  3. Plugins
  4. Generic support for vacuums
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
43 Posts 10 Posters 24.3k Views 10 Watching
    My first Roomba, still in service (700 series) is approaching its 13 year in duty. It's becoming sluggish and slow, but it's still operating. The second one was sent to the basement, and we have a new Deebot that we love, since it's also mopping. We have hard floors (white on first floor, dark gray on the 2nd) so my wife wants them to do the daily tasks because otherwise dust will be visibile and she hates it.
    Belevie me or not, she is the main driver to get robot vacuums, because they're really helping with the daily maintenance. The one one could mop as well and on white floor she said that it's good, because it's helping to maintian the floor cleaned.
    We have no dogs/cats (we're both allergic), kids are not really kids anymore, but we live at the borders of the city and dust is a problem.
      In 2017, bought a "Xiaomi Mi Robot Vacuum Cleaner Laser Distance Sensor NIDEC Brushless Motor, MPN: SDJQR01RR". Need to lift the smaller obstacles off the floor so it gets a good go at the floor and it can get stuck under some furniture. We have a mix of hard floor and carpet and it gets cleaned really well. Based on its work, it paid for itself very quickly. It maps the house with LIDAR and sends the map of my house back to China - no doubt there is some good data mining to be had in thousands of house plans!!! It vacuums in lines, up & down, rather than just bumping around randomly, like some of the older vacs do. Takes a while but that's only because it does a good job.
      • parkercP Offline
        parkercP Offline
        parkerc
        Thanks - this is good timing as I’m at the point where I need to replace both the vacuum cleaner and also our lawn mower , and the robot option look very attractive in both areas
        • parkercP parkerc
          @parkerc Probably want to make sure you don't get them confused....
            Just started looking into the background stuff for the domoticz plugin.. It uses a separate Miio-server instance to talk to the vacuum, and i suppose that could be upgraded to push directly to MQTT? it uses the python miio library..
            I have no idea of how to go about that, and with what layer.. guess i could ask the miio server developer..
            • PerHP PerH
              @perh I’m writing an mqtt client for my deebot. I’m working slowly but it’s coming nicely. I’ll publish the device file with a virtual http device next week.
                @therealdb said in Generic support for vacuums:
                Might have to buy a Deebot then 🐶
                  @catmanv2 it’s based on nodejs, but since you’re on openluup, you’d run nicely along it. Logic is still rough, but I’m pushing maps via telegram as well when cleaning is completed 😎
                    ronluna
                    @therealdb could use homebridge 2 openluup also...
                    • R ronluna
                      @ronluna I've taken a look and it's using the same base library. I'll push some changes I did in the next days, since the library is good but not well organized. I've already added a couple of features. But I digress.
                      I've finally completed the part pushing via MQTT. I could get nice maps pushed to me and my wife via Telegram with the map, when it started (un'ora fa - one hour ago), how many square meters (69) and the duration.
                      Next week I'll build the device file for Vera/openLuup. I've started pushing the variables, so it's just a matter of stabilizing them, make them generic and build the UI.
                        Love it. Will this work with any Deebot?
                          @catmanv2 yes. keep in mind it's not lua-based, but a nodejs app pushing data into mqtt. since mqtt it's supported under openLuup these days, it's not that difficult, but it's not plug-and-play. home assistant should have similar features, but it's written in python and I'm not that proficient - plus I'm not really runnning HA in production, since I prefer to thinker with APIs and similar these days.
                            I understand about half of that 😄
                              @catmanv2 If you go the HomeAssistant or homebridge route, it's pratically plug&play 😄
                              I'm just playing with stuff, because I'm working too much, life is still slow, and I need to fill some voids. It should be easier to integrate than via my route 🙂
                              But a generic device file should benefit everyone, regardless of the routes you'll follow to map your vacuum.
                              Next I'll get a robo mower, because I'm tired of cutting the grass, and I'll probably write another device file with associated services, so anyone could map their and see status, alerts, etc.
                                I suggest that you buy a xiaomi mi vacuum as well! 😉
                                (good job!)
                                  #28
                                  So, I've just started to collect variables. In honor of this place, I'm starting to use this new service ID: urn:smarthome-community:serverId:Vacuum
                                  I've consolidated this variables, but I'm waiting for feedback (@akbooer , @rafale77, @toggledbits):
                                  • CleanState: the clean state (idle, auto, alert, etc)
                                  • LastClean: the last clean date
                                  • LastCleanImageUrl: a map of the last clean, if available
                                  • LastCleanSquareMeters: (should we just use a generic unit of measure?)
                                  • LastCleanDuration: the duration
                                  • LastCleanDurationFormatted (last clean formatted)
                                  • LastError/LastErrorCode
                                  • ChargeStatus (0/1)
                                  • SleepStatus (0/1)
                                  • CleanSpeed (number)
                                  • Description: something more verbose, like "docked and charging", or "auto", "clean started at", etc.
                                  Is there anything I'm missing?
                                    I think all the "Last****" variables are very good but I tend to be a minimalist for the rest. I would actually suggest to remove the sleepStatus, the ChargeStatus binary sensors and add the BatteryLevel instead. Does the CleanState include Cleaning/Paused/Stopped?
                                      I think we could define the values for CleanState. Right now, I'm using:
                                      • auto
                                      • pause
                                      • idle
                                      • returning
                                      • alert
                                      • spot_area
                                      BatteryStatus is taken from the standard service, as well as status (on/off) and I actions are possible via Switch service as well (SetTarget 1/0).
                                      This post is more a request for feedback, we could add/remove variables if necessary.
                                        I'd like to make intelligent comments, but I've yet to go into any details of robot vacuums. You seems to have covered that basics above.
                                          Bin full/empty, filter OK/need change, very common across HA platforms I'm seeing...
                                            343
                                            151.2k
