  3. Vera
  4. Backup
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
Backup
3 Posts 2 Posters 1.3k Views 2 Watching
    Hello Everyone -
    Can someone point me in the proper direction of doing a Vera (Secure) backup?
    Specifically, I'm worried about a controller failure and unable to source a new one where I could just use the included backup facilities.
    I'm considering staying on Vera a little longer to see what happens with Ezlo (especially around easy migrations).
    I know I can manually run backups from the UI but wondering if there's a more "standard" method that would allow me to move to another platform if required. This would require me to pull my (important definition, I feel. This shouldn't be a secret) encryption key off of the Vera as part of the backup - so any pointers there would be helpful as well.
    • T tbully
      Hello Everyone -
      @tbully
      This sound like such a simple thing yet it is quite a convoluted process.
      For Zigbee, it is nearly impossible because it requires spoofing the zigbee MAC address of the original zigbee radio.
      I suppose you are really looking for the z-wave part of it.
      I would suggest you read my migration method from vera to z-way which contains the method to migrate first the vera zwave chip data to another zwave chip (through any usb zwave stick). You can then run the vera on the stick itself for as long as you want and when you want to migrate, you will be able to do so by just moving the stick to a new controller.
      The process is described here.
      The access to the security key is then described here
      These are all contained in the vera backup of course and could be extracted manually if you know how to decompress the backup file.
        @tbully
        wrote on last edited by tbully
        @rafale77 - I'm so sorry for my delayed response. I didn't get the alert in my inbox (or blew past it).
        I will look in to this. I have previously read your migration instructions but, the last I checked, the security key part was omitted. I'm still willing to wait out Vera/Ezlo but I'm nervous that I can't get a replacement controller. If this thing dies, I need another move.
        I'll revert back with questions but I remember the guide being very well thought out. Glad to see this community coming together over here.
        Thanks gain.
          164.3k
