  3. Z-Wave.me
  4. UZB/RaZberry Firmwares - Update
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
45 Posts 7 Posters 31.1k Views 7 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    #21
    Hi @rafale77 or any others in this coMmunity who might be able to help., I‘m looking to upgrade my UZB USB module, - which is plugged into to a USB hub on my PI - to the latest firmware..
    Using the guide here..
    https://z-wave.me/zmeserialupdater-manual/
    I’ve so far done the following..
    wget https://z-wave.me/download/ZMESerialUpdater.tgz
    tar -zxvf ZMESerialUpdater.tgz
    cd ZMESerialUpdater/arm/
    chmod +x ZMESerialUpdater
    To be sure the software is working and also to check what FW I currently have - I ran the following command.
    pi@raspberrypi:~/ZMESerialUpdater/arm $ sudo ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyACM0
    Which gave me this...
    Z-WAVE Serial API Tool
        Version:LWE0.9
        by Z-WAVE>ME
           Device ready in:1.01568007469 seconds
                     FULL INFO
    Openning port                            ..............................                            OK
              SERIAL INFO
                     VERSION:  05 05  VENDOR:  01 15
              ZME_CAPABILITIES
                         UID:  7B 93 21 D8 62 1E C2 2B 4F 6E 8B 94 A3 05 01 36
                      VENDOR:  00 00   NODES: FF
                       FLAGS:  05 00 00 00 00 00 00 00 00 00 00 00 00
              FIRMWARE CRC
                        BOOT:  BB BB      FW:  75 7B
              MISC
                        FREQ:  EU
                                             NVR Content
              Prog/erase lock :  FF FF FF FF FF FF FF FF, Read back lock: FF
              Rev 01, Cal 06, TXCal  17 13, SAW  FF FF FF FF, Pin FF, CRC  3E CE
              NMV: CS 15, TYPE 02, SIZE  01 00, PSIZE  01 00 (EEPROM M25PE20)
              USB: VID  FF FF, PID  FF FF, UUID  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
              FACTORY ID: WEEK 51, YEAR 16, CHIP  00 01, SER  0B D2, WS 1, HWREV: 00 01, CRC8 04
              elapsed 3.09909391403 seconds
    The next steps seems to be to find the latest firmware, and that’s where things get a little confusing, as it basically tells you to go and find it via this - https://service.z-wave.me/expertui/uzb-stats/versions-graph.html. and that’s where I get lost ..
    It seems to be suggesting that I need to build my own url (using the following construct below) to download it..
    https://service.z-wave.me/expertui/uzb/add-file_name-here?
      I would recommend running the upgrade through the z-way-server expert UI if you can. It makes things a lot simpler. Using the firmware tool works better but is a bit of a learning curve. Indeed if you open the version graph, you need to find which firmware version you currently are on and clicking on the corresponding dot on the graph opens a simple page listing all the url of every possible downgrade/firmware available from that version. This is where you get the url to use with the tool...
      • parkercP Offline
        parkercP Offline
        parkerc
        #23
        I downloads the software and installed the zway stuff, and then useD the ‘ExpertUI’ as described to update the firmware and boot loader; interestingly their website says the latest version is 5.39. - https://z-wave.me/support/uzbrazberry-firmwares/
        Yet, It seems while I was originally only on 5.05, after two upgrades 5.06 and 5.07 - the software tells me I’m now all up to date.. yet it’s reporting I’m on 5.07..
        Here’s my updated report.. ..
        Device ready in:25.022865057 seconds
                  FULL INFO
                  SERIAL INFO
                         VERSION:  05 07  VENDOR:  01 15
                  ZME_CAPABILITIES
                  FIRMWARE CRC
                            BOOT:  9D 04      FW:  AE CB
                  MISC
                            FREQ:  EU
                                                 NVR Content
          Did you try typing all in the token field ?
