  2. Hardware
  3. Z-Wave.me
  4. UZB/RaZberry Firmwares - Update
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
45 Posts 7 Posters 31.5k Views 7 Watching
    Thanks for the info. Does your stick have a "true" serial number? Mine has the same serial number of other peoples that bricked on the z-way forum "04.19.01"
      I am not seeing a serial number but have a UUID which I assume is unique and a subvendor ID of 0x0115
        3rd UZB and it appeared to upgrade. (Via GUI) I upgraded from 5.27 to 5.36. Then upgraded to 5.36 to 5.39. @rafale77 , Since you are on 5.39, does your show anything in the SDK Version line? Mine did before the upgrade to 5.39.
        On the firmware upgrade page it shows this now. But they do nothing.
          It is normal. No I am not seeing an SDK version because... it is too new. This will apparently will be fixed in the next version of z-way. It is in fact 6.82.1
            Trexx
            Thanks Rafale77 for your patience/help. Now I have to jump over to your GitHub page/directions for copying my existing ZWave NW from Vera onto the ZWay.Me and get the existing security key 🙂
              Great! Let me know if you need any help or if the documentation needs improvements.
              • parkercP Offline
                parkercP Offline
                parkerc
                #21
                Hi @rafale77 or any others in this coMmunity who might be able to help., I‘m looking to upgrade my UZB USB module, - which is plugged into to a USB hub on my PI - to the latest firmware..
                Using the guide here..
                https://z-wave.me/zmeserialupdater-manual/
                I’ve so far done the following..
                wget https://z-wave.me/download/ZMESerialUpdater.tgz
                tar -zxvf ZMESerialUpdater.tgz
                cd ZMESerialUpdater/arm/
                chmod +x ZMESerialUpdater
                To be sure the software is working and also to check what FW I currently have - I ran the following command.
                pi@raspberrypi:~/ZMESerialUpdater/arm $ sudo ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyACM0
                Which gave me this...
                Z-WAVE Serial API Tool
                    Version:LWE0.9
                    by Z-WAVE>ME
                       Device ready in:1.01568007469 seconds
                                 FULL INFO
                Openning port                            ..............................                            OK
                          SERIAL INFO
                                 VERSION:  05 05  VENDOR:  01 15
                          ZME_CAPABILITIES
                                     UID:  7B 93 21 D8 62 1E C2 2B 4F 6E 8B 94 A3 05 01 36
                                  VENDOR:  00 00   NODES: FF
                                   FLAGS:  05 00 00 00 00 00 00 00 00 00 00 00 00
                          FIRMWARE CRC
                                    BOOT:  BB BB      FW:  75 7B
                          MISC
                                    FREQ:  EU
                                                         NVR Content
                          Prog/erase lock :  FF FF FF FF FF FF FF FF, Read back lock: FF
                          Rev 01, Cal 06, TXCal  17 13, SAW  FF FF FF FF, Pin FF, CRC  3E CE
                          NMV: CS 15, TYPE 02, SIZE  01 00, PSIZE  01 00 (EEPROM M25PE20)
                          USB: VID  FF FF, PID  FF FF, UUID  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                          FACTORY ID: WEEK 51, YEAR 16, CHIP  00 01, SER  0B D2, WS 1, HWREV: 00 01, CRC8 04
                          elapsed 3.09909391403 seconds
                The next steps seems to be to find the latest firmware, and that’s where things get a little confusing, as it basically tells you to go and find it via this - https://service.z-wave.me/expertui/uzb-stats/versions-graph.html. and that’s where I get lost ..
                It seems to be suggesting that I need to build my own url (using the following construct below) to download it..
                https://service.z-wave.me/expertui/uzb/add-file_name-here?
                  I would recommend running the upgrade through the z-way-server expert UI if you can. It makes things a lot simpler. Using the firmware tool works better but is a bit of a learning curve. Indeed if you open the version graph, you need to find which firmware version you currently are on and clicking on the corresponding dot on the graph opens a simple page listing all the url of every possible downgrade/firmware available from that version. This is where you get the url to use with the tool...
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    #23
                    I downloads the software and installed the zway stuff, and then useD the ‘ExpertUI’ as described to update the firmware and boot loader; interestingly their website says the latest version is 5.39. - https://z-wave.me/support/uzbrazberry-firmwares/
                    Yet, It seems while I was originally only on 5.05, after two upgrades 5.06 and 5.07 - the software tells me I’m now all up to date.. yet it’s reporting I’m on 5.07..
                    Here’s my updated report.. ..
                    Device ready in:25.022865057 seconds
                              FULL INFO
                              SERIAL INFO
                                     VERSION:  05 07  VENDOR:  01 15
                              ZME_CAPABILITIES
                              FIRMWARE CRC
                                        BOOT:  9D 04      FW:  AE CB
                              MISC
                                        FREQ:  EU
                                                             NVR Content
                      Did you try typing all in the token field ?
                      • parkercP Offline
                        parkercP Offline
                        parkerc
                        #25
                        Hi @SweetGenius, sorry, I’m new to these modules and this whole process
                        What do you mean by the ‘token field’ ?
                        Is it the ‘Action Token’ one, shared in the screen shot above?
                        If so, what goes in there ?
                        Is this where the licensing comes in ?
                        Can you only go so far with the firmware upgrades ?
