  3. Z-Wave.me
  4. Getting status update from device
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
4 Posts 3 Posters 1.6k Views 4 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    Probably @rafale77 will jump on this question first 😉
      Hmm this is weird, The only device which I found to somewhat behave this way were my Yale locks:
      Z-way sends a command to lock or unlock and immediately thereafter sends a command to get the status of the lock.
      The problem was that it takes time for the lock to change status so the result of the "get" command was always wrong. I ended up hacking the z-way lock plugin to add another "get" command 1s after any lock target change command is detected.
      For a light switch it is rather surprising and I have never seen this. If it is "often" and not always, it could very well be a signal lost problem. Have you looked at the command queue in the expert UI to see what happens when it succeeds and when it fails? This could provide a clue.
      • C Offline
        C Offline
        cubs2b23
        I see things like this in my setup now that I've moved to z-way instead of Vera. Like it missed the status update. I can click on the "Update All" button from the Z-way Expert UI and then everything is accurate again. And it's not missing every status update and not even for the same devices. Just one maybe two. I've often wondered if there is a way to manually send the "Update All". But that status on my lock is definitely one that often incorrect.
        @rafale77, would it be possible for you to go into more explanation of hacking the z-way lock plugin?
          This indeed is a side effect of how Z-way works (it is a bit too fast at trying to poll updates) and I have gone over this with @PoltoS over emails. "Update all" would add too much overhead traffic. I was proposing to add a small delay between the zwave "Set" and "Get" commands but was told that it would make z-way run slower for the vast majority of devices which don't need this. Since in my case, there is only one type of device I just used my own workaround. It's been a long time since I did this so my memory is fading.
          The pluggin is the Niffler:
          [userModule] Niffler - An event notification updater - forum
          GitHub - jensmoes/Niffler: Workaround for Z-Wave devices that does not send unsolicited reports
          Workaround for Z-Wave devices that does not send unsolicited reports - jensmoes/Niffler
          Readily available in the z-way appstore. This is my version, I just forked. https://github.com/rafale77/Niffler
            165.4k
