  3. Vera
  4. How to throttle or stop plug-in from cluttering LuaPnP Log?
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
7 Posts 3 Posters 1.6k Views 3 Watching
    I use the ROKU plug-in from Vera's app repository. It seems to constantly add Log entries every 5 seconds or so, to the point where my LuaPnP log is just littered with page-long reports about the status of my Roku TV. My Log is 75% "Roku" status!
    The only pertinent setting I see under Advanced > Variables is "PollingEnabled" (default: true) which when set to false does indeed stop the logging altogether. But I fear this also completely stops the plug-in from checking TV status which otherwise would update variables that happen to trigger some of my MSR routines. (More testing needed here...)
    But do you guys know of any way -- up to and including editing the D_, I_ or L_ files of the plug-in itself! -- to simply stop or slow a running plug-in from writing to the Log??
    Also, is there any harm (other than mild annoyance when I have to review the Log for unrelated things) in allowing Vera to write so vigorously to the Log all day long??
    THANKS!
      There is a way... by going into the L_ file of the plugin and commenting out some of the luup.log lines which you don't want to see...
        On a separate note, should I be at all concerned about these lines in my Vera Plus LuaPnP log?
        02	03/31/21 0:56:28.105	ZWaveNode::AddPollingCommand light/switch node 27 doesn't support any COMMAND_CLASS_BASIC <0x75f53520>
        02	03/31/21 0:56:38.100	ZWaveJobHandler::AlarmCallback skipping check because of jobs <0x76553520>
        01	03/31/21 0:59:50.162	LuaInterface::CallFunction_Timer device 336 refreshCache took 10 seconds <0x73353520>
        They repeat quite often, though I can't pinpoint what they denote. I do know that "Node 27" refers to "altID=27" which is my Fibaro RGBW LED controller (this is precisely why I foolishly clicked "Configure Node Now" on it the other day, to my eternal embarrassment!).
        Should I ignore? Do something? The Log is just the Amazon jungle to me. Thanks!
        • LibraSunL LibraSun
          @librasun
          You should really disable polling on the vera...
          LibraSunL 1 Reply Last reply
            @librasun
            @rafale77 said in How to throttle or stop plug-in from cluttering LuaPnP Log?:
            @librasun
            I actually thought I had...? I'll dredge up the old "Polling" thread and follow up. Thanks again!
              Care to comment on this particular line, which (a) occurred during my most recent unplanned Luup Engine restart, and (b) is the only instance of this I've seen:
              01	03/31/21 12:17:43.489	Main WatchDogRoutine: blocked - terminating 1 <0x6b31e520>
              02	03/31/21 12:17:43.491	Dumping 28 locks <0x6b31e520>
              2021-03-31 12:17:43 - LuaUPnP Terminated with Exit Code: 137
              Sounds scary to me, esp. cuz the first line was shown all in RED in Vera's Log.
              (Much) earlier threads about this situation on MCV suggest it's the result of plug-ins fighting each other, in essence. I may have to remove plug-ins one by one to see which one's the worst offender.
              UPDATE:
              I've since deleted these plug-ins from my Vera Plus...
              Reactor, GCal3, AutoVera (none of which were in use)
              ...then power cycled her in case there were memory leaks.
                I have also been seeing a lot of red in my Vera logs notably the dumping XX locks
                  128.0k
                • Logon screen timeout
