  3. Zway Bridge
  4. full devices reset
full devices reset
Zway Bridge
Help with Z-Way plugin
Zway Bridge
Zway Bridge
Zway Bridge
Renaming device name...
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Zway Bridge
Z-way token Expiration
Zway Bridge
Zway Bridge
XMLs & jsons without vera
P
Zway Bridge
Error after device delete
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Child device undo failure
Zway Bridge
K
Zway Bridge
Zway Bridge
z-way with home assistant
Zway Bridge
full devices reset
77 Posts 2 Posters 49.2k Views 2 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    @akbooer
      Would it be acceptable to just delete the ZWay plug-in and start again?
      …or am I misunderstanding the problem?
      • DesTD Offline
        DesTD Offline
        DesT
        Ohhhh yeah... good idea.. so just by deleting the zway plugin, all devices will be removed ?
          Oh yes. No parent device, then no children!
          • DesTD Offline
            DesTD Offline
            DesT
            @akbooer Didn't had a chance to do it yet but, is it possible instead that the bridge "update" openLuup instead ? I mean if I rename/move a device in z-way, it will automatically be updated on openLuup on the next reload ?
            'cause deleting the plugin, it will break a couple of plugins that I'm using, like Rulesengine and maybe Smartswitch too...
              There should be a device variable called NAMEDEVICES, and if set to true, then the device names should be copied from ZWay.
              • DesTD Offline
                DesTD Offline
                DesT
                And what about the room ?
                • DesTD Offline
                  DesTD Offline
                  DesT
                  NameDevices is already at TRUE btw
                    Same for CloneRooms?
                    • DesTD Offline
                      DesTD Offline
                      DesT
                      CloneRooms is having of 1, I should change it to true ?
                      • DesTD Offline
                        DesTD Offline
                        DesT
                        @akbooer just check something else, and looks like I will have the same kind of issue with the verabridge, that doesn't move/rename devices too
                          I thought that CloneRooms did that. I don’t have a running Vera or ZWay setup that I can test.
                          Renaming and reroofing devices is really quick in the openLuup console, on the devices page.
                          How many devices do you have to relocate?
                          If you have a list of them (old/new) then it’s easy enough to write a script to automate it.
                          • DesTD Offline
                            DesTD Offline
                            DesT
                            CloneRooms, I think it works the first time only...
                            I'm still using Vera for 2 things, 3 zigbee thermostat that I can't migrate on z-way and also the DSC plugin (for our alarm), I have the source of the plugin, but I can't make it works under openLuup, so I'm still having it on Vera!
                            • DesTD Offline
                              DesTD Offline
                              DesT
                              And I can confirm also that renaming a device under z-way, it doesn't change it under openLuup
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                if at least the renaming is working, I can move them manually after.
                                But having the rename them 1 by 1, and also moving, I will be doing that for a long long day 😉
                                  So ZWay is really the issue, rather than VeraBridge?
                                  • DesTD Offline
                                    DesTD Offline
                                    DesT
                                    I can deal with verabridge, as I don't really changed a lot of stuff on this side. On Vera, I just rename some "rooms", so I can deal with thoses changes manually in openLuup.
                                    The real issue for me, it's z-way bridge, as all my zwave devices are there.
                                      Does this URL return you a JSON list of ZWave devices?
                                      http://ZWayIP:8083/ZAutomation/api/v1/devices
                                      If I had that, and the user_data.json file from openLuup, than I might be able to make the necessary adjustments.
                                      • DesTD Offline
                                        DesTD Offline
                                        DesT
                                        • DesTD Offline
                                          DesTD Offline
                                          DesT
                                          @akbooer let me know if you need them by email
                                            163.2k
