  4. Alerts - (vera>device_699) does not have attribute ?attr?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
32 Posts 2 Posters 9.3k Views 2 Watching
    Your other snip shows the variable is there now, at the bottom of the list, therefore it has appeared and has a value, and null is not to be expected. This is exactly why I am taking this approach: the arming capability will make sure that its state attribute always exists with a value of true, false, or null, the first two following the value of SecuritySensor1/Armed when it is present on the device, or getting null if it is not. This is easier to handle in rules/conditions than getting an error thrown; you can treat null and false as equivalent, in all likelihood, which is exactly what a simple is TRUE condition operation would do.
    For the sake of clarity, the update did not make the Armed variable appear on the device. It can't do that. It only affects how it reads the device data that is available. So something created Armed on the Vera side in the interim, perhaps Vera itself.
    @toggledbits said in Alerts - (vera>device_699) does not have attribute ?attr?:
    But I still can't see the "Armed" variable listed in Vera. I have hard refreshed the browser.
      #22
      Well, it would not be listed if it hadn't come back in user_data. If, since the last MSR restart, the Vera reported that variable even once, MSR would have it. If it later is missing, there's actually no way for MSR to know it's missing, it thinks it's just not being updated/no updates for it, so it keeps it at the last value it got. The only way to reset that cached state is to restart MSR.
        #23
        This is confusing.
        This is the SDATA for this device, "armed" is indeed present:
        { "name": "Deck Floodlight", "altid": "133", "id": 699, "category": 3, "subcategory": 0, "room": 5, "parent": 1, "status": "0", "configured": "1", "armedtripped": "0", "lasttrip": "1617376314", "tripped": "0", "armed": "0" },
        However I cannot see that variable in the Vera UI7 web GUI even after reloading the LUUP engine and hard refreshing the browser.
          Change out sdata for status and see what it reports.
            #25
            Status output:
            { "id": 699, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "SensorMlType", "value": "1" }
            { "id": 699, "states": [ { "id": 466, "service": "urn:upnp-org:serviceId:SwitchPower1", "variable": "Status", "value": "0" }
            The name of the device "Deck Floodlight" cannot be found, so I searched for its ID number 699 instead and that's all I could see.
            I don't know what ID 466 is ? There is no device with that ID.
            Its not its altid / node id that is 133
              That does not look like a complete status output. Can you post the URL you used for that query? I assume you're doing that as an HTTP request?
              cw-kidC 2 Replies Last reply
                http://Vera-IP:3480/data_request?id=status
                  I just ran it in Chrome browser.
                    #29
                    Try adding DeviceNum parameter, and please don't edit any of the response when posting:
                    http://vera-ip:3480/data_request?id=status&DeviceNum=699
                    The 466 you were asking about earlier is the state's ID number. It's not relevant to anything, just an internal value for Luup.
                      There's a lot of it:
                      { "Device_Num_699": { "states": [ { "id": 583, "service": "urn:upnp-org:serviceId:SwitchPower1", "variable": "Status", "value": "0" }, { "id": 584, "service": "urn:upnp-org:serviceId:SwitchPower1", "variable": "Target", "value": "0" }, { "id": 585, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "Configured", "value": "1" }, { "id": 586, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "LastUpdate", "value": "1616525032" }, { "id": 587, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "FirstConfigured", "value": "1616524758" }, { "id": 588, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "ChildrenSameRoom", "value": "1" }, { "id": 589, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "PollRatings", "value": "5.00" }, { "id": 590, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "ModeSetting", "value": "1:;2:;3:;4:" }, { "id": 591, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "Capabilities", "value": "211,156,1,4,7,1,L,R,B,RS,|37S,49S:5,85,89S,90S,94,108S,112S,113S:4,114S,115S,122S,133S,134S,152,159," }, { "id": 592, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "NodeInfo", "value": "55,5e,98,9f," }, { "id": 593, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "Neighbors", "value": "1,12,28,31,32,33,40,44,45,47,52,56,58,67,70,72,79,85,87,112," }, { "id": 594, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "LastReset", "value": "1616524754" }, { "id": 595, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "VariablesSet", "value": "1-PIR Trigger Off period,2d,60,2-Lux sensor threshold,2d,30,3-Lux auto report,2d,1" }, { "id": 596, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "SecurityFailed", "value": "0" }, { "id": 597, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "ManufacturerInfo", "value": "96,18,1" }, { "id": 598, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "VersionInfo", "value": "3,4,61,1,1" }, { "id": 599, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "AlarmType", "value": "0x7,0x8," }, { "id": 600, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "AlarmVersion", "value": "0,2" }, { "id": 601, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "SubscribedAlarms", "value": ",0x7,0x8," }, { "id": 602, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "SensorMlType", "value": "3" }, { "id": 603, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "PlusInfo", "value": "1,5,0,12,7,12,7" }, { "id": 604, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "FirmwareInfo", "value": "96,4609,29529" }, { "id": 605, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "AgiInfo", "value": "X" }, { "id": 606, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "ConfiguredAssoc", "value": "" }, { "id": 607, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "ConfiguredVariable", "value": "1-PIR Trigger Off period,2d,60,2-Lux sensor threshold,2d,30,3-Lux auto report,2d,1" }, { "id": 608, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "PollSettings", "value": "60" }, { "id": 609, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "VariablesGet", "value": "1,60,2,30,3,1," }, { "id": 610, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "PollOk", "value": "2" }, { "id": 611, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "AssociationNum", "value": "0" }, { "id": 612, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "LastRouteUpdate", "value": "1616525092" }, { "id": 613, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "LastNnu", "value": "1617238807,7" }, { "id": 614, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "LastArr", "value": "1617238811,7" }, { "id": 615, "service": "urn:micasaverde-com:serviceId:ZWaveNetwork1", "variable": "LastPollSuccess", "value": "1616525034" }, { "id": 616, "service": "urn:micasaverde-com:serviceId:ZWaveNetwork1", "variable": "ConsecutivePollFails", "value": "0" }, { "id": 617, "service": "urn:micasaverde-com:serviceId:SecuritySensor1", "variable": "IgnoreTripTime", "value": "2" }, { "id": 618, "service": "urn:micasaverde-com:serviceId:SecuritySensor1", "variable": "ArmedTripped", "value": "0" }, { "id": 619, "service": "urn:micasaverde-com:serviceId:SecuritySensor1", "variable": "LastTrip", "value": "1617376314" }, { "id": 620, "service": "urn:micasaverde-com:serviceId:SecuritySensor1", "variable": "Tripped", "value": "0" }, { "id": 621, "service": "urn:micasaverde-com:serviceId:SecuritySensor1", "variable": "Armed", "value": "0" } ], "Jobs": [ ], "PendingJobs": 0, "tooltip": { "display": 0 }, "status": -1 }, "Using_2G": 0, "LoadTime": 1617383774, "DataVersion": 383787633, "UserData_DataVersion": 383774040, "TimeStamp": 1617390782, "lights_on": 13, "lights_off": 43, "doors_locked": 0, "doors_unlocked": 0, "sensors_tripped": 0, "sensors_not_tripped": 24, "failed_devices": 0, "visible_devices": 149, "partitions_active": 0, "partitions_notactive": 0, "alerts": [ { "PK_Device": 331, "Room": 1, "DeviceName": "Lounge Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "35995388862", "LocalDate": "2021-03-31 06:24:21", "EventType": 16, "SourceType": 5, "Argument": 1, "Filesize": 0, "Severity": 5, "LocalTimestamp": 1617168261, "Code": "offline", "NewValue": "1", "Description": "Device NOT responding", "Users": "", "Server_Storage": "", "Key": "", "Icon": "error.png", "PK_Store": "0" }, { "PK_Device": 331, "Room": 1, "DeviceName": "Lounge Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "35995486322", "LocalDate": "2021-03-31 07:30:55", "EventType": 16, "SourceType": 5, "Argument": 0, "Filesize": 0, "Severity": 5, "LocalTimestamp": 1617172255, "Code": "offline", "NewValue": "0", "Description": "Device responding again", "Users": "", "Server_Storage": "", "Key": "", "Icon": "error.png", "PK_Store": "0" }, { "PK_Device": 331, "Room": 1, "DeviceName": "Lounge Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36007081772", "LocalDate": "2021-03-31 23:15:25", "EventType": 3, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 1, "LocalTimestamp": 1617228925, "Code": "DL_ARMEDTRIPPED", "NewValue": "1", "Description": "Lounge Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "", "PK_Store": "0" }, { "PK_Device": 331, "Room": 1, "DeviceName": "Lounge Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36007090092", "LocalDate": "2021-03-31 23:15:58", "EventType": 4, "SourceType": 4, "Argument": 0, "Filesize": 0, "Severity": 1, "LocalTimestamp": 1617228958, "Code": "DL_ARMEDTRIPPED", "NewValue": "0", "Description": "Lounge Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "", "PK_Store": "0" }, { "PK_Device": 290, "Room": 5, "DeviceName": "Deck Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034063812", "LocalDate": "2021-04-02 12:54:57", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617364497, "Code": "", "NewValue": "1", "Description": "Deck Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" }, { "PK_Device": 290, "Room": 5, "DeviceName": "Deck Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034387302", "LocalDate": "2021-04-02 13:23:04", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617366184, "Code": "", "NewValue": "1", "Description": "Deck Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" }, { "PK_Device": 694, "Room": 3, "DeviceName": "Porch Motion Sensor", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034718782", "LocalDate": "2021-04-02 13:53:19", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617367999, "Code": "", "NewValue": "1", "Description": "Porch Motion Sensor", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" }, { "PK_Device": 290, "Room": 5, "DeviceName": "Deck Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034775722", "LocalDate": "2021-04-02 13:58:47", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617368327, "Code": "", "NewValue": "1", "Description": "Deck Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" }, { "PK_Device": 290, "Room": 5, "DeviceName": "Deck Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034882632", "LocalDate": "2021-04-02 14:08:12", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617368892, "Code": "", "NewValue": "1", "Description": "Deck Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" }, { "PK_Device": 290, "Room": 5, "DeviceName": "Deck Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034926972", "LocalDate": "2021-04-02 14:12:02", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617369122, "Code": "", "NewValue": "1", "Description": "Deck Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" } ], "ZWaveStatus": 1, "Mode": 1, "LocalTime": "2021-04-02 20:13:02 N" }
                        #31
                        "Lounge Motion" not sure why that is referenced in there? That is a motion sensor in the lounge room.
                        "Deck Motion" is the virtual motion sensor I created to work with this Everspring Flood light parent device #699
                        Can see "Porch Motion Sensor" mentioned as well, that is an outdoor Everspring motion sensor not related.
                          #32
                          You only care about what's in the "Device_Num_699" section of the file. You can "pretty up" the format in jsonlint.com, and if you look at that section, you'll find Armed is in there, state ID 621 at the very end of the states array.
                          			"id": 621,
                          			"value": "0"
                          The other devices are in the alerts section of the response, which isn't relevant to our work here.
                            163.2k
