  3. Z-Wave.me
  4. z-way-server 3.1.0 release
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
7 Posts 3 Posters 2.7k Views 3 Watching
    Just upgraded to 3.1.0 and am happy to report that it has not impacted the z-way bridge for openLuup.
    I am now seeing the SDK version for firmware 5.39
      @rafale77 said in z-way-server 3.1.0 release:
      ..You're happy? How happy do you think that makes me feel!
        @akbooer
        🙂 lol, yes I can imagine. So far I am seeing a few cosmetic improvements on this new version but since I am rarely ever interacting with the z-way UI, it isn't doing much for me. The upgrade went pretty smoothly though it had to be a little manual.
        For those who want to do it on debian/ubuntu, the process is to download the file:
        wget https://storage.z-wave.me/z-way-server/z-way-server-Ubuntu-v3.1.0.tgz
        decompress it:
        tar -zxf z-way-server-Ubuntu-v3.1.0.tgz
        remove the default config file:
        rm z-way-server/automation/storage/*.json
        and then overwrite the z-way-server installation folder wherever it is. Mine is in the /opt folder which requires root permission.
        sudo cp -r z-way-server /opt/
        PS: One notable improvement is in the noise meter. Now the below detection limit shows up as -95dBm instead of a nil value which made the graph looked like the noise remained at a high level. I think it was one of my requests...
          Just did this, and it seems to work well, but i realized i have UZB FW 5.29! Still the "expert" gui tells me i have the latest? and you have 5.39?
            F**k me.. Tried to make sense of this beauty: https://service.z-wave.me/expertui/uzb-stats/versions-graph.html?hw=277 referred here: https://z-wave.me/zmeserialupdater-manual/
            can I just download the latest file, or do I have to do all versions, bootloaders and all?
              Answer was:
              Upgrade to 5.26, then 5.27, then 5.33, then 5.34, then 5.36, THEN 5.39..
              The UI said I have the latest all the way from 26 to 39..
              Anyway, finally im up to date!
                Just updated to 3.1.1, same round as shown above. Works fine.
                Then i tried with 3.1.2, but then i did that, the service doesn't show as "running":
                ● z-way-server.service - LSB: Z-Way service
                   Loaded: loaded (/etc/init.d/z-way-server; generated)
                   Active: active (exited) since Wed 2021-01-20 23:33:36 CET; 6s ago
                     Docs: man:systemd-sysv-generator(8)
                  Process: 14265 ExecStart=/etc/init.d/z-way-server start (code=exited, status=0/SUCCESS)
                Jan 20 23:33:36 Chromebox systemd[1]: Starting LSB: Z-Way service...
                Jan 20 23:33:36 Chromebox z-way-server[14265]: Starting z-way-server: done.
                Jan 20 23:33:36 Chromebox systemd[1]: Started LSB: Z-Way service.
                No idea why, so i'll stick to 3.1.1, but 3.1.2 seems to have som bug fixes that would've been nice..
                  154.4k
