  4. Unable to pull attributes into Global Expression (Hubitat)
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
14 Posts 2 Posters 2.5k Views 2 Watching
  • 3 Offline
    3 Offline
    I have begun my migration off of Vera and over to Hubitat. One device and one app at a time. I am working on my Netamo app/devices right now. The Netatmo Client App in Hubitat pulls all the information in and I can use the values within rules. However I am unable to use these value within an expression. Or at least a Global Expression. Honestly haven't tried a local one yet. In my screenshot below, the Global Expression as a value from the Vera Netatmo plugin, but when I try to change this to the Hubitat entity, there are no attributes to pull in. Below that is what I am able to see within the Rule itself.
    • toggledbitsT Online
      toggledbitsT Online
      What is shown in the Entities detail display for hubitat>39?
      Regardless, that doesn't stop you from using them. That's just a tool to help make it easier to write the expression. You can still write it out:
      getEntity( 'hubitat>39' ).attributes.humidity_sensor.value
      3 1 Reply Last reply
        3 Offline
        3 Offline
        @toggledbits said in Unable to pull attributes into Global Expression (Hubitat):
        Ah. Good to know. I can write that out, or attempt to. Here is what is shown under the entity.
          toggledbitsT Online
          Strange. Have you done a hard refresh on the browser?
            3 Offline
            3 Offline
            Yes. And to add more to the confusion, in my Triggers, if the ==/<> option is changes, the Condition must be sustained for section is completely missing.
            • 3 Offline
              3 Offline
              Actually. I think the changes is a bug. I tried to set my old Netatmo entity back in and even with that there is no Condition must be sustained option. Regardless of the entity, when the ==/<> (I forget what this is called) is set to changes, that field/option is missing. My original rule for this was imported from RfV.
              EDIT: I have a work around. And steps to follow to see if you can reproduce it.
              Set the operator to something other than changes and open the Conditions options
              Change your operator to changes (BTW, the menu option is very small with the Conditions options open.)
              Set your Condition must be sustained for xxxx value.
              Close your Conditions options.
              Cond.jpg The work around works. This trigger must be sustained for 3 hours before being true.
              Was running 21236-90dd714. Upgraded to 21237-e161aed and still seeing both issues. In fact my operators in general for any new rule are only showing me the above list now. Existing rules I get the full drop down list. I don't know what happened.
                toggledbitsT Online
                No, logically "changes" and "sustained for" cannot go together. "Changes" is an instantaneous at the moment the change occurs. It is therefore not capable of being "sustained" for any period of time. Also don't assume that just because Reactor for Vera allowed you to do something that (a) it was right, and (b) MSR will work the same. There are a lot of things in MSR that are fixed behaviors of things that should never have been in R4V.
                Also, unless I'm certain what is causing a problem and can put in a fix, not every build is going to have a fix for every issue that may be being discussed. Your first issue doesn't happen for me, and I've never seen it, so in the absence of being able to reproduce it myself, I can't fix it, and that won't change until I can see it. The second issue is, I think, a misunderstanding, and also too new to make the build window even if it was a something to address/fix.
                • 3 Offline
                  3 Offline
                  Oh I totally get it. Sorry if I came across as I was expecting it to be fixed in the newer build. That wasn't my intent. I just wanted to test a newer build JIC.
                  It makes sense that changes are immediate. What I'm doing is watching the internal temp reading from my Netatmo and if it hasn't changed in in 3 hours, then reboot the netatmo device. I suppose I could do this with a pulse and a expression. Setting the variable then compare the new reading to the previous reading every 3 hours. If they are == then reboot.
                  I'm happy to troubleshoot the Hubitat Expression issue with you. Is there anything I can run for you?
