  3. Vera
  4. Vera Alexa Plugin 7.32
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
119 Posts 7 Posters 69.4k Views 5 Watching
    Vera beta, not VeraAlexa I assume?
    So glad I stopped with it! There's so much I should do with OpenLuup but I lack both the imagination and the skill, but thanks to all on here, have a rock solid system!
    PablaP 1 Reply Last reply
      @catmanv2 ha whoops didn’t even check I posted in the correct thread.
        This still is hacky, because it's based on unsupported feature, but me and many others have it running since 3+ years. The point is to
        • ensure you could get a cookie. If not, the best thing to do is to install on a pi or similar and use via oath tool and openluup
        • use exact names for devices, because it's case sensitive
        • avoid groups, unless you have announcements enabled
        • avoid complex voices, unless you have announcements enabled
        • try with debugmode set to 1 and looking at live logs
        I'm always open to PRs for docs and a UI, if anyone wants to contribute. I've not invested so much into a proper UI because I still think it's not really necessary, but it doesn't mean that one of you could not step in and do it 😁
        #103
        @therealdb Has the 'runroutine' action been deprecated?
        I just tried sending:
        luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1",
          "RunRoutine",
          {RoutineName="Time for Cooking", GroupZones="Living Room"}, 345)
        and got back this error:
        ERROR: unknown command "automation:Time for Cooking"!
        ...along with all the possible valid options...
        /storage/alexa/alexa_remote_control_plain.sh [-d <device>|ALL] -e <pause|play|next|prev|fwd|rwd|shuffle|repeat|vol:<0-100>> |           -b [list|<"AA:BB:CC:DD:EE:FF">] | -q | -n | -r <"station name"|stationid> |           -s <trackID|'Artist' 'Album'> | -t <ASIN> | -u <seedID> | -v <queueID> | -w <playlistId> |           -a | -m <multiroom_device> [device_1 .. device_X] | -lastalexa | -l | -h    -e : run command, additional SEQUENCECMDs:         weather,traffic,flashbriefing,goodmorning,singasong,tellstory,         speak:'<text>',sound:<soundeffect_name>,         textcommand:'<anything you would otherwise say to Alexa>'    -b : connect/disconnect/list bluetooth device    -q : query queue    -n : query notifications    -r : play tunein radio    -s : play library track/library album    -t : play Prime playlist    -u : play Prime station    -v : play Prime historical queue    -w : play library playlist    -a : list available devices    -m : delete multiroom and/or create new multiroom containing devices    -lastalexa : print serial number that received the last voice command    -login : Logs in, without further command    -l : logoff    -h : help
        In brief, I see no reference (except in the ReadMe back at GitHub) to the 'RunRoutine' action, neither does trying to execute a routine through the 'textcommand' method. Any suggestions?
        • LibraSunL LibraSun
            "RunRoutine",
          @librasun routine is a shortcut for -e automation:'ABC'.
          In my experience, no space will work better, and sometimes you'll have to replace with _. ie 'Time_for_Cooking'
          I'm using routines daily, to trigger things (ie, when the alarm is off, when we are going to bed to read my calendar, weather, and house status via a virtual device on HA-bridge, etc) and it's working no problem since day 1.
            I'll gladly give that a whirl, thanks again. Sorry to always take up your time with such mundane things like this!!
              @librasun no worries, I’m happy to help 😉
                #107
                Sadly, not a single time has either version ("RunRoutine" or "-e automation:") of this construct worked. It always, always claims it's an unknown command (as I shared earlier). I've used precisely the syntax from the docs, and this thread, and only those. Makes me wonder what the heck is going on. 😕
                About to resume giving up. My only hope at this juncture was to have Vera kick off an Alexa routine. She can speak, start (non-routine) commands, make music, give the weather, etc. But not this one thing. Argh.
                  @librasun post your variables, minus the username and password. Let’s see how it’s configured.
                    Here ya go:
                    device #345
                    DebugMode
                    BinPath
                    /storage/alexa
                    Username
                    xxxxxxxxxxxx
                    Password
                    xxxxxxxxxxxx
                    DefaultEcho
                    Living Room
                    DefaultVolume
                    50
                    AnnouncementVolume
                    50
                    Language
                    en-us
                    AlexaHost
                    pitangui.amazon.com
                    AmazonHost
                    amazon.com
                    UseAnnoucements
                    DefaultBreak
                    OneTimePassCode
                    CommFailure
                    CurrentVersion
                    0.92
                    LatestResponse
                    ERROR: unknown command "automation:Time_for_Cooking"! /storage/alexa/alexa_remote_control_plain.sh [-d
                    Configured
                      Oddly there is a bugle_03 and that doesn't work either
                      Nor 01 or 02 and they are in exactly the same format.
