  3. Vera
  4. Vera Alexa Plugin 7.32
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
119 Posts 7 Posters 69.4k Views 5 Watching
    #61
    Yep, tried that. Changed GroupZones= to "Sonos Beam" (name of my Alexa-enabled Sonos device also known as "Living Room"), and still... silence.
    But thanks for the tip to try!
    Oh wait! You're saying try piping the command to the SONOS service instead of the 'bochicchio' one... hold on... gonna try.
    Answer: NOPE. Still same "Sorry, I'm having trouble accessing ___ skill right now."
    PablaP 1 Reply Last reply
    • LibraSunL LibraSun
      @librasun I will try to get logged in later today to try these commands and see if I can reproduce these issues
        Fun times. I took my own advice and completely removed VeraAlexa plug-in from my Vera Plus (making sure there were no hidden devices lurking, then executing a device > remove command via HTTP request in my browser). Rebooted, restarted MSR (so it would forget about deleted Entity), copied ZIP from Github, loaded files onto Vera, restarted Luup engine, created Device (it starts hidden!), restarted Luup engine again, see device in UI (no name), restart Luup yet again, see "Alexa" device, says "Configured=1" (yay!), update its "DefaultEcho" variable, etc., restart MSR in Docker, hard refresh all browsers.
        And I'm back. Now HERE is the fun part... SOME of the "Say" commands work now, some ALMOST do, and others still do not.
        WORKS // says "Hello from Vera Alexa"
        luup.call_action("urn:micasaverde-com:serviceId:Sonos1", "Say", {Text="Hello from Vera Alexa"}, 345)
        ALMOST WORKS // says "Domain" and stops
        luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say", {Text='<amazon:domain name="conversational">Hello from Alexa</amazon:domain>',   Volume=10, Repeat = 1}, 345)
        DOES NOT WORK // says "Sorry..." error message
        luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say", {Text='<voice name="Raveena">Hello from Vera Alexa</voice>', Volume=40,GroupZones="Living Room"}, 345)
        I must be a bad person.
        @librasun said in Vera Alexa Plugin 7.32:
        I forgot entirely about the default echo. Mine was 3 floors away this morning.
        I don't have a Sonos so can't test that bit but
        luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say", {Text='<amazon:domain name="conversational">Hello from Alexa</amazon:domain>', Volume=10, Repeat = 1}, 22)
        Works
        luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say", {Text='<voice name="Raveena">Hello from Vera Alexa</voice>', Volume=40}, 22)
        Works.
        I am not on Vera though. Openluup with full JQ AFAIK
          Perhaps my never having used OpenLuup, that could be the key differentiator between my setup and yours and @therealdb 's?
          I'm on a stock Vera Plus running 7.32 firmware. I'm sending all Lua commands via MSR for testing purposes.
          PablaP ElcidE 2 Replies Last reply
            @librasun alright just logged in and tried these and Libra you’re not going crazy.... I am having the exact same responses about the Simon says skill
              ElcidE Offline
              ElcidE Offline
              Elcid
              wrote on last edited by Elcid
              #66
              @librasun Have you tried to install JQuery on the vera, it's is now available with 7.32
              LibraSunL 1 Reply Last reply
              • ElcidE Elcid
                @elcid said in Vera Alexa Plugin 7.32:
                Uh oh, I thought "jq" was a package included with 7.32? I'd scoured @therealdb 's notes and ReadMe, seeing references to "jq" (never once thinking that meant "JQuery").
                How does one "install" "jQuery" on Vera??
                • ElcidE Offline
                  ElcidE Offline
                  Elcid
                  ssh in and run
                  opkg update
                  opkg install jq
                    @librasun The plug-in will take care of it. So, just set configured to 0 and it will install it.
                    I've had a very busy week, but tomorrow I'll have more time to re-try from scratch. Keep in mind that this is using some internal amazon stuff and the chances that they changed something is high. Anyway, it should not create <s>... unless you have announcements enabled. I'll take a deeper look tomorrow. I've tested with 7.32 beta, but not this build, and it worked, but I've not tested all the possibile variants.
                      Also if anyone in the future has Cookie issues, you must turn of JavaScript in Firefox to get the correct cookie file, I didn't and it wasn't working.
                      LibraSunL ElcidE 2 Replies Last reply
                        @pabla said in Vera Alexa Plugin 7.32:
                        Does this apply to Chrome as well? And if so, do you mean "Disable Javascript" for all sites, forever? Or just while VeraAlexa plug-in is configuring itself?
                        (Because I did none of that. 🙂
                          @librasun I am not sure if it applies to chrome but I assume it would, because when you disable JavaScript and login you get the Captcha login screen (which is what you are trying to bypass).
                          Yes temporarily disable JavaScript until you have got the cookie file.
                            ElcidE Offline
                            ElcidE Offline
                            Elcid
                            #73
                            @pabla I never turn off JS, I use Export Cookies Addon to export to a txt file. I will add i do it on Android Firefox I login to layala.amazon.co.uk. Once logged in i export amazon.co.uk to text file. I then copy the contents to .alexa.cookie
                            • ElcidE Elcid
                              @elcid I never used to have to turn off JavaScript in the past, but I had to this time around which was odd.
                                Perhaps wise advice, but I'm gonna sit on my hands for now if only because the .alexa.cookie file manifested without any fuss when I first installed the plug-in. I took that as a sign that all is well.
                                Unless advised otherwise and/or someone explains how to examine the cookie file to know I got the "wrong" one?
                                  @librasun if you get the Captcha error in the LatestResponse variable then you'll need to manually grab the file. In your case though, seems that you didn't get a captcha error when you first logged in.
                                    I thought it might interest you guys to know that Twilio would charge me between $0.0008 and $0.0032 per 100 characters to generate synthesized speech (TTS) using Amazon's SSML voice API. However, that interface is intended for phone calls (which I've used in the past for automated responses and such).
                                    Guess we should be grateful that it's possible to get the same results for free via Vera/Alexa. 🙂
                                      Thoughts on sound effects folks?
                                      luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command="-e sound:amzn_sfx_trumpet_bugle_04",Volume=49, GroupZones="Living Room dot"}, 22)
                                      Works fine but
                                      Bears no resemblance to the file library names listed here:
                                      Alexa Skills Kit Sound Library | Alexa Skills Kit
                                      Use the sound effects in the Alexa Skills Kit Sound Library in your Alexa skill.
                                      What do I need to do to make something like:
                                      soundbank://soundlibrary/air/fire_extinguisher/fire_extinguisher_08
                                      Work?
                                      TIA
                                        #79
                                        The filename I see listed at the link you shared is amzn_sfx_trumpet_bugle_04 which appears to match.
                                        Not sure what you're calling "different"?
                                        I notice that the other sound effect you hunted for appears to be <audio src="soundbank://soundlibrary/air/fire_extinguisher/fire_extinguisher_08"/> which I take to mean "fire_extinguisher_08" gets substituted in place of the bugle reference in your Lua command.
                                          Sorry. I can't give a direct link to one of the files in the sound library but they are listed like:
                                          <audio src="soundbank://soundlibrary/aircrafts/helicopter/helicopter_13"/>
                                          But replacing amzn_sfx_trumpet_bugle_04 with helicopter_13 doesn't do anything.
                                          Is that making sense?
                                            154.0k
