  3. Z-Wave.me
  4. Docker container for Z-Way
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
37 Posts 8 Posters 22.9k Views 8 Watching
    sofakng
    wrote on last edited by sofakng
    • $ZWAY_DIR/config/Configuration.xml
    • $ZWAY_DIR/config/Rules.xml
    • $ZWAY_DIR/config/maps
    • $ZWAY_DIR/config/zddx
    • $ZWAY_DIR/automation/user_syscommands
    • $ZWAY_DIR/automation/storage
    • $ZWAY_DIR/automation/userModules
    • $ZWAY_DIR/htdocs/smarthome/user
    • $ZWAY_DIR/config.xml
      This was all the rage a while ago, but, as you say, they have fallen out of use.
      Not a Docker user myself, but delighted to see an expert here again.
      • S sofakng
        @sofakng
        Welcome!
        Yeah, I myself am not a big fan of docker and I try to avoid it (have been successful so far) as I see the complications and overhead it brings far outweigh the benefits. Maybe you could explain why you are pursuing this route? I see that you are coming from the home assistant forum as well where there is a raging debate about their supervisor structure. Even there I have been questioning the reason for using containers at all when I already saw no significant benefit of using a python venv. I am very puzzled by this approach.
          sender
          Me 2... might well be that your container becomes a home assistant add on... 🙂
            I would be very interested in a docker image for zway server. I have a Synology DS216+ running docker. If there was a working zway sever image i would purchase the UZB stick and try this instead of buying a Raspberry pi and running another piece of hardware. I'm excited to move from my Veraplus to zway and i am exploring options.
            @sofakng I did try your image (with out a UZB stick yet) to see if it would load. It loads but does display lots of SSL DEBUG LOCK: 2 > 1 SSL DEBUG LOCK: 2 > 0 messages during install. Ideas? The GUI comes up fine. I do not know how to see what version of the server from the GUI but during install it did show loading v3.0.6.
              So... bit of a hanger-on N00b question here: Have any of you lads managed to get Z-Way (ZWave.me) working in a Docker container, on a Synology NAS, using the UZB dongle? (Wow, that was a mouthful! And I purposely left out any mention of OpenLuup, even.)
              S 1 Reply Last reply
              • LibraSunL LibraSun
                @librasun
                I, being a Noob with docker, used PerH's image with a run command on my Synology. It runs and I can see the UZB dongle from the interface but I haven't added any devices yet. There are a couple of things that I do not think are quite right though. Read the the thread "z-way-server new release" I posted those issues there. Also search the Zwave.me forum for "Docker" and PerH posted a docker file and compose file but the version is not right for the compose file with the Docker version on the Synology, that is why I used a run command.
                  Which version do you need for Synology? Its probably not much different, i think it might just be syntax on volumes/binds?
                  • PerHP PerH
                    @perh The docker version on the Synology is 18.09.8, so looking on the docker documentation i would say v3.7 compose file. Not sure what you are doing with the static IP's either.
                    Sorry I am not very familiar with docker but willing to learn. Thanks.
                      I’m following with interest, with exactly same needs as @SweetGenius – ZWay on Synology Docker will be the final nail in the coffin for my last Vera and a RPi, which will simplify support no end.
                      So RIP RPi and Vera!
                        We're clearly thinking along the same lines here lol.
                          wrote on last edited by PerH
                          looking at the compatibility matrix, it seems like differences are in options I don't use in my file, did you try to change line 1 to version: "3.7"?
                          regarding networks:
                          I have several dockers, and Openluup/InfluxDB/Grafana/etc is all communicating inside this network.
                          The "networks:" part needs to define this network for each docker-compose file in order to tie them together, so it will show an error if you do docker-compose down on one docker while other dockers are connected. and thats OK.
                          Edit: you could skip the "networks:" definitions all together, but then you would have to open ports for intercommunication as well to the host. I found that to be over complicating when you can have internal communication. 🙂
                          Wrt. timezone sync:
                          I haven't done timezone in z-way, as it hasn't been nessecary as i'm using openLuup for control an logging, but i've added the sync lines like I did in the openluup compose file below.
                          I just tested the code below, and it worked on my testbench.
                          version: "3.7"
                          services:
                            Z-Way:
                              container_name: Z-Way #or what you want to call it
                              restart: always
                              image: perhu/z-way-server-3-1-3:latest
                              networks:
                                HAnett:  #or whatever you internal docker network is called
                                  ipv4_address: 192.168.0.2  #this volume gets this IP in the internal network
                              ports:
                                - "8083:8083" #UI port
                              volumes:
                                - type: bind    #timezone sync
                                  source: /etc/localtime
                                  target: /etc/localtime
                                - type: volume
                                  source: Z-Way-zddx #Device info storage (i think)
                                  target: /opt/z-way-server/config/zddx
                                - type: volume
                                  source: Z-Way-storage #application settings
                                  target: /opt/z-way-server/automation/storage
                              devices:
                                - "/dev/serial/by-id/usb-0658_0200-if00:/dev/serial/by-id/usb-0658_0200-if00" #your device here
                              environment:
                                - ZWAY_VERSION=3.1.3
                              logging:
                                  driver: "json-file"
                                  options:
                                      max-file: "5"
                                      max-size: 10m
                          networks: #I set up a network for the dockers to communicate, with static IPs
                              HAnett:
                                  driver: bridge
                                  ipam:
                                      config:
                                          - subnet: 192.168.0.0/16 #subnet of choice
                                            gateway: 192.168.0.254 #gateway ip (this can be used to reach ser2net devices on host)
                          volumes:
                            Z-Way-zddx:
                            Z-Way-storage:
                          EDIT: added the "logging:" settings in the code above. I've done this to all my dockers, as logs were stored without limit and ended up filling my HD!