                      @catmanv2 said in Vera Alexa Plugin 7.32:
                      Check out the part of this documentation that describes:
                      "Unfortunately, you have to try out the possible sound library entries . Of the four possible trumpet sounds, only the one shown above works, for example. You can see what sounds there are when you add "tones" to a routine."
                        #111
                        @therealdb somehow, on my own, I unearthed an update to alexa_remote_control_plain.sh (v0.17c -- I had been using v0.17a (now safely backed up!) until today), and it seems one step closer to honoring the RunRoutine verb. At least it doesn't throw errors in the Log or in the Variables section. Still total silence, though!
                        Here's how it looks in the LuaUPnP log:
                        08	04/15/21 18:31:59.634	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunLua <0x6e6ec520>
                        08	04/15/21 18:31:59.634	JobHandler_LuaUPnP::HandleActionRequest argument Code=luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1", "RunRoutine", {RoutineName="Time for Cooking", GroupZones="Living Room"}, 345) <0x6e6ec520>
                        08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=0 <0x6e6ec520>
                        08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x6e6ec520>
                        08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument action=RunLua <0x6e6ec520>
                        08	04/15/21 18:31:59.635	JobHandler_LuaUPnP::HandleActionRequest argument _r=1618529519635 <0x6e6ec520>
                        08	04/15/21 18:31:59.636	JobHandler_LuaUPnP::HandleActionRequest device: 345 service: urn:bochicchio-com:serviceId:VeraAlexa1 action: RunRoutine <0x6e6ec520>
                        08	04/15/21 18:31:59.636	JobHandler_LuaUPnP::HandleActionRequest argument GroupZones=Living Room <0x6e6ec520>
                        08	04/15/21 18:31:59.636	JobHandler_LuaUPnP::HandleActionRequest argument RoutineName=Time for Cooking <0x6e6ec520>
                        50	04/15/21 18:31:59.638	luup_log:345: VeraAlexa[0.92@345](setVar@126):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",345) old value "" <0x6e6ec520>
                        50	04/15/21 18:31:59.638	luup_log:345: VeraAlexa[0.92@345](runRoutine@348):Executing command [runRoutine]: "-e automation:\"Time for Cooking\" -d \"Living Room\"" <0x6e6ec520>
                        Should I uninstall the plug-in and re-install it from scratch from your GitHub repo? I'm assuming you keep updating it based on new releases, and now I'm worried that simply pasting the contents of v0.17c into the existing .sh file on Vera may not have been the best approach. (Seemed smart at the time.)
                        EDIT: It wasn't a smart idea, since everything stopped working (i.e. no Alexa commands would do anything any more), so I swapped back the v0.17a version of the .sh file on Vera.
                          @librasun if you set Configured variable to 0, it will download the sh script again.
                          set DebugMode var to 1 and see if jq is successfully detected, because it's a pre-requisite for routines.
                          LibraSunL 1 Reply Last reply
                            @librasun said in Vera Alexa Plugin 7.32:
                            Thanks, that'll give me something to read!
                              #114
                              @therealdb Oddly, no mention of jq in the log. I'll need to be reminded how to (re)install jq so I'll go check the Docs (EDIT: Nope, they don't explain how, nor where to find it.) for the 100th time, lol.
                              Wow, this whole Vera Alexa thing has turned into quite the balancing act. So many moving parts! 😕
                              EDIT: I found elsewhere on the old MCV forum, after much Googling, this reference to jq and where it comes from, namely:
                              it’s a package to parse json via command line: https://stedolan.github.io/jq/
                              You’ll have to build yourself and load in your unit.
                              Sadly, that is all Greek to me. (And here I thought jq somehow "came with 7.32 firmware", lol.) So I kept searching...
                              EDIT 2: Looks like 22 days ago, I was informed: "The plug-in will take care of it. So, just set configured to 0 and it will install it." Turns out I've done that twice since, so naturally assumed jq is indeed installed on my Vera.
                              Screenshot from file search (for "jq*") in WinSCP as (false) "proof":
                              Still frustrated... on a hunch that the above just means jquery (not jq) is installed, I then followed @Elcid 's advice from the same post:
                              ssh in and run:
                              opkg update
                              opkg install jq
                              So I PuTTY'd into Vera, did those things, and I saw these freshly installed files...
                              Then I restarted Vera's Luup engine one more time, and ....
