarrassing mind blank
Hi I’ve been investing a lot of time recently trying to digitise everything I can, and my current adventure is with all my paper documents. My tool of choice is Paperless-ngx, which so far is an amazing open source solution, and highly recommended if you’re interest in such a thing… Such a move to Paperless would not be complete without some form of integration into Vera / openLuup, and thankfully it has a nice Rest API (https://paperless-ngx.readthedocs.io/en/latest/api.html) I can use. So far I’ve been able to make use the GET requests, to provide document counts etc., but it’s the mutipart/form data piece where I’m struggling.. The Curl command to upload a document, is as follows curl -H "Authorization: Basic Y2hyaXM62tgbsgjunotmeY2hyaXNob3N0aW5n" -F "title=Companies House File 10" -F "correspondent=12" -F "document=@/mnt/nas/10.pdf" http://192.168.102.134:8777/api/documents/post_document/ But, I’d like to know how to do this with Lua code, more just to help me in my Lua learning curve, and what I thought would be reasonably straight forward thing to do, has turned out to be quite the opposite Sending a multipart form data submission via http.request, is not as straight forward as I hoped. If anyone has any time to help, I’d appreciate some guidance on what I’m missing with the following, as based on the feedback, it looks like it not seeing the file (which I think I’ve confirmed by trying to sending both the curl and Lua commands to httbin.org ) … local http = require("socket.http") local ltn12 = require("ltn12") local mime = require("mime") local lfs = require("lfs") local username = "username" local password = "password" local httpendpoint = 'http://httpbin.org/post' local filepath = "/mnt/nas/10.pdf" local file = io.open(filepath, "rb") local contents = file:read( "*a" ) -- https://stackoverflow.com/questions/3508338/what-is-the-boundary-in-multipart-form-data local boundary = "-----BoundaryePkpFF7tjBAqx29L" local send = "--"..boundary.. "\r\nContent-Disposition: form-data; title='Companies House File'\r\n" .."----"..boundary.. "\r\nContent-Disposition: form-data; document="..filepath.. "\r\nContent-type: application/pdf".."\r\n" ..contents.."\r\n" .."------"..boundary.."--\r\n" -- Execute request (returns response body, response code, response header) local resp = {} local body, code, headers, status = http.request { url = httpendpoint, method = 'POST', headers = { ["Authorization"] = "Basic " .. (mime.b64(username ..":" .. password)), ["Content-Length"] = lfs.attributes(filepath, 'size'), ['Content-Type'] = "multipart/form-data; boundary="..boundary, }, -- source = ltn12.source.file( io.open(filepath,"rb") ), source = ltn12.source.file( io.open(send) ), sink = ltn12.sink.table(resp) } print(body, code, headers, status) print(table.concat(resp)) if headers then for k,v in pairs(headers) do print(k,v) end end
Luup : Fitbit API
Hi I’m trying out the Fitbit api, not only to extract some activity data for a potential plugin, but also to learn more about OAuth 2.0. More details can be found here.. https://dev.fitbit.com/build/reference/web-api/developer-guide/getting-started/ In addition to having a fitbit account, to get going with any integration, you need to register your app, via here.. https://dev.fitbit.com/apps With an app registered, I’ve called mine “VERA” , I’ve written chunks of Lua code to support the various steps, (completed manually) my goal now is to try and put them all together into functions to be called in sequence on my Vera and/or OpenLuup. Where I’m getting stuck is with the authorisation code step, which Fitbit provides appended to the domain name I registered with them when registered my app .. Here’s an example of a redirect URL that Fitbit will redirect the user too, with their associated authorisation code, which I need in the process later on to obtain the required access token. (More specific details are here - https://dev.fitbit.com/build/reference/web-api/developer-guide/authorization/ ) https://myapp.com/callback?code=d62d6f5bdc13df79d9a5f#_=_ And it’s the d62d6f5bdc13df79d9a5f part of that new page/URL which I need.. How best do i capture/process the URL call Fitbit issues? I assume this is where a luup.register_handler would come in, and I could register my Vera handle (using https ?, as that’s required by Fitbit) as the redirect domain/url e.g. https://veraip:3480/data_request?id=lr_fitbit& So Fitbit would redirect to.. https://veraip:3480/data_request?id=lr_fitbit&/?code=d62d6f5bdc13df79d9a5f#_=_ But that doesn’t seem to work.. Any suggestions on how to do this would be appreciated.. function FitbitRequestHandler(lul_request, lul_parameters, lul_outputformat) for k,v in pairs(lul_parameters) do luup.log ('fitbit_Handler: parameters are: '..tostring(k)..'='..tostring(v)) end if next(lul_parameters) == nil then luup.log("lul_parameters Table is empty") end local html = "</html><head>" .. "</head>" .. "<body>" .. "PRINTING" .. "\n" .. " lul_request: " .. tostring(lul_request) .. "\n" .. " lul_parameters: " .. tostring(lul_parameters) .. "\n" .. " lul_outputformat: " .. tostring(lul_outputformat) .. "\n" .. "</body></html>" return html, "text/html" end luup.register_handler("FitbitRequestHandler", "fitbit") Thanks is advance…
Luup : Error Handling
Help with luup.chdev.sync
Add-on - Aviosys IPPower 9258
Hi Picking up from another thread this is to focus on the creation of the 4 key elements of a new Plugin for my Aviosys IPPower 9258, which are quite old, and I don’t believe are made anymore, but they seem to have a simple http api interface to cut my teeth on with a plugin. First the device file, which is to support the creation/set up of the device, and here I explain what it is, tell Vera what the implementation file and .json file is, and also leverage the pre-existing Switch and HA capabilities.. Device File - D_IPPower.xml <?xml version="1.0"?> <root xmlns="urn:schemas-upnp-org:device-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <device> <deviceType>urn:nodecentral-net:device:IPPower:1</deviceType> <staticJson>D_IPPower1.json</staticJson> <manufacturer>Aviosys</manufacturer> <modelDescription>IPPowerSwitch</modelDescription> <modelName>IPPower9258</modelName> <handleChildren>1</handleChildren> <implementationList> <implementationFile>I_IPPower1.xml</implementationFile> </implementationList> <serviceList> <service> <serviceType>urn:schemas-upnp-org:service:SwitchPower:1</serviceType> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <SCPDURL>S_SwitchPower1.xml</SCPDURL> </service> <service> <serviceType>urn:schemas-micasaverde-com:service:HaDevice:1</serviceType> <serviceId>urn:micasaverde-com:serviceId:HaDevice1</serviceId> <SCPDURL>S_HaDevice1.xml</SCPDURL> </service> </serviceList> </device> </root> Next it is the Implementation file, which thanks to the feedback on this forum, will focus on a specific Lua file, where all the code will be, the only thing I need to add here are the Actions (what do I want it to be able to do etc.) Implementation file - I_IPPower.xml <?xml version="1.0"?> <!-- I_IPPower.xml; Vera/openLuup "IPPower 9258" Plug-in V1.1 Nov 2021 --> <implementation> <settings> <protocol>crlf</protocol> </settings> <files>L_IPPower1.lua</files> <startup>IPPowerStartup</startup> <actionList> <action> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <name>SetTarget</name> <job> local url = "http://" .. ipAddress .. "/set.cmd?user=admin+pass=12345678+cmd=setpower+" .. luup.devices[lul_device].id .. "=" .. lul_settings.newTargetValue luup.log("Sending command " .. url) local status, data = luup.inet.wget(url) if (data) then debug("Data received = " .. data) else log("No Data received !! ") end local value = string.match(data, luup.devices[lul_device].id.."=(%d)") if (value) then luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", value, lul_device) else log("Value returned is empty") end </job> </action> </actionList> </implementation> The other two files D_IPPower.json, and L_IPPower.lua are still being worked on so i will add later … If anyone notices any improvement
