  3. Z-Wave.me
  4. Rpi kit
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
Rpi kit
5 Posts 2 Posters 1.8k Views 2 Watching
  • P Offline
    P Offline
    powisquare
      The uzb doesn't consume much power so it should be fine.
      I will never stop being fascinated by how expensive these rPi accessories are. You can get an actual UPS 10x the capacity for about the same price but it won't be this small. If powering through USB 5V, I actually made a DIY UPS a few years ago using 4 AA NiMH batteries in a small battery box with a cable splitter which worked wonders. Now you are giving me iideas about reusing it.
      • P Offline
        P Offline
        powisquare
        : ) We get quite a few power cuts - not long generally. What UPS would you recommend? Will be going in to some tightish loft space ..
          If you require tiny then you probably got yourself one of the better solutions. Careful with the Li-ion battery though as it relates to heat.
          I have a couple of alternatives you could have considered:
          https://www.ebay.com/itm/USB-4-AA-Battery-Emergency-Charger-Power-Bank-Case-AA-Cell-Storage-Case-Hold-t5e/193726914459?epid=19039273597&hash=item2d1b061f9b
          May not be this particular one but it should give you an idea. I got I think a set of 3 of these for ~$12.
          Then put in 4 NiMH rechargeable batteries in it and plug it with a USB splitter cable. This has served me well in the past to power things like raspberries and hue hubs.
          The other way if you have a lot of low powered devices to power in all kinds of different places and if they are all going to be connected by ethernet is to go POE. You would get a standard UPS as there are many going on sale on a regular basis, to power a POE ethernet switch and then use a POE splitter (~$10 each) to replace all of the wall warts. I think I posted in the old place that this has the side benefit of dramatically reduced RF noise from all these DC power cables and make your z-wave network more reliable since all these cheap AC-DC power supplies are often of poor quality and generate a lot of noise. I went on rampage a couple of years ago replacing every power supply I could with POE in my house which significantly reduced the noise even measured by the UZB using z-way.
          • P Offline
            P Offline
            powisquare
            Thanks for that - good to know. Was thinking about putting a switch there too - for the moment it's plugged directly in to the AP. Heat is quite a large concern as the temps get pretty warm in the summer under the roof. That battery hat uses a Mototrola droid battery afaik and was hoping it could deal with it. Then ... there are explosions.
              1.1k
              158.2k