                                #115
                                AND HOLY CRAP, IT WORKS NOW!! The Last Response variable finally shows a successful...
                                sending cmd:automation:Time for Cooking to dev:Living Room type:A15ERDAKK5HQQG serial:eb48978706f5459f890ef0ec5aa9fce9 customerid:A3SL3Z0HELH3YG
                                and the Alexa Routine that I've been trying to run all week finally ran from MSR!
                                Now, it's on to troubleshooting this command, which no longer responds with an error, or the odd response "Domain!", but just vexing silence after altering the volume level to '50':
                                luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","Say",{Text='<amazon:domain name="conversational">Hello from Vera Alexa.</amazon:domain>', Volume=50, Repeat = 2}, 345)
                                And dang it, now this one has stopped working (i.e. no error thrown, just silence):
                                luup.call_action("urn:micasaverde-com:serviceId:Sonos1", "Say", {Text="Hello from your Vera Alexa"}, 345)
                                You can never quite win. <facepalm> Now, all the formerly working routines are silent. Argh!
                                And since I could detect no "Error" conditions in the log, I went back in via WinSCP and discovered that a new file alexa_remote_control.sh (along with a bunch of others named alexa.volume.db99...) had mysteriously appeared, but was v0.17c (shown above not to work), so I temporarily renamed it, and renamed the v0.17a file to `alexa_remote_control.sh' whereupon all my formerly working commands resumed working. Oh, man, what an unending journey. Think I'll stick with solving Sudoku puzzles!
                                (So I renamed the files as Vera Alexa had them and ran away.)
                                  @librasun yeah, so many moving parts, but you should be set. I'll probably write somethingi n the var in order to let you use your custom version anyway 😉
                                  Ping me next time it'll overwrite your file!
                                    @therealdb said in Vera Alexa Plugin 7.32:
                                    Cool. For the time being, I'm taking the "sledgehammer" approach, deleting the "Alexa" device from my Vera, deleting the VeraAlexa files from cmh-ludl and rebooting. Then I'll grab the ZIP from your repo anew, reinstall it per instructions, and see what happens.
                                    I've literally got nothing to lose at this point (except more time). 🙂
                                      It would be quicker to ditch it and go OpenLuup. Just saying 😉
                                        #119
                                        Undoubtedly. I've got OpenLuup installed (but not currently running) as a Docker container, for future exploration.
                                        Meanwhile, I went ahead and re-downloaded Vera Alexa from Github, installed it (seems to be version 0.94 instead of 0.92), did a million restarts to get the new device recognized, configured, and stable. Seemed to really lag on some of those steps, but can confirm full configuration achieved, 'Alexa' folder present, cookie and all.
                                        Next, on to testing... as expected, in rev. 0.94 (using the v0.17c .sh file), every say or command attempt results in silence but no errors**, while the routine action works perfectly. Exactly the opposite of rev. 0.92 (using the 0.17a .sh file).
                                        **Here's a typical log entry in Debug mode:
                                        08	04/16/21 11:42:50.143	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunLua <0x723cc520>
                                        08	04/16/21 11:42:50.144	JobHandler_LuaUPnP::HandleActionRequest argument Code=luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command="-e weather -d 'Living Room'"}, 366) <0x723cc520>
                                        08	04/16/21 11:42:50.144	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=0 <0x723cc520>
                                        08	04/16/21 11:42:50.144	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x723cc520>
                                        08	04/16/21 11:42:50.144	JobHandler_LuaUPnP::HandleActionRequest argument action=RunLua <0x723cc520>
                                        08	04/16/21 11:42:50.144	JobHandler_LuaUPnP::HandleActionRequest argument _r=1618591370147 <0x723cc520>
                                        08	04/16/21 11:42:50.145	JobHandler_LuaUPnP::HandleActionRequest device: 366 service: urn:bochicchio-com:serviceId:VeraAlexa1 action: RunCommand <0x723cc520>
                                        08	04/16/21 11:42:50.145	JobHandler_LuaUPnP::HandleActionRequest argument Command=-e weather -d 'Living Room' <0x723cc520>
                                        50	04/16/21 11:42:50.147	luup_log:366: VeraAlexa[0.94@366](setVar@127):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",366) old value "" <0x723cc520>
                                        50	04/16/21 11:42:50.148	luup_log:366: VeraAlexa[0.94@366](runCommand@360):Executing command [runCommand]: "-e weather -d 'Living Room'" <0x723cc520>
                                        OK, I go shoot myself now.
                                          154.0k
