  4. Timers in my log
Timers in my log
26 Posts 3 Posters 10.3k Views 3 Watching
    #21
    OK. Non-problem. Everything is fine. These are just debug messages from my previous investigation into scheduling of re-evaluations on time-based rules (PR #34 and 44 specifically). For that, I used the "always" log level (hence the "null" reported where the level goes in the logged messages). This is just normal start-up. When you start Reactor and it brings up the Engine, it reads all the rules, does an initial scan for dependencies, then evaluates all the conditions, which sets the timers for the next event based on current (post-startup) conditions. All is well.
    The logs do not show they are rolling. If you had a continuous stream of timer messages, that would be noteworthy, but getting a timer messages for every time condition in any rule is expected at start-up. If there were further timer messages at unexpected time, the logs provided don't show that.
    • MatohlM Offline
      MatohlM Offline
      Matohl
      No problems, everything is working well. I will check my logs in the coming days.
      • K Offline
        K Offline
        kfxo
        That actually makes perfect sense and upon further inspection I see that the timers I was noticing in the logs are with respect to one rule that I had recently turned on that resets often.
          I'll put a proper level on that debug now that I'm not targeting that area as well. That will keep the log chatter down.
          • MatohlM Offline
            MatohlM Offline
            Matohl
            Thank you Patrick, the MSR is awesome 🙂
              Not yet, but it's on its way. Definitely showing promise. Thanks for your help is making it work!
                146.1k