Hi all I’ve been trying to use the Hue api and some of my Lua knowledge to create an energy calculator based on the brightness and wattage of specific models of hue bulb registered on the hub I’ve pretty much got there, the only stumbling block I have is how I total up all the individual bulb wattages. Can anyone help ? It’s likely an easy thing for someone more experienced to see, but as I only dip in and dip out now and then, the correct code/syntax does not always come to mind. Note : as I’ve tried various routes, I’ve commented some things out, but you should be able to get the idea of what I’m trying to do.. Create device json from Hue Hub Decode JSON and extract key values to a table Calculate approx watts based on bulb model and/or watts function Total up watts of all bulbs that are switch on. Code below... local hueBridgeIP = '192.168.1.29' local hueBridgeAPI = "80uCoXjnn2LNLhxEJ9PW6nmt-G5KWQ2uP3oONAvcm0j" function getHueLight() local http = require('socket.http') local ltn12 = require('ltn12') local json = require('dkjson') t = {} local url = string.format("http://%s/api/%s/lights", hueBridgeIP, hueBridgeAPI) b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'} huestring = tostring(table.concat(t)) local hue, pos, err = json.decode(huestring, 1, nil) huelights = {} for k, v in pairs(hue) do local modelno = string.gsub(hue[k]['modelid'], "%s+", "") table.insert(huelights, {k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']}) print(k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']) end end local fourpointeightwattTable = { [ 1 ] = 0.6 , [ 2 ] = 0.7 , [ 3 ] = 0.8 , [ 4 ] = 0.9 , [ 5 ] = 1.2 , [ 6 ] = 1.4 , [ 7 ] = 1.7 , [ 8 ] = 2.0 , [ 9 ] = 2.3 , [ 10 ] = 2.6 , [ 11 ] = 2.9 , [ 12 ] = 3.1 , [ 13 ] = 3.5 , [ 14 ] = 4.0 , } local sevenwattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.4 , [ 7 ] = 2.7 , [ 8 ] = 3.0 , [ 9 ] = 3.5 , [ 10 ] = 3.9 , [ 11 ] = 4.5 , [ 12 ] = 5.1 , [ 13 ] = 5.5 , [ 14 ] = 6.4 , } local ninewattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.5 , [ 7 ] = 2.9 , [ 8 ] = 3.5 , [ 9 ] = 3.8 , [ 10 ] = 4.6 , [ 11 ] = 5.5 , [ 12 ] = 6.5 , [ 13 ] = 7.7 , [ 14 ] = 8.5 , } function fourpointeightgetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.2 elseif index >= 15 then return 4.8 else return fourpointeightwattTable[index] end end function sevengetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 7.0 else return sevenwattTable[index] end end function ninegetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 9.0 else return ninewattTable[index] end end local total = 0 local Value = 0 local huewatts = {} for k,v in pairs(huelights) do if v[2] == true and v[5] == "RS125" and v[6] == true then local watts = fourpointeightgetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("four point eight watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[5] == "LWA004" and v[6] == true then local watts = sevengetWattage(v[4]) local Value = tonumber(watts) local total = total + watts print("seven watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[6] == true then local watts = ninegetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("nine watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) end end print(total) print(huewatts) -- confirm if table it there (TBC)
UDP Datagrams
Luup : Foscam API
Help with luup.call_delay()
2 Posts 2 Posters 2.0k Views 2 Watching
    For the most up-to-date list refer to the openLuup documentation.
    The plugins listed here are available via the Alternative App Store. The app store becomes accessible via a new menu item in the Alternative User Interface once configured.
    Both the Alternative User Interface (AltUI) and AltAppStore (AltAppStore) plugins need to be installed on Vera to access the store. With openLuup; this is all "automatically" set up and ready to go as part of the openLuup suite.