          • parkercP Offline
            parkercP Offline
            parkerc
            #25
            Hi @SweetGenius, sorry, I’m new to these modules and this whole process
            What do you mean by the ‘token field’ ?
            Is it the ‘Action Token’ one, shared in the screen shot above?
            If so, what goes in there ?
            Is this where the licensing comes in ?
            Can you only go so far with the firmware upgrades ?
            • parkercP parkerc
              @parkerc
              On the firmware update page you should see this:
              Which where you can input the "all" token so you can see all available update paths.
              • parkercP Offline
                parkercP Offline
                parkerc
                #27
                Hi, thanks I’ve put ‘all’ in and it provided me with a list, however it still says I’m using the latest firmware ?
                Also it’s a bit confusing and they mention 5.07 and 5.7 - not sure if that’s an error and they mean the same (5.07)....
                  You should go to 5.27 as the first step. Check in the firmware map to make sure it isn't a dead end. Also you appear to have a boot loader upgrade available too but need to check whether it is a downgrade again from the firmware map.
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    #29
                    Hi @rafale77
                    The map is not the easiest thing to read ? - https://service.z-wave.me/expertui/uzb-stats/versions-graph.html?hw=277&with_hidden image attached is just the active ones
                    Am I on 5.07, or 5.7? If so, is 5.7 to 5.27 not a downgrade, rather than an upgrade ? The command line firmware tool seems to suggest I‘m on 5.07. How do you read it to work out the bootloader? I can’t see the 7278 mention via the expert Ui?
                      #30
                      5.07 = 5.7, it would be called 5.70 which doesn't exist.
                      Also you should try clicking the "all" map which corresponds to the "all" token in the z-way server. Once you find the bootloader and firmware version you are currently running, the map shows you to to get to where you want to go. It's actually pretty intuitive once you get the hang of it. On this map for example you can see that 5.7/40196 appears to be a dead end (have to check the all map to see the whole thing)
                      • parkercP Offline
                        parkercP Offline
                        parkerc
                        #31
                        Ok, clicking on UZB all and then 5.7, it gives me the following..
                        The second one relates to the bootloader upgrade option that’s presented.. is it suggesting I update the bootloader first ?
                        {"data":[{"id":"252","baseid":"","enabled":"enabled","type":"bootloader","file":"bin","vendorID":"277","bootloaderCRC":null,"appVersionMajor":"5","appVersionMinor":"7","targetBootloaderCRC":"40196","targetAppVersionMajor":null,"targetAppVersionMinor":null,"fileURL":"UPD_BOOTLOADER_UZB_ZME_05_07_04000001_9d04.bin","released":"2018-01-12","comment":"Update bootloader to 9d04","position":"70","version":"5.7"},
                        {"id":"98","baseid":"","enabled":"disabled","type":"bootloader","file":"bin","vendorID":"277","bootloaderCRC":null,"appVersionMajor":"5","appVersionMinor":"7","targetBootloaderCRC":"29304","targetAppVersionMajor":null,"targetAppVersionMinor":null,"fileURL":"bootloader_UZB_from_05_07_to_7278_2MB.bin","released":"2017-05-12","comment":"Update bootloader to 7278","position":"72","version":"5.7"},
                        {"id":"88","baseid":"","enabled":"disabled","type":"firmware","file":"bin","vendorID":"277","bootloaderCRC":null,"appVersionMajor":"5","appVersionMinor":"7","targetBootloaderCRC":null,"targetAppVersionMajor":"5","targetAppVersionMinor":"7","fileURL":"UPD_FIRMWARE_UZB500_X_from05_07_to_UZB500_3CH_05_07.bin","released":"2017-04-18","comment":"Update firmware to 3 channels (JP/TW/KR/SG) on 5.07","position":"57","version":"5.7"},
                        {"id":"89","baseid":"","enabled":"disabled","type":"firmware","file":"bin","vendorID":"277","bootloaderCRC":null,"appVersionMajor":"5","appVersionMinor":"7","targetBootloaderCRC":null,"targetAppVersionMajor":"5","targetAppVersionMinor":"7","fileURL":"UPD_FIRMWARE_UZB500_3CH_X_from05_07_to_UZB500_05_07.bin","released":"2017-04-18","comment":"Update firmware to 2 channels (EU/RU/US/ANZ/MY/IL/..) on 05.07","position":"58","version":"5.7"}]}
                          #32
                          I went to read the map myself and here are the steps I would take:
                          5.7 -> 5.7 40196 BL -> 5.27 ->5.36 ->5.39
                          So yes Bootloader first in general but need to read the version.
