  3. Z-Wave.me
  4. z-way-server new release
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
11 Posts 3 Posters 4.0k Views 3 Watching
    Z-Way builds
    dpkg -i z-way-*.deb
      wrote on last edited by PerH
      This one was of particular interest for me:
      Fixes:
       - Do not logout permanent tokens
      I tried earlier to upgrade using the old technique, didn't work. I'll try this on later. Thanks
        This didn't work for me, this is the print after running dpkg:
        Selecting previously unselected package z-way-server.
        (Reading database ... 153903 files and directories currently installed.)
        Preparing to unpack z-way-3.1.2_amd64.deb ...
        Stopping z-way-server: done.
        Unpacking z-way-server (3.1.2) ...
        dpkg: dependency problems prevent configuration of z-way-server:
         z-way-server depends on libwebsockets15; however:
          Package libwebsockets15 is not installed.
        dpkg: error processing package z-way-server (--install):
         dependency problems - leaving unconfigured
        Processing triggers for systemd (241-7~deb10u4) ...
        Errors were encountered while processing:
         z-way-server
        also saw the same as when i tried to install it the old way:
        ● z-way-server.service - LSB: Z-Way service
           Loaded: loaded (/etc/init.d/z-way-server; generated)
           Active: active (exited) since Wed 2021-01-20 23:36:28 CET; 2 weeks 3 days ago
             Docs: man:systemd-sysv-generator(8)
            Tasks: 0 (limit: 4513)
           Memory: 0B
           CGroup: /system.slice/z-way-server.service
        Seems to be missing libwebsockets15, but it says there is no release candidate?
        • PerHP PerH
           z-way-server
             Memory: 0B
          @perh
          try installing this (assuming you are using a debian/raspbian/ubuntu base):
          sudo apt-get install libc-ares2  libwebsockets-dev
          it is possible that your linux installation is missing some dependencies. Just need to track down which packages has them and install them.
            And... 3.1.3 just got released. They seem to be on a roll.
              Tried your suggestion, and it seems to have installed libwebsockets8.. how do i find out which package to ask for? google didnt help me today..
                What linux distribution are you running? It looks like the repository it is pinging is quite old.
                I am running ubuntu20.04 and this is what it has
                https://pkgs.org/download/libwebsockets15
                This is the archlinux version:
                https://aur.archlinux.org/packages/libwebsockets15/
                If you are on Debian, it looks like the version 15 doesn't exist, I would therefore trying installing libwebsockets16 and create a symbolic link to use the newer library instead:
                sudo apt-get install libwebsockets16
                sudo ln -s /usr/lib/x86_64-linux-gnu/libswebsockets.so.16 /usr/lib/x86_64-linux-gnu/lib/libwebsockets.so.15
                You just have to know where your library is as the location may vary depending on the distro
                  seconds after i posted, i found it!
                   wget http://archive.ubuntu.com/ubuntu/pool/universe/libw/libwebsockets/libwebsockets15_3.2.1-3_amd64.deb
                  Seems to be up and running now. 🙂 This is in a docker on my test system, its some ubuntu release..
                  A bit weird that the software info doesnt say 3.1.3 though:
                    I made a docker that works well here: https://hub.docker.com/r/perhu/z-way-server-3-1-3
                    My first attempt at building an image, let me know if it's not working. 🙂
                    S 1 Reply Last reply
                    • PerHP PerH
                      @perh
                      @PerH I tried your image with a docker run command because the Docker version on my Synology is 18.09.8 and doesnt support the version of compose file you posted in the zway forum. The image runs and I can see the UZB stick but it gets errors in the settings such as "Can't intialize remote access data." and the time zone wont save. The zddx directory is empty also. Any thoughts?
                        Actually, i have never gotten to save timezone data in the GUI of Z-Way.. So thats not because of the docker at least..
                        Remote access is a plugin you have to set up - i think? never used it myself. I think I asked poltos about the error message when going into settings, and he said that it will always be there when you havent set up remote access.
                        I dont have my installation in front of me, but i think zddx fills when you have devices set up, if you only have a stick now, mabye it'll come when you add devices?
                        regarding docker compose, i guess you have to backport some of the functions. I know there is some info on that in docker documentation. But the run command done correctly should do exactly the same, but it can be long in some instances.
                          163.3k
