  4. How To: Send TCP packet in Reaction
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
2 Posts 2 Posters 740 Views 4 Watching
    Someone had posted earlier a question about how to send TCP packets from Reactor, and then deleted the post, but I thought the question was interesting. It's not something Reactor can do directly at this time (that is, there's no action specifically for this purpose), but I had a hunch how it would be doable through the shell, and it took me a bit before I could get to my desk/lab to try it out.
    Pretty straightforward on Linux-based systems, at least:
    This uses a Shell Command action to drive nc to send the packet. The echo command is used to pipe the string to be transmitted to nc, which makes the connection and delivers the data, waits one second, then disconnects.
    This test case has some particulars for communication with Yeelight bulbs. You may need to adjust the command line arguments to suit the intended target if it's something else. Specifically:
    • The echo command here is used without -n so that a LF is sent after the string; if no line ending is needed for your target, use echo -n.
    • The -C option is used on nc to translate echo's LF to CRLF, which Yeelight requires. Drop this option if your target has no such requirement.
      Alan_F
      I was able to do it pretty simply in Node-Red, so I set it up there and deleted the question. I put an http listener on the NR flow and call that URL from MSR when I want to trigger the TCP connection. I'll give this solution a try, as having it all in one place seems like a good idea.
      EDIT:
      So I tried and am getting this. I'm working on it, but you'll probably post a solution before I can figure it out. I'm running MSR in Docker on a RPi4.
      Rule<SET>" (rule-kvmgurr3:S) step 3 Shell action failed command "echo '?\"id\?' | nc -C -q 1 192.168.0.25 55443" (1)
      nc: unrecognized option: C
      BusyBox v1.31.1 () multi-call binary.
      Usage: nc [OPTIONS] HOST PORT  - connect
      nc [OPTIONS] -l -p PORT [HOST] [PORT]  - listen
      	-e PROG	Run PROG after connect (must be last)
      	-l	Listen mode, for inbound connects
      	-lk	With -e, provides persistent server
      	-p PORT	Local port
      	-s ADDR	Local address
      	-w SEC	Timeout for connects and final net reads
      	-i SEC	Delay interval for lines sent
      	-n	Don't do DNS resolution
      	-u	UDP mode
      	-v	Verbose
      	-o FILE	Hex dump traffic
      	-z	Zero-I/O mode (scanning)
      Edit 2:
      I used my usual brute force method of Googling various terms and mashing the keyboard (aka trial and error by a Linux novice) and finally made this work on my RPi4 Docker install of MSR.
      The '-C' didn't work, but I was able to add $'\r\n' to the end of the echo command which I believe achieved the same effect.
      The '-q 1' didn't work, but I was able to use '-w 1' which again I believe has the same effect.
      So I end up with a shell command of:
      echo '{"id":1,"method":"set_power","params":["on", "smooth", 250]}'$'\r\n' | nc -w 1 192.168.0.25 55443
      P.S. - I read the 'category topic guide' between my first reply and this edit and realize that I'm probably violating at least one of those rules. I got a good laugh from this part of that post: " I wrote Reactor as a tool for you to use to solve your automation/logic problems, not as a tool for me to use to solve your automation/logic problems." Hopefully I'm living up to that part a little bit by figuring this out for myself (with a initial help from Patrick).
        163.6k