                          Also there is a hex to dec you need to do to understand the numbering. 7278 is 29304 and is likely a bootloader downgrade. You need to know what version of bootloader you are on right now.
                          • parkercP Offline
                            parkercP Offline
                            parkerc
                            #33
                            Using the control ‘Show Controller Data’ option, it looks like my bootloader is 40196
                            So based on your recommendation I would do the following..
                            Update firmware to 5.25
                            Update firmware to 5.36
                            Update firmware to 5.39
                            • parkercP Offline
                              parkercP Offline
                              parkerc
                              #34
                              Just to confused matters,
                              I’ve upgraded the bootloader to 7278, and the information in the system has changed to 29304
                              And I’m now presented with another bootloader option..
                              This time.. 9d04 , which hex to Dec = 40196 - which means I downgraded the bootloader ?
                              This is turning out to be far more complicated than I thought - I had hoped the expert UI would guide me through the required sequence so I have the latest version .
                              So now we have 5.22 and 5.23 added In to the mix ?
                              Sorry for all the questions 🙁
                                So indeed as I said 7278 seems to be a downgrade. I wouldn’t have run the boot loader update knowing that my boot loader number was already higher. Sorry for not being clear. You indeed need to be on 40196 and then move on from there as I described from my previous post.
                                • parkercP Offline
                                  parkercP Offline
                                  parkerc
                                  #36
                                  Thanks for all the guidance @rafale77
                                  I’ve reapplied the bootloader update, and have started to go through the incremental firmware updates..
                                  Update : What’s interesting is after going to 5.25, it gives me two sideways options of ‘normal’ and ‘bridge’ version ?
                                  Assuming it’s knows what it’s doing 🙂 - and to try to keep moving on, after going to 5.26, (which admittedly was not in our earlier list), I now have the following options .
                                  Trying to work out the correct path to take (factoring what ‘active; and what not) is a puzzle in itself_
                                  All..
                                  EDCF246F-42CA-4CF3-9873-835580FBA716.jpeg Active ..
                                  Looking at the published firmware releases, is that the path I ultimate want to take ?
                                  So, that would suggest 5.27 firmware (not bridge) next - rather than 5.33 ? (Any idea why there are all duplicates ?)
                                    #37
                                    You didn't need to go to 5.26. As you can see from the graph, 5.27 is kind of a central version from which they build many upgrades from so it is the pivotal version. I only use the static versions of the firmware.
                                    5.33 is a dead end. Don't go there.
                                    parkercP 1 Reply Last reply
                                      parkercP Offline
                                      parkercP Offline
                                      parkerc
                                      @rafale77 said in UZB/RaZberry Firmwares - Update:
                                      I didn’t seem to have any other option, (based on the earlier screenshot) all I could do was upgrade from 5.25 to 5.26. But now I’m on 5.26, I do have the 5.27 option..
                                        ha... such a complicated scheme... it really didn't need to do so. But anyway, once you get to 5.27 you can practically go anywhere you need.
                                        • parkercP Offline
                                          parkercP Offline
                                          parkerc
                                          #40
                                          Hi @rafale77, seems I’ve reached another block, trying to move from 5.26 to 5.27 😞
                                          And now over 3,600 items appeared in the queue..
                                          I’ve tried a couple of times , same result..
                                            162.9k
