  2. Hardware
  3. Vera
  4. Vera account suspended for a 1000 years
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
101 Posts 22 Posters 65.0k Views 20 Watching
    Stange, That post is still up. If that was the cause i would have thought it would have been removed to. If they keep up this tyrannical behaviour the forum will die a death of a thousand cuts.
      mrFarmer
      wrote on last edited by mrFarmer
      Maybe he still hasn't recovered from Raf's comments and bans all that post here one at the time 🙂
      O and you said you moved to the 'competition'. Apparently he feels openLuup based DIY is.
        sender
        I have moved to homeassistant and OZW. Works very well! And recently I started with esphome via homeassistant. Configure and compile firmware, upload it to an esp and manage it further from homeassistant (OTA!).
        This way I have now created a hall flow meter for 9 euro :-). And a 8v port relay board for 13 euro. Rocksolid... downside is my wifi has to be always on... but that counts for a lot of things...
        Since I have been banned I did not even look back :-).
        And to be honest I am so happy with this Vera situation else I would not ever have discovered what's out there!
        • M mrFarmer
          @mrFarmer said in Vera account suspended for a 1000 years:
          I am finding it pretty funny actually as I don't think at this point and the direction they are taking is making them a competitor for no one. They are so far behind "DIY" or open-source solutions even on their roadmap that I think they are in a market on their own: Find complicated solutions running on obsolete hardware to solve problems nobody but vera owners had while creating new problems of their own and claiming great achievements for functionalities The community had developed and implemented for half a decade. My system is so far beyond what they plan to offer even years (1000?) from now... I am puzzled.
          All the banned people were trying to bring to the forum was a reality check and offering competitive information they seem to be so oblivious to. So they can ban away... all their customers.
          In the meantime, I am learning about AI, deep learning, machine learning, convoluted neural network and their local implementations for home automation while they are still congratulating themselves on the achievement turning a light bulb on "very fast" with alexa going through their unreliable cloud and junk ware controllers. Hyping up about an obviously ignorant review of a product which doesn't really work.
          So yeah... sorry, competitor? How arrogant and pretentious are they to call anyone a competitor? 🤣
            sender
            And that watervalve... that will be a top notch product 💦
            • Black CatB Offline
              Black CatB Offline
              Black Cat
              There is nothing on that forum that is of interest now. Before it was a joy to open it and read what others had achieved, look at it now, just full of beta comments of possible new FW.
              Commercially, I've opted for Homeseer and have never looked back especially as HS4 now supports node-red natively, but always read this forum first as it has many old friends on board advancing Home Management Automation. Keep up the good work guy's and don;t look back.
              aka Zedrally
                sender
                I have moved it from my favourites and it feels... releaving 😕
                  Well welcome to the club, I think that makes at least three of us now 😄
                  • Black CatB Black Cat
                    @Black-Cat said in Vera account suspended for a 1000 years:
                    yeah, so sad to have lost a lot of smart people. plus, many other lost interest, so traffic is down and interest is low. that's normal when you think it's 1 year since a new firmware and the new one is not even an alpha.
                    S 1 Reply Last reply
                      sender
                      @therealdb they do have an "alpha" however! It's Melih sitting on a rock, beating the drum and banging on his chest like a real alpha monkey while banning people.
                        Black CatB Offline
                        Black Cat
                        I'll be joining you all soon, just posted about Homeseer 4 and multiple Zed-Nets( ser2net), something Vera can't handle.
                        aka Zedrally
                          @Black-Cat
                          Ah, interesting... I had PM’d the OP of that thread saying that the place to get good advice on topics like that was here!
                          (So if they read that, I’ll be joining too.)
                          CatmanV2C CrilleC 2 Replies Last reply
                            @Black-Cat
                            @akbooer Don't let Melih catch you 😉
                              Yeah really don't miss the old forum thanks to @DesT! 🙂
                              Live and let ... be.
                              Happy as clam with my zwave and zigbee setup honestly... and to not have had to exclude/re-include anything to get there was a major part of it, given the size of my network.
                              DesTD CatmanV2C 2 Replies Last reply
                                DesTD Offline
                                DesTD Offline
                                DesT
                                wrote on last edited by DesT
                                @rafale77 If you need anything else, let us know!
                                And that's the same thing for everyone 😉
                                  Trexx
                                  @DesT - A dark mode theme would be nice, and support for DiscourseHub 🙂
                                  Black CatB 1 Reply Last reply
                                  • T Trexx
                                    Black CatB Offline
                                    Black CatB Offline
                                    Black Cat
                                    @Trexx
                                    aka Zedrally
                                      Trexx
                                      wrote on last edited by Trexx
                                      Well that was quick/painless :). Thanks BlackCat!
                                      @DesT - One other thing that would be handy is for code blocks to have a 'click - copy to clipboard' function. Unless I just missed that somehow as well 🙂
                                      DesTD 1 Reply Last reply
                                        @rafale77 I've had one device stop working. Re-interviewing it fixed it immediately.
                                        Not got round to working out what happened but meh....
                                        • T Trexx
                                          DesTD Offline
                                          DesTD Offline
                                          DesT
                                          @Trexx said in Vera account suspended for a 1000 years:
                                          I would need to check that. Pretty sure for the moment there's no option for that!
                                            220
                                            150.6k
