  3. Vera
  4. zwaveserial
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
zwaveserial
    Never posted this on the vera forum but...
    Did you know about this?
    The vera has a very powerful zwaveserial API program in the firmware. Take a look at what it can do:
    It is what the UI calls to interface with the zwave dongle.
    • parkercP Offline
      parkercP Offline
      parkerc
      Hi @rafale77, thanks for sharing this, this is good info to know..
      Not only do I have a VeraPlus with an external USB Z-wave module, (as the onboard zwave chip failed), I’m also exploring a ‘Serial Server’ where I would have multiple usb/serial devices connected that can then be shared with any number of HA controllers you want to run.
      Based on this and anything else you know, can you mesh/sync multiple z-wave modules?
      (I’ve specifically used the term module and not controller, as I assume the latter is the software that works behind the modules) ?
      • parkercP parkerc
        @parkerc
        Not sure I fully understand what you are trying to do in meshing/syncing multiple z-wave modules.
        The modules can talk to one another through zwave for sure but I think you are rather looking for a controller which can control multiple zwave dongles. If such is the case, I so far do not know of any controller which can do this natively. What you can do though is... use openluup with multiple controller instances and bridges which is already what @akbooer is doing.
        This makes sense with you have multiple zwave networks in physically separated locations which don't interfere with one another and want them all centralize within one controller.
        As I found out through my analysis, it makes no sense to have multiple colocated zwave networks as they will interfere with one another causing reliability and performance issues. People have done this only because the vera problems with larger networks were even a bigger problem and used this as a workaround but it is really unnecessary under normal zwave condition.
        So technically you could have multiple zwave dongles running in different locations all bridged through multiple instances of z-way bridge or verabridges. I don't know if z-way-server can control multiple zwave modules within one instance... From the look of it, it theoretically could but I never tried.
        • Black CatB Offline
          Black CatB Offline
          Black Cat
          Homeseer can do this without interference.
          I had multiple Z-wave UZB's Pi mounted all connected by ser2net to the Primary HS Controller as a test, the physical limit is over 200.
          No bridge required, just as many RasPi (and UZB's) as you need (or want). Other protocols may require a Converter.
          With HS you can add Interfaces for many protocols - HS wan't designed as a Z-wave box, rather as a HA controller which would accept multiple interfaces - that's the beauty of HS, it's a semi profesional system without the $$$$ price tag.
          aka Zedrally
          • Black CatB Black Cat
            @Black-Cat
            Don't think we are talking about the same interference...
            I am talking about z-wave RF interference which will happen if you have collocated z-wave networks. You may just not know it but it causes retries and CRC errors in frames which the zwave chip has to deal with, often causing latencies and worst case, completely lost frames. It has nothing to do with the controller. It is the nature of z-wave.
            What you are describing... is what openLuup does as well along with home assistant etc. Nothing special about HomeSeer... It is just picking up the various serial ports and utilize them within their own plugins.
              164.0k
