  3. Z-Wave.me
  4. Switched from RaZberry to UZB
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
9 Posts 6 Posters 3.0k Views 6 Watching
  • K Offline
    K Offline
    kfxo
      This is what I have been suspecting too: the Razberry PCB antenna is likely not as good as the one on the UZB but most likely it is the fact that it can be located away from a lot of interference sources (the raspberry itself is likely a source)
      C 1 Reply Last reply
        Interesting. Thanks for that. So this is just about RF performance, and ease of siting the antenna, rather than any other differences?
          Yes,
          Technically they are based on the same chip. The uzb has an additional serial to usb interface chip and that's about it.
          I did notice that the razberry has the possibility of adding an external antenna. It requires some soldering job to add a connector though. The solder pads are already there. You also would have to break off the PCB antenna or at least break off the trace connecting to it.
          • Black CatB Offline
            Black CatB Offline
            Black Cat
            The UZB aerial is helictical ( it is in a Black Cat UZB, so I'll assume that they are mostly similar), superior to a copper trace.
            It's radiation pattern is also superior to the polarization of a copper trace.
            You could add a full wave antenna to a UZB, but you will get positive results just with a USB extender and another marked improvement if you add a Powered USB Switch.
            aka Zedrally
            P 1 Reply Last reply
            • Black CatB Black Cat
              P Offline
              P Offline
              powisquare
              @black-cat said in Switched from RaZberry to UZB:
              Would you plug the dongle into the hub or at the end of the extender plugged into the hub?
              Am thinking of powering the pi and a ssd with the same hub (say 15w?) - would there be any downsides to this?
                Black CatB Offline
                Black Cat
                Plug the UZB into the extender which plugs into the powered hub.
                The idea is to supply power to the UZB not other equipment. Best practice would be to power the Pi with it's own power supply.
                aka Zedrally
                  C Offline
                  C Offline
                  chali
                  @rafale77 i added 3 high gpio rizes to my rpi4b and now its -90-95db from -65-70db is really fast now, if you use the fibaro app and plugin to zway it also makes a big difference in speed.
                  • C chali
                    @chali
                    It's a great confirmation, thanks!
                    Note that it is not as simple as the noise: it is the signal/noise ratio that matters. Moving the antenna further from the noise source makes a big difference but the antenna on the UZB may still be more sensitive... meaning it will pick up weaker signals and have a longer range. That part I have not verified.
                    Note also that -95dBm = below detection limit. This was a change I requested to make the data graph cleaner. Before that the data point value would be nil or NaN and therefore distort the graph by showing a lot of step like forms not reflecting the reality.
                      165.5k
