  3. http relay activate with username and password authentication
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
  • D Offline
    D Offline
    destination
    wrote on last edited by destination
    Hi to all,
    I am user of vera controller. I have a dahua door intercom with relay. Relay activates with username and password authentication. I can activate the relay http://admin:a1234567@192.168.1.111/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote
    As you can see intercom username admin and password is a1234567 I build a scene with luup code luup.inet.wget( "http://admin:a1234567@192.168.1.111/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote" ) But can not activate relay. Is there any idea?
      Try using:
      luup.inet.wget( "http://192.168.1.111/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote", 15, "admin", "a1234567" )
      ...and see if that works (username and password as third and fourth arguments). If not, your door intercom probably requires Digest Authentication, which the browser will happily use if asked, but which the old libraries on Vera probably don't do. In that case, you'll want to use curl via os.execute() like this:
      os.execute( "curl -o - --user admin:a1234567 'http://192.168.1.111/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote'")
      Notice that the URL is enclosed in single-quotes, which is necessary; the entire command is enclosed in double quotes. The closing single quote at the end of the URL is next to the closing double quote for the string sent to os.execute() so it is hard to see, but it's there.
      D 1 Reply Last reply
        Try using:
        D Offline
        D Offline
        destination
        @toggledbits said in http relay activate with username and password authentication:
        Thanks for reply but both are not working.
        • D destination
          @destination what if you just try that curl command from the command line (without os.execute)? Just to narrow down what is working and what's not.
            D Offline
            D Offline
            destination
            @tunnus said in http relay activate with username and password authentication:
            No luck
              145.6k