                  3 toggledbitsT 2 Replies Last reply
                  • 3 3rdStng
                    3 Offline
                    3 Offline
                    Something is definitely up with my Reactor. Any new rules that I create I only have a very short list of operator choices. I blew away my docker image and pulled a new one. I also tried going back to the generic 1.0.0. I tried via Incognito Mode and in a different browser in case it was a cookie issue. All had the same results, and it doesn't matter which hub I pull from.
                    What logs can/should I pull for you? Thinking back to the only changes I made yesterday. I installed the Netatmo Client app and drivers in my HE hub and presented them via the Maker API. I was changing my temperature related rules from the Vera device to the HE device. Outside of that, there weren't any real changes that I recall to Reactor. Oh. I upgraded from 21228 to 21236 earlier in the day. Then was presented with a 21236 again about an hour later. And then to 21237 late last night. But I don't think these are related.
                    • 3 3rdStng
                      toggledbitsT Online
                      toggledbitsT Online
                      @3rdstng Here's an approach:
                      Using the "delay reset" for 180 minutes (10,800 seconds) will hold the changes condition true for three hours. The group is set to NOT to invert the sense of the output.
                      When the temperature changes, and for three hours after, the condition will be true, so the rule will be false. If there are no changes for three consecutive hours, the condition goes false, so the rule will go true (set).
                      • 3 Offline
                        3 Offline
                        Thank you @toggledbits - There is something else going on too. I thought it was machine related, so I deleted my post. But after hard refreshing the browsers on my other machine, and testing on a 3rd machine, I'm still seeing the issue. I've restored my post, which is now a couple up from here. The operators list does not contain ==, <>, >=, etc. for brand new triggers. If I edit a trigger that is already there, I get all those operator choices. I cleared and reset all my settings in Chrome and still see it. Short of completely blowing away Reactor and creating a second/new instance, I'm not sure where to go. I have a feeling that if I went with the new Reactor docker, and I copy my config/rule files over, that the issue will come with it.
                        EDIT: Did the operators options code get an update? I was poking around and noticed that depending on what the triggers capability setting is set to, the operators are restricted to what is shown. I don't recall ever having this restriction/limitation before. For example I used to manually define the power_switch.state to T/F. Manually typing in the value to check again. But now my options are is TRUE, is FALSE, etc. Maybe my mind is just warped and I was used to seeing the full drop down list prior to now?
                          toggledbitsT Online
                          If you choose an attribute for which the data type is known, operators that do not apply to that datatype are removed. For example, if you choose a boolean attribute (like motion sensor state), the ==, <>, etc are removed, because you use is TRUE, is FALSE and is NULL to test that value type.
                          This is a change from the behavior of R4V, where all data was strings so you had to test for "0" or "1" on a boolean. MSR doesn't work that way.
                          Edit: to your other question, this was not a recent change. It happened around March 8.
                            3 Offline
                            3 Offline
                            THANK YOU! Everything had been imported from R4V, so my mind was still in the state of seeing everything. I thought I was having issues. Since I'm migrating off Vera and onto HE, I'm starting to see the changes between R4V and MSR. Glad I'm not having PC/browser/docker issues.
                            Getting back on topic. What can I provide you to get the Expressions drop down populated? If I choose a different entity, those options are presented. If I then switch back to the HE Netatmo entity, I still see the options from the other device. It appears to only be these Netatmo entities. Not sure if this will help, but here is where/how I installed the client and drivers.
                            Jan 22, 2020
                            [RELEASE] HubConnect Netatmo Weather Station Client (HubConnect not req'd)
                            I am pleased to announce the release of a brand new, Netatmo integration to Hubitat. This is NOT a ported app.. It is a brand-new integration, written nearly from the ground up. It features driver support for the Base Station, Outdoor Module, Wind Gauge, Rain Gauge, and Indoor Modules. Despite...
                            • 3 3rdStng
                              Jan 22, 2020
                              3 Offline
                              3 Offline
                              The manual entry into the Expressions does work. The top expression is from my Vera entities. The bottom is from the HE entities.
                                165.4k
