  3. Z-Wave.me
  4. UZB/RaZberry Firmwares - Update
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
45 Posts 7 Posters 31.5k Views 7 Watching
    sender
    After a major hassle got z-way running on my ubuntu 16 VM with a USB pasthough UZB1 stick including license and connected to Vera...
    I see:
    I also see:
    But how do I update that?
      sender
      Found a tip here:https://forum.z-wave.me/viewtopic.php?f=3419&t=33503&p=86965&hilit=firmware#p86965
        sender
        So I think this is where my journey ends... dead also after reboot...
          The lesson here is to not try to upgrade sticks with a P/N ending in BB as they are partner made sticks which apparently have some problems.
            sender
            2nd stick also bricked - UZB firmware 5.36 update failed. Device is bricked. Return to seller - forum
              So i just received a UZB stick from a US seller.
              Part number ZMEUUZB1
              Serial number 4.19.01
              Firmware 5.27
              Firmware update options:
              5.27 => 5.36
              5.27 => 5.23
              Has anyone successfully updated the firmware on one of these or is it brick material? Any vendors with up-gradable sticks?
              Update: Tried to update from the GUI and it never recovered. No lights and will not detect. 😞
              • Black CatB Offline
                Black CatB Offline
                Black Cat
                Yep, our UZB is upgradable.
                Black Cat UZB Z-Wave Smart 6 Static controller
                https://www.blackcatcontrolsystems.com.au/Black-Cat-UZB-Smart-6-Static-Z-Wave-Controller
                UZB sometimes can be unbricked, I don;t have the link for this but Raf might remember where it resided.
                FWIW, the ZWBCUZB might also be flashable to other frequencies, I've never tried it but the FW is available for other regions.
                aka Zedrally
                • S SweetGenius
                  Firmware 5.27
                  5.27 => 5.36
                  5.27 => 5.23
                  @SweetGenius
                  I got my stick from eBay I think but I think amazon one here should be upgradable. The non upgradable ones are more rare I think:
                  Z-Wave.Me USB Smart Home Stick made for My Cloud2 by WD, Z-Wave Plus - Amazon.com
                  S 1 Reply Last reply
                    @SweetGenius
                    @rafale77
                    I have bricked two of them, Could I be doing something wrong when trying to upgrade the firmware? I am Using Z-way v3.0.6 GUI expert settings. Update firmware button, Putting "all" in the token field and click the button on update firmware 5.27 to 5.36. After the page reloads the the device is not accessible and no blue lights. It does not show up in the /dev folder any more. Reboot of the Pi does not help.
                      Have you tried unplugging and plugging it back to power cycle the stick? I screwed up the firmware upload quite intensively on the last upgrade (>50x) due to some memory indexing issues and never managed to brick it. The process has it load the entire firmware image on the non volatile memory first and then after checking it is corruption free, it does the upgrade. I found it much more difficult to brick than say the vera firmware. The 3rd party vendor stick is unknown to me as I don't have one but I see some people struggling with upgrading those.
                      I am running on 5.39 at the moment...
                        Yes, unplugged multiple times, The link you sent is the same vendor that I bought from directly. I have read your posts so that is why I thought I might be doing something wrong.
                          I am also not using the GUI. I use the command line upgrade tool, in part because I had a lot of failures with the GUI with not much explanation... and I like to know what is going on...
                            I looked at the CLI tool. Very confusing of the correct bootloaders and version of files. I thought the GUI would be safer.
                              True, it is a bit dissuasive at first... And the firmware map is kind of mind-blowing and takes some time to understand how it works. Well sorry you got these 3rd party buggers.
                              This I am pretty sure where I got mine from. I would recommend returning those amazon ones if you still can.
                              https://www.ebay.com/itm/Z-Wave-ME-UZB-Z-Wave-USB-Stick-US-Version-Free-shipping/371973342579?epid=527624931&hash=item569b56c573:g:zgAAAOSw5cRZNccI
                                Thanks for the info. Does your stick have a "true" serial number? Mine has the same serial number of other peoples that bricked on the z-way forum "04.19.01"
                                  I am not seeing a serial number but have a UUID which I assume is unique and a subvendor ID of 0x0115
                                    3rd UZB and it appeared to upgrade. (Via GUI) I upgraded from 5.27 to 5.36. Then upgraded to 5.36 to 5.39. @rafale77 , Since you are on 5.39, does your show anything in the SDK Version line? Mine did before the upgrade to 5.39.
                                    On the firmware upgrade page it shows this now. But they do nothing.
                                      It is normal. No I am not seeing an SDK version because... it is too new. This will apparently will be fixed in the next version of z-way. It is in fact 6.82.1
                                        Trexx
                                        Thanks Rafale77 for your patience/help. Now I have to jump over to your GitHub page/directions for copying my existing ZWave NW from Vera onto the ZWay.Me and get the existing security key 🙂
                                          Great! Let me know if you need any help or if the documentation needs improvements.
                                            165.4k
