  3. Zway Bridge
  4. All Z-way devices "disabled" attribute is set to 1
full devices reset
Zway Bridge
Help with Z-Way plugin
Zway Bridge
Zway Bridge
Zway Bridge
Renaming device name...
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Zway Bridge
Z-way token Expiration
Zway Bridge
Zway Bridge
XMLs & jsons without vera
P
Zway Bridge
Error after device delete
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Child device undo failure
Zway Bridge
K
Zway Bridge
Zway Bridge
z-way with home assistant
Zway Bridge
6 Posts 2 Posters 2.3k Views 2 Watching
  • K Offline
    K Offline
    kfxo
      Yes... in the process of switching the devices became unavailable (openLuup must have been restarted whilst they were offline) so were put into room 101 (rather then just being deleted.). For some good reason, that I currently fail to recall, I also disable devices that are put in there.
      If they’re not associated with scene actions or triggers, then the easiest thing is simply to delete them with the openLuup plugin’s EmptyRoom101 action and then restart openLuup.
      If that’s not acceptable I can easily provide a Lua script which reenables the existing devices.
      K 1 Reply Last reply
        K Offline
        K Offline
        kfxo
        @akbooer said in All Z-way devices "disabled" attribute is set to 1:
        The problem is they are no longer in Room 101 because they were unavailable and then became available again. So if z-way becomes unreachable for some reason and openLuup is restarted during that time, this would happen again? Seems undesirable.
        I wrote a Lua script that enables all the devices with device #'s in the 20000's
        	if k >= 20000 and k < 30000 then
        	    luup.attr_set("disabled", 0, k)
          Yes, of course, that's the case.
          Your code is just what I would have offered.
          I'll revisit the decision to disable the devices – it shouldn't actually make any difference to them, since they have no implementation of their own. Of course, it appears to have had a negative impact on Imperihome.
          • K Offline
            K Offline
            kfxo
            Yeah not a big deal, easily fixable with the lua script and should not happen often.
              This should be fixed in development release v20.5.12
                165.2k