    The Alternative App Store can be found here.
    Publishing a plugin in the store is pretty easy. First your plugin code must be available in GitHub. Publish it, using the Publish command in the AltAppStore web page. You need to enter the salient information and it's ready to go.
    Plugin icons can be stored on GitHub eg like so. After a "few days" the raw json describing the plugin appears here.
    Vera 3 users should note the store will not work, as Vera 3 doesn't have the https capability required to access GitHub. However, the apps can always be downloaded from GitHub and manually installed.
    For those just interested in what the store contains; refer to the list below - as of 2021 July 27 there were about 75 plugins available:
    Plugin Comments
    ABC:
    Aeratron fans
    Alternative App Store Built into openLuup
    ALTHue
    ALTUI
    Amcrest Dahua
    AutoVirtualThermostat
    BroadLink-Mk2
    Canal Plus Not in GitHub
    Countdown Timer Originated by Futzle
    DEF:
    DALI Planet
    DarkSky Weather Support for the Dark Sky API ended 31 Mar 2023. The "Multi Provider Weather Station" plugin can potentially be used as a replacement.
    DataYours
    DelayLight
    DeusExMachinaII
    Domoticz Bridge Non functional: needs work check here
    Domoticz Bridge 2 Originated by 999LV and updated by perhusaas
    DreamColorESP8266
    DreamColorLedRGB
    Ecobee
    Edisio Gateway
    EDS One Wire Server Originated by Chris Jackson
    EKM metering
    Emby Interface
    Enphase Envoy Solar Monitor
    EventWatcher
    Ezlo Bridge
    FritzBox Sensor
    GHI:
    Google Calendar 3
    Harmony Hub Control
    Heliotrope Originated by Futzle. openLuup incorporates the same functionality, so this plugin is not required in that casse.
    Homebridge 2 openLuup
    HomeWave Push
    HundredGraphs Logger
    IKEA Tradfri
    Image Map Remote
    Info Viewer For Vera only
    IPhone Locator
    IPX800
    Irrigation Caddy
    JKL:
    KSenia Lares 16 Bridge
    LuaView
    MNO:
    MetOffice DataPoint
    Netatmo
    Network Monitor
    OpenSprinkler
    OpenTherm Gateway
    openWeather Support for the Wunderground weather API ended Dec, 2018. The "Multi Provider Weather Station" plugin can potentially be used as a replacement.
    PQRS:
    Paradox EVO IP150 web page scrapper
    Pioneer Receiver
    Rachio
    Rainforest Eagle Based on robertmm's work
    RaZberry (ALPHA)
    Reactor
    RGB Controller
    Rules Engine
    SiteSensor
    SMA inverter
    Smartmeter Reader
    Solar Meter
    Sonos Originated by lolomodo and updated by toggledbits.
    Sony Bravia IP
    Surveillance Station Remote (BETA)
    Switchboard
    TUV:
    Telegram
    Tesla Car
    UPS Sensor
    UPnP Event Proxy Modified for installs that have systemd available. Not suitable for Vera - plugin originated by Futzle.
    VeraAlexa
    Virtual Devices MQTT commands & status are only available with openLuup. http & Lua can be used by Vera and openLuup.
    Virtual Pronto Remote
    Virtual Sensor
    VW CarNet
    WXYZ:
    WES
    Xee
    Yamaha RX HTTP
    Z-Way
    ZiBlue Gateway
    ZiGate Gateway
      Under openLuup, you can use the native App Store page...
      http://openLuupIP:3480/openLuup?page=app_store
      ...which, of course, shows only openLuup compatible plugins. It's also very responsive.
      Hovering over the plugin icon shows the description, and there are links to the App Store JSON and GitHub repository if you're a developer wanting to browse those.
      • A a-lurker referenced this topic on
      • T Talisker referenced this topic on
        164.4k
