  2. Blogs
  3. My migration from Vera, or what I did on my holidays
Seeking Advice:
Blogs
L
Blogs
Finally gave up on my Ezlo Plus
Blogs
Another transition from Vera to OpenLuup And now to HASS - PerH
PerHP
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
105 Posts 6 Posters 81.0k Views 7 Watching
    @rafale77 said in My migration from Vera, or what I did on my holidays:
    I have a few of these... If you look at how the vera treats them... they are actually switches with a different icon. You can change the device json file to make them look like a siren.
    Yes. Thinking about this right now
    @rafale77 or I could just change the json and XML files?
      yes, I just checked. You can change both. The siren and the light are basically interchangeable. The services they call are the same.
        Given there is a category, a json and an xml for siren, it seems sensible 🙂
          I will embark soon on the same path. I’m just waiting for my home vacation in August. I will leave my Vera on since I still have Nest, I like them and there’s no way to port them. It will just be a Nest gateway, but I’m done with Zwave on it. The last months have been impossible, thanks to more activity outside, as it’s usually for me during Christmas time and Summer.
            @therealdb said in My migration from Vera, or what I did on my holidays:
            HA Bridge.....
              Nest closed its APIs, so you cannot request a new key, but previous integrations works. I may have a key or two laying around. We’ll see.
              CatmanV2C rafale77R 2 Replies Last reply
                Ahhh I see!
                  Yeah and this was the trigger which motivated me to get rid of my nest protects and ban google devices and replace all the other unnecessarily cloud dependent ecosystems.
                    Yep, but they’re way more stylish than other options and style is very important to me. Wife demands style too, so I can’t really change them right now.
                      You could just hide them! 😉
                        165.2k