                          • PerHP PerH
                            regarding networks:
                            Wrt. timezone sync:
                            version: "3.7"
                            services:
                              Z-Way:
                                restart: always
                                networks:
                                ports:
                                volumes:
                                  - type: volume
                                  - type: volume
                                devices:
                                environment:
                                logging:
                                    driver: "json-file"
                                    options:
                                        max-file: "5"
                                        max-size: 10m
                                HAnett:
                                    driver: bridge
                                    ipam:
                                        config:
                            volumes:
                              Z-Way-zddx:
                              Z-Way-storage:
                            @perh Thanks for the all the help ! A couple more questions if you don’t mind: PoltoS mentioned the volume should be zddx instead of zddl. I assume that is in the docker file but does that change anything in the compose file?
                            Im confused with the volumes: sections, With the run command that I used that had data created in the storage folder was:
                            sudo docker run --restart=always -p 8083:8083 --device=/dev/ttyACM0 --name="zway" -v /volume1/docker/zway/zddl:/opt/z-way-server/config/zddl -v /volume1/docker/zway/storage:/opt/z-way-server/automation/storage perhu/z-way-server-3-1-3:latest
                            Can you explain how to put these paths in the compose file because when I try i do not get any thing in the directories? So obviously i still don't understand the compose file.
                              ah, it should be zddx, yes. I've corrected that in my own dockerfile and docker-compose, but haven't fixed it on the forums. sorry.
                              The change is both in the dockerfile and compose file. replace "zddl" with "zddx".
                              The docker-compose file uses docker volumes instead of binds. docker has its own system for persistent storage, volumes, that is stored in /var/lib/docker/volumes.
                              In your run command you use binds to host folders, which can also work if you declare it like this:
                                  volumes:
                                    - type: bind
                                      source: /volume1/docker/zway/zddx
                              like i did in the above file with the time zone folder.
                              I ended up using the docker way instead as that was recommended in the docker documentation, but as long as you keep strict control of the folders you bind to, that will work too.
                                did anyone test the updated docker-compose on synology? I'm curious to if that was all it took to make it work there. 🙂
                                • PerHP PerH
                                  @perh I did try your docker-compose and it does run just like the run command. So I think that part is good but the image still has some issues. I installed zway on a rpi again to see how it works. The remote access error was there until a reboot and then went away. That is without touching the config of remote access. Setting the time zone set and then prompted for a reboot and all was well. I think there is some permission issues or something else because this does not happen on the docker image. On all the other docker images I use (MSR, Homeassistant, Homebridge) i shut the container down, update the image, action clear and the container would update and not lose any settings. I did a action clear on this image and it was like a brand new image. No settings were saved. Sorry to say It Idont think it is totally working. I sure appreciate your help and expertise.
                                    Ok. Just checked my installation, and i have removed the remote access app completely, and according to @PoltoS, the error message would stay there if you don't set that app up. It is the one that appears twice when you go into "Settings", right? Did it go away just by rebooting on the non-docker install?
                                    Timezone:
                                    My timezone is working correctly now, as it is defined to Europe/Oslo in the image. that can be overridden by this in docker-compose:
                                        environment:
                                          - TZ=Europe/Oslo
                                    (adding that last line with your timezone)
                                    I thought that changing it in the Z-way UI would do the same, but mabye not?
                                    persistent storage:
                                    How did you do the folders? Did you use the docker-compose as-is, or change to binds to your /folder1/ folders?
                                    I don't have a synology, it might be an issue with binds on that?
                                    you should perhaps go over to volumes in that case, you can still access the volume the same way as a bind folder by going to /var/lib/docker/volumes/*volume name*/_data.
                                    Are you using docker-compose up -d and docker-compose down to start and stop/remove the container?
                                    Definately no expert on dockers yet, but its an interesting thing to learn. 🙂
                                      On the non-Docker install it just went away. On your docker image, no remote access is installed at first and there is the error. If I install it and make it not active it warns that is not active. If make it active it keeps prompting to make it active... I am using your compose file with the exception of taking out the network stuff and adding my time zone in the environment settings. The time zone will show up after fiddling with it but if you try to change it to something different than what is set in the compose file it errors. Is the update supposed to work? If so, I need to put back in some network settings as it does not work the way it is.
                                        One other note on the network, All the other docker containers i use, I do not specify an IP. You access each container by the Synology IP:Port. So, this might be different but I do not know for sure. Just giving you information.
                                          Ok. Sounds like some other folder of z-way needs to be persistent too, which holds info on the plugins.. I'll ask @PoltoS.
                                          Not sure about the timezone update, i'll have to try that later. Usually its not nessecary to change after you set it in docker compose though.
                                          The reason for the static IP's is to use the internal docker network for all communication between the dockers. I only expose the web UI ports of the applications, as all communication between the docker applications goes internally on the docker network. I.e. InfluxDB, which has no web UI (that i use), have no exposed ports, and it sends and recieves everything on the docker network.
                                          This also exposes less ports on the host, which may be better security-wise?
                                            165.5k