                        • parkercP parkerc
                          @parkerc
                          On the firmware update page you should see this:
                          Which where you can input the "all" token so you can see all available update paths.
                          • parkercP Offline
                            parkercP Offline
                            parkerc
                            #27
                            Hi, thanks I’ve put ‘all’ in and it provided me with a list, however it still says I’m using the latest firmware ?
                            Also it’s a bit confusing and they mention 5.07 and 5.7 - not sure if that’s an error and they mean the same (5.07)....
                              You should go to 5.27 as the first step. Check in the firmware map to make sure it isn't a dead end. Also you appear to have a boot loader upgrade available too but need to check whether it is a downgrade again from the firmware map.
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                #29
                                Hi @rafale77
                                The map is not the easiest thing to read ? - https://service.z-wave.me/expertui/uzb-stats/versions-graph.html?hw=277&with_hidden image attached is just the active ones
                                Am I on 5.07, or 5.7? If so, is 5.7 to 5.27 not a downgrade, rather than an upgrade ? The command line firmware tool seems to suggest I‘m on 5.07. How do you read it to work out the bootloader? I can’t see the 7278 mention via the expert Ui?
                                  #30
                                  5.07 = 5.7, it would be called 5.70 which doesn't exist.
                                  Also you should try clicking the "all" map which corresponds to the "all" token in the z-way server. Once you find the bootloader and firmware version you are currently running, the map shows you to to get to where you want to go. It's actually pretty intuitive once you get the hang of it. On this map for example you can see that 5.7/40196 appears to be a dead end (have to check the all map to see the whole thing)
                                  • parkercP Offline
                                    parkercP Offline
                                    parkerc
                                    #31
                                    Ok, clicking on UZB all and then 5.7, it gives me the following..
                                    The second one relates to the bootloader upgrade option that’s presented.. is it suggesting I update the bootloader first ?
                                    {"data":[{"id":"252","baseid":"","enabled":"enabled","type":"bootloader","file":"bin","vendorID":"277","bootloaderCRC":null,"appVersionMajor":"5","appVersionMinor":"7","targetBootloaderCRC":"40196","targetAppVersionMajor":null,"targetAppVersionMinor":null,"fileURL":"UPD_BOOTLOADER_UZB_ZME_05_07_04000001_9d04.bin","released":"2018-01-12","comment":"Update bootloader to 9d04","position":"70","version":"5.7"},
                                    {"id":"98","baseid":"","enabled":"disabled","type":"bootloader","file":"bin","vendorID":"277","bootloaderCRC":null,"appVersionMajor":"5","appVersionMinor":"7","targetBootloaderCRC":"29304","targetAppVersionMajor":null,"targetAppVersionMinor":null,"fileURL":"bootloader_UZB_from_05_07_to_7278_2MB.bin","released":"2017-05-12","comment":"Update bootloader to 7278","position":"72","version":"5.7"},
                                    {"id":"88","baseid":"","enabled":"disabled","type":"firmware","file":"bin","vendorID":"277","bootloaderCRC":null,"appVersionMajor":"5","appVersionMinor":"7","targetBootloaderCRC":null,"targetAppVersionMajor":"5","targetAppVersionMinor":"7","fileURL":"UPD_FIRMWARE_UZB500_X_from05_07_to_UZB500_3CH_05_07.bin","released":"2017-04-18","comment":"Update firmware to 3 channels (JP/TW/KR/SG) on 5.07","position":"57","version":"5.7"},
                                    {"id":"89","baseid":"","enabled":"disabled","type":"firmware","file":"bin","vendorID":"277","bootloaderCRC":null,"appVersionMajor":"5","appVersionMinor":"7","targetBootloaderCRC":null,"targetAppVersionMajor":"5","targetAppVersionMinor":"7","fileURL":"UPD_FIRMWARE_UZB500_3CH_X_from05_07_to_UZB500_05_07.bin","released":"2017-04-18","comment":"Update firmware to 2 channels (EU/RU/US/ANZ/MY/IL/..) on 05.07","position":"58","version":"5.7"}]}
                                      #32
                                      I went to read the map myself and here are the steps I would take:
                                      5.7 -> 5.7 40196 BL -> 5.27 ->5.36 ->5.39
                                      So yes Bootloader first in general but need to read the version.
                                      Also there is a hex to dec you need to do to understand the numbering. 7278 is 29304 and is likely a bootloader downgrade. You need to know what version of bootloader you are on right now.
                                      • parkercP Offline
                                        parkercP Offline
                                        parkerc
                                        #33
                                        Using the control ‘Show Controller Data’ option, it looks like my bootloader is 40196
                                        So based on your recommendation I would do the following..
                                        Update firmware to 5.25
                                        Update firmware to 5.36
                                        Update firmware to 5.39
                                        • parkercP Offline
                                          parkercP Offline
                                          parkerc
                                          #34
                                          Just to confused matters,
                                          I’ve upgraded the bootloader to 7278, and the information in the system has changed to 29304
                                          And I’m now presented with another bootloader option..
                                          This time.. 9d04 , which hex to Dec = 40196 - which means I downgraded the bootloader ?
                                          This is turning out to be far more complicated than I thought - I had hoped the expert UI would guide me through the required sequence so I have the latest version .
                                          So now we have 5.22 and 5.23 added In to the mix ?
                                          Sorry for all the questions 🙁
                                            165.5k
