  3. Plugins
  4. create another countdown timer in openluup
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
AltUI sort?
Am I losing it or did there used to be a sort either alphabetically or numerically option on devices in AltUI? Seems to not be there there? TIA C
Plugins
4 Posts 3 Posters 922 Views 3 Watching
  • E Offline
    E Offline
    Edwin1972
    On my VeraPlus I use the Countdown timer plugin. If I click on details via my apps, I can create multiple timers. Now I want to switch to openluup and have installed the Countdown timer plugin via appstore. Only 1 timer is visible. Is it possible to create more timers
      I ‘m not familiar with the plugin, but think that you just need to create another device with the same device files.
      This is especially easy from openLuup’s console Devices Table page, where there is a create button. Clicking on this pulls up a form which has smart auto-fill capabilities. Just start typing the name of the device/implementation file and you get a short list of choices...
      You can also do this from the Create button on AltUI’s Devices page, but it doesn’t have the auto=fill feature.
        @akbooer is correct. I have 5 instances of these on openluup. You just need to create a new device using the plugin files just like you would for any other plugin.
        • E Offline
          E Offline
          Edwin1972
          Thanks! It works.....
          • Mode Status NULL
            112.9k
