  2. Hardware
  3. Vera
  4. The death of a thousand cuts
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
35 Posts 5 Posters 13.3k Views 5 Watching
    #24
    OK. I just created a new device. The system reloads at the request of the new camera implementation. The AltUI Actions page looks like this:
      #25
      No, my mistake, that's not the action you should use (that's supposed to change the camera password, I suppose, but it's not implemented here.) It's been a while.
      The device files don't specify a default value for URL or DirectStreamingURL, so those don't exist. You can simply create them manually, either from Luup Test code or the +Create button on the camera's device variable page in openLuup.
      luup.variable_set ("urn:micasaverde-com:serviceId:Camera1", "URL", "whatever goes here", dev_no)
      luup.variable_set ("urn:micasaverde-com:serviceId:Camera1", "DirectStreamingURL", "whatever goes here", dev_no)
      The contents are obviously camera-dependent. Username/password can, IIRC, be put either in the device's attribute fields (which aren't created by default, either) or, as I do, directly in the URLs:
      • URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USR&pwd=PWD
      • DirectStreamingURL: /cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USRr&pwd=PWD
      Sorry, this is more manual than desirable.
      I'll change the implementation file to create blank attributes and variables for the camera.
      __
      Edit: the latest development version of openLuup v20.5.6 does create these attributes and variables!
        #26
        I have an equivalent for Amcrest/Dahua cameras setup with a different plugin with PTZ control if it is of interest. I will post it in the plugin section.
        GitHub - rafale77/Amcrest-Dahua-Openluup: Plugin for Amcrest/Dahua Cameras on openLuup
        Plugin for Amcrest/Dahua Cameras on openLuup. Contribute to rafale77/Amcrest-Dahua-Openluup development by creating an account on GitHub.
        See how it looks on my setup. I automate changing the camera preset from one position to another depending on time of the day using this plugin.
          Just a follow up on the CPU impact of this type of camera implementation. Here's the last 12 hours of CPU/memory usage on my RPi. I installed the camera device at around 10:45, about halfway through the graph.
          You can see there's barely any difference, and, that which there is, it's simply due to running AltUI which requests the usual status updates from the engine (I don't usually run AltUI on this system.)
          The video simply streams from the camera to the browser, and openLuup doesn't see the video stream. The only time it gets involved is in downloading an archive snapshot from the camera (or receiving email triggers with attached images.)
          • propheadP Offline
            propheadP Offline
            prophead
            Success, thank you for your help. It looks really good.
            • propheadP Offline
              propheadP Offline
              prophead
              While you’re at it can you make set attribute category_num to 6 so it’s recognized as a camera
              TIA
              • propheadP prophead
                TIA
                @prophead
                Will do! The category system is rather flawed, so I tend to ignore it!
                  @prophead
                  #31
                  @akbooer said in The death of a thousand cuts:
                  By way of example...
                  The category is traditionally defined by the device file. It turns out that D_DigitalSecurityCamera1.xml does not set it. D_DigitalSecurityCamera2.xml, OTOH, does!
                  • propheadP Offline
                    propheadP Offline
                    prophead
                    Should I switch to D_DigitalSecurityCamera2?
                      ...or just set the category manually. The extra controls offered by #2 are, IIRC, for steerable cameras. This isn’t implemented as it stands, so it makes no difference. If it’s an issue (to steer) it could be added.
                      • DesTD DesT
                        @therealdb said in The death of a thousand cuts:
                        my own bot
                        Can you elaborate? 😉
                        @DesT said in The death of a thousand cuts:
                        my own bot
                        I wrote a bot for telegram. I already posted some pictures on the Vera forum:
                        52277123-e6a0-4038-b1d8-cc83203fcd95-image.png aeb491db-5446-4ec7-88c8-5f2fc63d66d6-image.png
                        Commands are in italian, but you'll get the point. First 3 are related to OpenSprinkler, then there’s a sensor connected to Vera for the entryway door, plus a short video (as GIF) from the camera. All the notifications are sent via Telegram, to me/my wife using position (since I used to work 50% of my time in a different part of the country before this COVID-19 mess, now I'm full remote for a couple of months).
                        The idea is to add frequently used manual actions here, and then get rid of the app 🙂
                        I'm now into forcing my wife to use it more, in order to add more features. For me, manual control of blinds in case of need is more than enough.
                        • propheadP Offline
                          propheadP Offline
                          prophead
                          My dudes, I tried your HomeWave suggestion. I’m not having a great experience. It’s flaky and im having difficulty adding devices.
                            156.0k
