  3. Z-Wave.me
  4. UZB Firmware update failed!
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
3 Posts 2 Posters 1.8k Views 2 Watching
  • D Offline
    D Offline
    domoworking
    Hi all, I hope someone could drive me in the right direction.
    I was setting up a new zware environment using a UZB stick I bought about 2 yeasr ago and never used.
    This stick was using firmware 5.27 that sounded to me a bit old.
    So I looked on the process of upgrading the device and I downloaded the ZMESerialUpdater, the I went on the z-wave.me site and look for the firmware and I found (on this awfull map) the firmware UPD_FIRMWARE_UZB_STATIC_2ch_ZME_05_1b_04000001_ZME_05_24_04000001.bin (that AFAIK should upgrade from version 5.27 to 5.36).
    I run the update and it never finished....
    8899ae1b-c9cc-488b-ba15-870bbf66c044-image.png After 2 hours waiting for nothing, I finally CTRL-C and removed and reinserted the USB stick that is not recognized anymore.
    I really think I won a nice peace of plastic usb shaped, but in case someone has an idea, I would be pleased to read your coment.
    Regards
    • Black CatB Offline
      Black CatB Offline
      Black Cat
      Updating Sigma FW can take time.
      Never remove the UZB until the upload is complete otherwise it will brick itself.
      Resist the temptation, walk away, go for a drive whatever but never remove it until you get the message that it is safe to do so.
      Apparently, the chip can be reset however I have never attempted this.
      You could try the Sigma Z-Wave Programmer, it might recognise the UZB.
      aka Zedrally
      • D Offline
        D Offline
        domoworking
        Hi mate, thank you for your reply. I know it may take time but I never saw a firmware upgrade taking more than 2 hours.... My fault.
        Unfortunately right now the stick is not recognized anymore neither from Windows nor from Linux. It looks like I lost the US2Serial interface....
        I have I ticket opened with the huys at z-wave.me, but meanwhile I bought a SiliconLab Z-Wave 700 stick, so I can try to brick also this one 😄
