  3. Z-Wave.me
  4. UZB/RaZberry Firmwares - Update
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
45 Posts 7 Posters 31.1k Views 7 Watching
    #41
    Yeah there where I switched to the command line tool. Do you already have devices on that stick? @poltoS says it is because the upgrade process is interrupted by RF signals. I thought it was due to some EEPROM start location issues but I did find it painful in recent versions to upgrade and had to retry dozens of times to get it through. It looks like the upload of the firmware started but gets interrupted by something.
    parkercP 1 Reply Last reply
      parkercP Offline
      parkercP Offline
      parkerc
      @rafale77 said in UZB/RaZberry Firmwares - Update:
      No, currently it’s blank, I reset it before I started down the whole upgrade path. What it is near is loads of other HA devices, 2 x Veras (a 3 and a Plus) and there’s also a hue hub and numerous other things .
      Could that have an effect ?
        Hmm possibly. But I don't know for sure. The recommendation was even to temporarily change region so as to prevent any noise from interrupting the upgrade process. I don't know why they don't have a better way to not be impacted by the RF signals during the upgrade on these newer firmwares.
        • PerHP PerH referenced this topic on
        • H Offline
          H Offline
          hunnypuppy
          wrote on last edited by hunnypuppy
          #44
          A kinda basic question, I'm currently on UZB1 firmware 5.34
          What is the advantage of going through this process to get to 5.39
          The only I notice is that it seems to have something called Zniffer feature to trap packets. What exactly does this enable? I can see packets in Zniffer using Z-Way (when using as a secondary controller but only between the secondary controller and device, not between devices and primary controller) and Zniffer ART seems to indicate that it needs different hardware. So where can this Zniffer additional 5.39 feature be used or is there any other advantage to upgrading the firmware?
          • H Offline
            H Offline
            hunnypuppy
            #45
            I'll answer my own question for others benefit. I was able to successfully upgrade UZB from firmware 5.34 to 5.39 using Z-Way server and the all token to first downgrade and then upgrade following this path.
            5.34 → 5.33 → 5.27 → 5.36 → 5.39
            My bootloader version is 40196 and I did not upgrade the bootloader along the way, I started and ended with the same bootloader.
            I did a ResetAPI followed by a ControllerReset after each firmware downgrade/upgrade to ensure that I had a clean start. I also disabled all zwave device (unplugged/removed batteries) to ensure that any stray packets didn't interfere with the process. Be sure to backup your configuration/network before updating the firmware.
            After upgrading to 5.39 I'm now able to use the promiscuous mode in Z-Way zniffer to capture packets on the network (although it misses some packets)
            I did get a note from support, so those with firmware under 5.24 may want to pay heed to this.
            there is a batch of sticks with "dead-end" firmware and a slightly modified board topology. But given the fact that such sticks are usually impossible to upgrade above version 5.24, then you most likely have a good stick for which this operation will be possible.
              162.9k
