  4. Release 1.0.0
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
Release 1.0.0
9 Posts 6 Posters 2.8k Views 6 Watching
    Well, it's July 19th, and as previously advertised, Reactor (Multi-System, aka MSR) has been published at release 1.0.0.
    Docker images are on DockerHub, and download package for bare-metal installs is available at https://reactor.toggledbits.com/download/
    Those of you with access to the Mantis Bug Tracker for the project, please continue to use it, particularly if you stick with the "latest" docker image tag (which will continue to be updated periodically, as will the bare-metal tarball). Feel free to open issues there on behalf of other users who do not have accounts if it seems appropriate.
      Haven't been able to do much helping on this for a while, but after installing the release docker, and moving the rest my automation to MSR i feel the need to say:
      GOOD JOB!
      Especially to Patrick, but also to all contributors.
      Automation is now very fast and intuitive to set up, and I still havent found anything i can't do with this. No bugs as far as i've seen yet either!
        Thanks, @PerH , and indeed, a lot of effort by many went to get it this far. And miles to go before (we) sleep...
        G B 2 Replies Last reply
          @toggledbits +1 for the Robert Frost reference.
            B Offline
            B Offline
            Buxton
            @toggledbits I was able to install the container through compose, however, I had to make some changes to get it working. See below for my compose file:
             MSR:
              container_name: reactor
              image: toggledbits/reactor:latest-generic-amd64
              restart: "on-failure"
              environment:
               TZ: America/Los_Angeles
              expose:
               - 8111
              ports:
               - 8111:8111
              volumes:
               - /home/username/reactor:/var/reactor
              tmpfs: /tmp
            #  logging:
            #   driver: "json-file"
            #   options:
            #    max-file: 5
            #    max-size: 2m
            The changes I made are:
            1.) substitute "MSR" for "web" for the service name. This was just a precaution against a generic service name interfering with container management programs I use, and was not a needed/critical change to get things working.
            2.) simplify the volume syntax for binding a data volume. The syntax you have on your website caused a yaml compile error with version: '3.7' compose.
            3.) comment out the logging options. These options compiled, but threw a runtime JSON error that stopped the container from coming up:
            ERROR: for MSR  Cannot create container for service MSR: json: cannot unmarshal number into Go struct field LogConfig.HostConfig.LogConfig.Config of type string
            ERROR: Encountered errors while bringing up the project.
            I hope to cut out some time next week to start forming some logic. The web UI looks great.
            B 1 Reply Last reply
              There will be some syntax differences for different versions of compose, but I would suggest that you reinstate the logging options in order to control/restrict the storage space the container uses for logs. 🙂
                Just installed 1.0.0 (21200), which seems to run fine on Debian chroot. Didn't find "reactor.service-example" file that was supposed to be included in the installation package?
                EDIT: found an example from documentation, but it turned out that you cannot run systemctl under chroot 😞
                @toggledbits or anyone, any advice on running sysinit style startup script?
                • N Offline
                  N Offline
                  Hi everybody!
                  I was following this web site as non-member. Finally I have a new Synology Nas to try the new @toggledbits 's reactor project and this post is first of all to thank @toggledbits for his effort and passion to share his projects and to make them accessible even for those who are not a programmer. I know many of you reading the posts from the vera community and would like to express my gratitude for the advice you give to understand things. So a big Thanks and congratulations to Patrick for this new project !!!
                  I just installed MSR and I am excited to try it out!
                  -Docker on Synology NAS
                  -HASS Docker 2026.8.1
                  -ZWaveJS-UI 11.22.3
                  -Update 16/08/2026
                  • B Buxton
                     MSR:
                      environment:
                      expose:
                       - 8111
                      ports:
                       - 8111:8111
                      volumes:
                      tmpfs: /tmp
                    #  logging:
                    #   options:
                    #    max-file: 5
                    #    max-size: 2m
                    B Offline
                    B Offline
                    Buxton
                    @buxton Just a follow-up to the docker compose file I listed above. The error I received for the logging option occurred because I used an integer for the "max-file" field. The proper notation should be:
                      logging:
                        driver: "json-file"
                        options:
                          max-file: "5"
                          max-size: 2m
                    Also note that for the logging section only, there are two spaces for the indents instead of one . YAML is unforgiving with formatting, so this too was corrected in my YAML file
                      164.2k
