  3. Z-Wave.me
  4. UZB Long Range
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
UZB Long Range
7 Posts 3 Posters 2.9k Views 3 Watching
    RHCPNG
    Hi guys,
    • I Offline
      I Offline
      iRobot
      wrote on last edited by iRobot
      I'm guessing you mean the zwave.me uzb1.
      No, that's still a 500 series chip.
        RHCPNG
        Yes, I mean the zwave.me one, I wasn't aware there are others. Ok, thanks! I hope they will release a new one soon then.
          I have tested the 700 series chip, not on a uzb but back on the vera and back then the controller API was not ready. Looking deeper and understanding how zwave works, I have come to the conclusion that in terms of range, the new 700 series will not show much benefit from changing the controller (It explains why silabs focused on device implementation rather than controller). Long range means stronger signal strength from the controller. It doesn't mean it can receive from devices further away. The range of your mesh is therefore much more dependent on the signal strength of the devices than it is on the one from the controller....
          The new chip may reduce the number of hops close to the controller... but upgrading the controller alone won't do much. Upgrading the devices alone however will improve the range for the simple reason that the limitation is generally coming from the devices (especially battery powered ones) rather than the controller (unless you have a weak controller antenna setup which is not the case of the uzb). Also, in most setups your range limitations are at the edge of your mesh and your controller is supposed to be at the center of it. The network range will benefit most from upgrading the nodes at the edge.
          Food for thought... My testing showed nearly 0 benefit.
            RHCPNG
            Thanks for your explanation. I don't think it is useful to wait for a new version then.
              RHCPNG
              Just got a reaction from z-wave.me. Maybe also interesting for others:
              "We are planning to release new UZB and RaZberry soon with LR support. Around April/May.
              LR is very new and there are no devices supporting it yet."
              • I Offline
                I Offline
                iRobot
                Always good to know a new UZB is coming.
                Thanks for the information.
                Hopefully this will also solve the debacle of bad stick production batches which makes firmware updating a nightmare.
                Other than that, to me it looks like we will have to wait for nodes which use the same LR chip to be able to fully benefit it's potential.
